Quelqu’un pourrait me dire quelle serait ma carte son ?
$ dmesg
Bootdata ok (command line is root=/dev/sda1 ro )
Linux version 2.6.18-6-amd64 (Debian 2.6.18.dfsg.1-23etch1) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Fri Dec 12 05:49:32 UTC 2008
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e6000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000007bfd0000 (usable)
BIOS-e820: 000000007bfd0000 - 000000007bfde000 (ACPI data)
BIOS-e820: 000000007bfde000 - 000000007c000000 (ACPI NVS)
BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
DMI present.
ACPI: RSDP (v000 ACPIAM ) @ 0x00000000000f98d0
ACPI: RSDT (v001 A M I OEMRSDT 0x04000803 MSFT 0x00000097) @ 0x000000007bfd0000
ACPI: FADT (v002 A M I OEMFACP 0x04000803 MSFT 0x00000097) @ 0x000000007bfd0200
ACPI: MADT (v001 A M I OEMAPIC 0x04000803 MSFT 0x00000097) @ 0x000000007bfd0390
ACPI: MCFG (v001 A M I OEMMCFG 0x04000803 MSFT 0x00000097) @ 0x000000007bfd0400
ACPI: OEMB (v001 A M I AMI_OEM 0x04000803 MSFT 0x00000097) @ 0x000000007bfde040
ACPI: HPET (v001 A M I OEMHPET0 0x04000803 MSFT 0x00000097) @ 0x000000007bfd47e0
ACPI: DSDT (v001 1ADMB 1ADMB006 0x00000006 INTL 0x20051117) @ 0x0000000000000000
Scanning NUMA topology in Northbridge 24
Number of nodes 1
Node 0 MemBase 0000000000000000 Limit 000000007bfd0000
NUMA: Using 63 for the hash shift.
Using node hash shift of 63
Bootmem setup node 0 0000000000000000-000000007bfd0000
On node 0 totalpages: 499929
DMA zone: 3056 pages, LIFO batch:0
DMA32 zone: 496873 pages, LIFO batch:31
ACPI: PM-Timer IO Port: 0x4008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 15:11 APIC version 16
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
Processor #1 15:11 APIC version 16
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
ACPI: IRQ14 used by override.
ACPI: IRQ15 used by override.
Setting APIC routing to physical flat
ACPI: HPET id: 0x10de8201 base: 0xfeff0000
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 80000000 (gap: 7c000000:82c00000)
SMP: Allowing 2 CPUs, 0 hotplug CPUs
Built 1 zonelists. Total pages: 499929
Kernel command line: root=/dev/sda1 ro
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 32768 bytes)
time.c: Using 25.000000 MHz WALL HPET GTOD HPET timer.
time.c: Detected 2712.969 MHz processor.
Console: colour VGA+ 80x25
Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Checking aperture...
CPU 0: aperture @ 12b0000000 size 32 MB
Aperture too small (32 MB)
No AGP bridge found
Memory: 1991560k/2031424k available (1929k kernel code, 39476k reserved, 870k data, 176k init)
Calibrating delay using timer specific routine.. 5431.80 BogoMIPS (lpj=10863606)Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 256
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
CPU 0/0 -> Node 0
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
SMP alternatives: switching to UP code
ACPI: Core revision 20060707
Using local APIC timer interrupts.
result 12560041
Detected 12.560 MHz APIC timer.
SMP alternatives: switching to SMP code
Booting processor 1/2 APIC 0x1
Initializing CPU#1
Calibrating delay using timer specific routine.. 5425.16 BogoMIPS (lpj=10850334)CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU 1/1 -> Node 0
CPU: Processor Core ID: 1
AMD Athlon(tm) 64 X2 Dual Core Processor 5200+ stepping 02
CPU 1: Syncing TSC to CPU 0.
CPU 1: synchronized TSC with CPU 0 (last diff 13 cycles, maxerr 576 cycles)
Brought up 2 CPUs
testing NMI watchdog ... OK.
migration_cost=194
checking if image is initramfs... it is
Freeing initrd memory: 4898k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: BIOS Bug: MCFG area at e0000000 is not E820-reserved
PCI: Not using MMCONFIG.
