La mise à jour avais rien réglé donc j’ai choisi de réinstaller et après 2 petites heures, j’ai retrouvé mon systeme et presque tout fonctionne!
Il me reste à activer les sons système de gdm entre autres.
Malgré avoir ajouté les options dans les diverses fichiers de configuration, toujours rien.
/etc/gdm/gdm.conf
[code]# GDM Custom Configuration file.
This file is the appropriate place for specifying your customizations to the
GDM configuration. If you run gdmsetup, it will automatically edit this
file for you and will cause the daemon and any running GDM GUI programs to
automatically update with the new configuration. Not all configuration
options are supported by gdmsetup, so to modify some values it may be
necessary to modify this file directly by hand.
This file overrides the default configuration settings. These settings
are stored in the GDM System Defaults configuration file, which is found
at the following location.
/usr/share/gdm/defaults.conf.
This file contains comments about the meaning of each configuration option,
so is also a useful reference. Also refer to the documentation links at
the end of this comment for further information. In short, to hand-edit
this file, simply add or modify the key=value combination in the
appropriate section in the template below this comment section.
For example, if you want to specify a different value for the Enable key
in the “[debug]” section of your GDM System Defaults configuration file,
then add “Enable=true” in the “[debug]” section of this file. If the
key already exists in this file, then simply modify it.
Older versions of GDM used the “gdm.conf” file for configuration. If your
system has an old gdm.conf file on the system, it will be used instead of
this file - so changes made to this file will not take effect. Consider
migrating your configuration to this file and removing the gdm.conf file.
If you hand edit a GDM configuration file, you can run the following
command and the GDM daemon will immediately reflect the change. Any
running GDM GUI programs will also be notified to update with the new
configuration.
gdmflexiserver --command="UPDATE_CONFIG "
e.g, the “Enable” key in the “[debug]” section would be “debug/Enable”.
You can also run gdm-restart or gdm-safe-restart to cause GDM to restart and
re-read the new configuration settings. You can also restart GDM by sending
a HUP or USR1 signal to the daemon. HUP behaves like gdm-restart and causes
any user session started by GDM to exit immediately while USR1 behaves like
gdm-safe-restart and will wait until all users log out before restarting GDM.
For full reference documentation see the gnome help browser under
GNOME|System category. You can also find the docs in HTML form on
http://www.gnome.org/projects/gdm/
NOTE: Lines that begin with “#” are considered comments.
Have fun!
[daemon]
SoundProgram=/usr/bin/aplay
[security]
AllowRoot=false
[xdmcp]
[gui]
[greeter]
SoundOnLogin=true
SoundOnLoginFile=/usr/share/sounds/question.wav
SoundOnLoginSuccess=true
SoundOnLoginSuccessFile=/usr/share/sounds/login.wav
SoundOnLoginFailure=true
SoundOnLoginFailureFile=/usr/share/sounds/warning.wav
GraphicalTheme=BlueSwirl
GraphicalThemes=happygnome/:circles
[chooser]
[debug]
Note that to disable servers defined in the GDM System Defaults
configuration file (such as 0=Standard, you must put a line in this file
that says 0=inactive, as described in the Configuration section of the GDM
documentation.
[servers]
Also note, that if you redefine a [server-foo] section, then GDM will
use the definition in this file, not the GDM System Defaults configuration
file. It is currently not possible to disable a [server-foo] section
defined in the GDM System Defaults configuration file.
#[/code]
[code]# GDM System Defaults Configuration file.
This file should not be updated by hand. Since GDM 2.13.0.4, configuration
choices in the GDM System Configuration file (/etc/gdm/gdm.conf) will
override the default values specified in this file.
If you were using an older version of GDM, your system may have the the older
gdm.conf configuration file on the system. If so, then this file is used
instead of the GDM Custom Configuration file for backwards support. If you
make changes to the GDM Custom Configuration file and they seem to not be
taking effect, this is likely the problem. Consider migrating your
configuration to the new configuration file and removing the gdm.conf file.
You can use the gdmsetup program to graphically edit the gdm.conf-custom
file. Note that gdmsetup does not support every option in this file, just
the most common ones that users want to change. If you feel that gdmsetup
should support additional configuration options, please file a bug report at
http://bugzilla.gnome.org/.
If you hand-edit the GDM configuration, you should run the following command
to get the GDM daemon to recognize the change. Any running GDM GUI programs
will also be notified to update with the new configuration.
You can also run invoke-rc.d gdm reload or invoke-rc.d gdm restart
to cause GDM to restart and re-read the new configuration settings.
You can also restart GDM by sending a HUP or USR1 signal to the
daemon. HUP behaves like restart and causes any user session
reload and will wait until all users log out before
restarting GDM.
For full reference documentation see the GNOME help browser under
NOTE: Some values are commented out, but show their default values. Lines
Have fun!
[daemon]
Automatic login, if true the first attached screen will automatically logged
in as user as set with AutomaticLogin key.
AutomaticLoginEnable=false
AutomaticLogin=
Timed login, useful for kiosks. Log in a certain user after a certain amount
of time.
TimedLoginEnable=false
TimedLogin=
TimedLoginDelay=30
The GDM configuration program that is run from the login screen, you should
probably leave this alone.
#Configurator=/usr/sbin/gdmsetup --disable-sound --disable-crash-dialog
The chooser program. Must output the chosen host on stdout, probably you
should leave this alone.
#Chooser=/usr/lib/gdm/gdmchooser
The greeter for attached (non-xdmcp) logins. Change gdmlogin to gdmgreeter
to get the new graphical greeter.
Greeter=/usr/lib/gdm/gdmgreeter
The greeter for xdmcp logins, usually you want a less graphically intensive
greeter here so it’s better to leave this with gdmlogin
#RemoteGreeter=/usr/lib/gdm/gdmlogin
Launch the greeter with an additional list of colon separated GTK+ modules.
This is useful for enabling additional feature support e.g. GNOME
accessibility framework. Only “trusted” modules should be allowed to minimize
security holes
#AddGtkModules=false
By default, these are the accessibility modules.
#GtkModulesList=gail:atk-bridge:/usr/lib/gtk-2.0/modules/libdwellmouselistener:/usr/lib/gtk-2.0/modules/libkeymouselistener
Default path to set. The profile scripts will likely override this value.
DefaultPath=/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/games
Default path for root. The profile scripts will likely override this value.
RootPath=/usr/local/bin:/usr/local/sbin:/sbin:/usr/sbin:/bin:/usr/bin:/usr/bin/X11:/usr/games
If you are having trouble with using a single server for a long time and want
GDM to kill/restart the server, turn this on. On Solaris, this value is
always true and this configuration setting is ignored.
#AlwaysRestartServer=
User and group used for running GDM GUI applications. By default this is set
to user “gdm” and group “gdm”. This user/group should have very limited
permissions and access to only the gdm directories and files.
User=gdm
Group=gdm
To try to kill all clients started at greeter time or in the Init script.
does not always work, only if those clients have a window of their own.
#KillInitClients=true
LogDir=/var/log/gdm
Note that a post login script is run before a PreSession script. It is run
after the login is successful and before any setup is run on behalf of the
user.
PostLoginScriptDir=/etc/gdm/PostLogin/
PreSessionScriptDir=/etc/gdm/PreSession/
PostSessionScriptDir=/etc/gdm/PostSession/
DisplayInitDir=/etc/gdm/Init
Distributions: If you have some script that runs an X server in say VGA
mode, allowing a login, could you please send it to me?
#FailsafeXServer=
if X keeps crashing on us we run this script. The default one does a bunch
of cool stuff to figure out what to tell the user and such and can run an X
configuration program.
XKeepsCrashing=/etc/gdm/XKeepsCrashing
System command support.
Reboot, Halt and suspend commands, you can add different commands separated
by a semicolon. GDM will use the first one it can find.