PCI: Using configuration type 1
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
Error attaching device data
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:00:0d.0
PCI: Transparent bridge - 0000:00:04.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR10._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR11._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR12._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *11
ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNEA] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNEB] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNEC] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNED] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LUB0] (IRQs 20 21 22 23) *5
ACPI: PCI Interrupt Link [LUB2] (IRQs 20 21 22 23) *10
ACPI: PCI Interrupt Link [LMAC] (IRQs 20 21 22 23) *5
ACPI: PCI Interrupt Link [LAZA] (IRQs 20 21 22 23) *11
ACPI: PCI Interrupt Link [LACI] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [LMC9] (IRQs 20 21 22 23) *10
ACPI: PCI Interrupt Link [LSMB] (IRQs 20 21 22 23) *11
ACPI: PCI Interrupt Link [LPMU] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [LSA0] (IRQs 20 21 22 23) *10
ACPI: PCI Interrupt Link [LSA1] (IRQs 20 21 22 23) *10
ACPI: PCI Interrupt Link [LATA] (IRQs 20 21 22 23) *0, disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: ACPI device : hid PNP0A03
pnp: ACPI device : hid PNP0200
pnp: ACPI device : hid PNP0B00
pnp: ACPI device : hid PNP0800
pnp: ACPI device : hid PNP0C04
pnp: ACPI device : hid PNP0501
pnp: ACPI device : hid PNP0400
pnp: ACPI device : hid PNP0C02
pnp: ACPI device : hid PNP0103
pnp: ACPI device : hid PNP0303
pnp: ACPI device : hid PNP0F03
pnp: ACPI device : hid PNP0C01
pnp: PnP ACPI: found 15 devices
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
hpet0: at MMIO 0xfeff0000 (virtual 0xffffffffff5fe000), IRQs 2, 8, 31
hpet0: 3 32-bit timers, 25000000 Hz
PCI-DMA: Disabling IOMMU.
pnp: the driver 'system' has been registered
pnp: match found with the PnP device '00:07' and the driver 'system'
pnp: match found with the PnP device '00:09' and the driver 'system'
pnp: match found with the PnP device '00:0c' and the driver 'system'
pnp: 00:0c: ioport range 0xa00-0xadf has been reserved
pnp: 00:0c: ioport range 0xae0-0xaef has been reserved
pnp: match found with the PnP device '00:0d' and the driver 'system'
pnp: match found with the PnP device '00:0e' and the driver 'system'
PCI: Bridge: 0000:00:04.0
IO window: disabled.
MEM window: feb00000-febfffff
PREFETCH window: disabled.
PCI: Bridge: 0000:00:09.0
MEM window: disabled.
PCI: Bridge: 0000:00:0b.0
PCI: Bridge: 0000:00:0c.0
PCI: Setting latency timer of device 0000:00:04.0 to 64
PCI: Setting latency timer of device 0000:00:09.0 to 64
PCI: Setting latency timer of device 0000:00:0b.0 to 64
PCI: Setting latency timer of device 0000:00:0c.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
TCP: Hash tables configured (established 262144 bind 65536)
TCP reno registered
audit: initializing netlink socket (disabled)
audit(1260027202.696:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
pcie_portdrv_probe->Dev[03e8:10de] has invalid IRQ. Check vendor BIOS
assign_interrupt_mode Found MSI capability
Allocate Port Service[0000:00:09.0:pcie00]
pcie_portdrv_probe->Dev[03e9:10de] has invalid IRQ. Check vendor BIOS
Allocate Port Service[0000:00:0b.0:pcie00]
Allocate Port Service[0000:00:0c.0:pcie00]
Real Time Clock Driver v1.12ac
hpet_resources: 0xfeff0000 is busy
Linux agpgart interface v0.101 (c) Dave Jones
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
pnp: the driver 'serial' has been registered
pnp: match found with the PnP device '00:05' and the driver 'serial'
00:05: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
pnp: the driver 'i8042 kbd' has been registered
pnp: match found with the PnP device '00:0a' and the driver 'i8042 kbd'
pnp: the driver 'i8042 aux' has been registered
pnp: match found with the PnP device '00:0b' and the driver 'i8042 aux'
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
ACPI: (supports S0 S1 S3 S4 S5)
Freeing unused kernel memory: 176k freed
ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
ACPI: PCI Interrupt Link [LUB0] enabled at IRQ 23
GSI 16 sharing vector 0xC9 and IRQ 16
ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LUB0] -> GSI 23 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:02.0 to 64
ohci_hcd 0000:00:02.0: OHCI Host Controller
ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
ohci_hcd 0000:00:02.0: irq 201, io mem 0xfeafb000
forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.56.
SCSI subsystem initialized
libata version 2.00 loaded.
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 10 ports detected
ACPI: PCI Interrupt Link [LUB2] enabled at IRQ 22
GSI 17 sharing vector 0xD1 and IRQ 17
ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [LUB2] -> GSI 22 (level, low) -> IRQ 209
PCI: Setting latency timer of device 0000:00:02.1 to 64
ehci_hcd 0000:00:02.1: EHCI Host Controller
ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 2
ehci_hcd 0000:00:02.1: debug port 1
PCI: cache line size of 64 is not supported by device 0000:00:02.1
ehci_hcd 0000:00:02.1: irq 209, io mem 0xfeafac00
ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 10 ports detected
sata_nv 0000:00:08.0: version 2.0
ACPI: PCI Interrupt Link [LSA0] enabled at IRQ 21
GSI 18 sharing vector 0xD9 and IRQ 18
ACPI: PCI Interrupt 0000:00:08.0[A] -> Link [LSA0] -> GSI 21 (level, low) -> IRQ 217
PCI: Setting latency timer of device 0000:00:08.0 to 64
ata1: SATA max UDMA/133 cmd 0xE400 ctl 0xE082 bmdma 0xD880 irq 217
ata2: SATA max UDMA/133 cmd 0xE000 ctl 0xDC02 bmdma 0xD888 irq 217
scsi0 : sata_nv
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata1.00: ATA-7, max UDMA/133, 488397168 sectors: LBA48 NCQ (depth 0/32)
ata1.00: ata1: dev 0 multi count 16
ata1.00: configured for UDMA/133
scsi1 : sata_nv
ata2: SATA link down (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0xE007
Vendor: ATA Model: MAXTOR STM325031 Rev: 4.AA
Type: Direct-Access ANSI SCSI revision: 05
ACPI: PCI Interrupt Link [LSA1] enabled at IRQ 20
GSI 19 sharing vector 0xE1 and IRQ 19
ACPI: PCI Interrupt 0000:00:08.1[B] -> Link [LSA1] -> GSI 20 (level, low) -> IRQ 225
PCI: Setting latency timer of device 0000:00:08.1 to 64
ata3: SATA max UDMA/133 cmd 0xD800 ctl 0xD482 bmdma 0xD000 irq 225
ata4: SATA max UDMA/133 cmd 0xD400 ctl 0xD082 bmdma 0xD008 irq 225
scsi2 : sata_nv
usb 1-2: new low speed USB device using ohci_hcd and address 2
usb 1-2: configuration #1 chosen from 1 choice
ata3: SATA link down (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0xD807
scsi3 : sata_nv
usb 1-4: new low speed USB device using ohci_hcd and address 3
ata4: SATA link down (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0xD407
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
usb 1-4: configuration #1 chosen from 1 choice
usbcore: registered new driver hiddev
ACPI: PCI Interrupt Link [LMAC] enabled at IRQ 23
ACPI: PCI Interrupt 0000:00:07.0[A] -> Link [LMAC] -> GSI 23 (level, low) -> IRQ 201
PCI: Setting latency timer of device 0000:00:07.0 to 64
forcedeth: using HIGHDMA
0000:00:07.0: Invalid Mac address detected: fb:b7:3b:85:21:00
Please complain to your hardware vendor. Switching to a random MAC.
input: NOVATEK USB Keyboard as /class/input/input0
input: USB HID v1.10 Keyboard [NOVATEK USB Keyboard] on usb-0000:00:02.0-2
input: NOVATEK USB Keyboard as /class/input/input1
input,hiddev96: USB HID v1.10 Device [NOVATEK USB Keyboard] on usb-0000:00:02.0-2
input: Logitech USB Receiver as /class/input/input2
input: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-0000:00:02.0-4
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
eth0: forcedeth.c: subsystem: 01462:7309 bound to 0000:00:07.0
NFORCE-MCP61: IDE controller at PCI slot 0000:00:06.0
NFORCE-MCP61: chipset revision 162
NFORCE-MCP61: not 100% native mode: will probe irqs later
NFORCE-MCP61: 0000:00:06.0 (rev a2) UDMA133 controller
ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:pio, hdb:pio
Probing IDE interface ide0...
SCSI device sda: 488397168 512-byte hdwr sectors (250059 MB)
sda: Write Protect is off
sda: Mode Sense: 00 3a 00 00
SCSI device sda: drive cache: write back
sda: sda1 sda2 sda3 sda4
sd 0:0:0:0: Attached scsi disk sda
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
ts: Compaq touchscreen protocol output
ndiswrapper version 1.53 loaded (smp=yes, preempt=no)
input: PC Speaker as /class/input/input3
ndiswrapper (check_nt_hdr:150): kernel is 64-bit, but Windows driver is not 64-bit;bad magic: 010B
ndiswrapper (load_sys_files:206): couldn't prepare driver 'mrv8335'
ndiswrapper (load_wrap_driver:108): couldn't load driver mrv8335; check system log for messages from 'loadndisdriver'
usbcore: registered new driver ndiswrapper
pnp: the driver 'parport_pc' has been registered
pnp: match found with the PnP device '00:06' and the driver 'parport_pc'
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
EXT3 FS on sda1, internal journal
loop: loaded (max 8 devices)
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
lp0: using parport0 (interrupt-driven).
ppdev: user-space parallel port driver
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
NFSD: starting 90-second grace period
NET: Registered protocol family 5
eth57: no IPv6 routers present