RebootCommand=/sbin/shutdown -r now "Rebooted via gdm."
HaltCommand=/sbin/shutdown -h now "Shut Down via gdm."
SuspendCommand=/usr/sbin/pm-suspend
The following options specify how GDM system commands are supported.
Specify which actions are displayed in the greeter. Valid values are HALT,
REBOOT, SUSPEND, and CUSTOM_CMD separated by semicolons.
SystemCommandsInMenu=HALT;REBOOT;SUSPEND;CUSTOM_CMD
Specify which actions are supported by QUERY_LOGOUT_ACTION, SET_LOGOUT_ACTION
and SET_SAFE_LOGOUT_ACTION. Valid values are HALT, REBOOT, SUSPEND, and
AllowLogoutActions=HALT;REBOOT;SUSPEND;CUSTOM_CMD
This feature is only functional if GDM is compiled with RBAC (Role Based
Access Control) support.
Specify the RBAC key used to determine if the user has permission to use
the action via QUERY_LOGOUT_ACTION, SET_LOGOUT_ACTION and
SET_SAFE_LOGOUT_ACTION. The GDM GUI will only display the action if the
“gdm” user has RBAC permissions to use the action. RBAC keys for multiple
actions can be specified by separating them by semicolons. The format for
each is “Action:RBAC key”. If an action is not specified, it is assumed
all users have permission for this action. For example:
HALT:key.for.halt,REBOOT:key.for.reboot,[…]
RBACSystemCommandKeys=
Probably should not touch the below this is the standard setup.
ServAuthDir=/var/lib/gdm
This is our standard startup script. A bit different from a normal X
session, but it shares a lot of stuff with that. See the provided default
for more information.
BaseXsession=/etc/gdm/Xsession
This is a directory where .desktop files describing the sessions live. It is
really a PATH style variable since 2.4.4.2 to allow actual interoperability
with KDM.
SessionDesktopDir=/usr/share/gdm/BuiltInSessions/:/usr/share/xsessions/:/etc/dm/Sessions/
This is the default .desktop session. One of the ones in SessionDesktopDir
DefaultSession=default.desktop
Better leave this blank and HOME will be used. You can use syntax ~/ below
to indicate home directory of the user. You can also set this to something
like /tmp if you don’t want the authorizations to be in home directories.
This is useful if you have NFS mounted home directories. Note that if this
is the home directory the UserAuthFBDir will still be used in case the home
directory is NFS, see security/NeverPlaceCookiesOnNFS to override this
behavior.
UserAuthDir=
Fallback directory for writing authorization file if user’s home directory
is not writable.
UserAuthFBDir=/tmp
UserAuthFile=.Xauthority
The X server to use if we can’t figure out what else to run.
StandardXServer=/usr/bin/X
The maximum number of flexible X servers to run.
#FlexibleXServers=5
And after how many minutes should we reap the flexible server if there is no
activity and no one logged on. Set to 0 to turn off the reaping. Does not
affect nested flexiservers.
#FlexiReapDelayMinutes=5
The X nest command.
Examples of valid commands (assuming installed to /usr/X11/bin:
Xorg Xnest: /usr/X11/bin/Xnest -audit 0 -name Xnest
Xsun Xnest: /usr/openwin/bin/Xnest -audit 0 -name Xnest -pn
Xephyr: /usr/X11/bin/Xephyr -audit 0
Xnest=/usr/share/gdm/gdmXnestWrapper -audit 0
Xsun Xnest does not support font paths (passed into Xnest -fp argument)
that include the “:unscaled” suffix after a path name. Setting this to
false will strip any “:unscaled” suffix from the font path. If not
using this Xnest, the value should be true.
XnestUnscaledFontPath=true
Automatic VT allocation. Right now only works on Linux. This way we force
X to use specific vts. Turn VTAllocation to false if this is causing
problems.
FirstVT=7
VTAllocation=true
Should double login be treated with a warning (and possibility to change VT’s
on Linux and FreeBSD systems for console logins)
#DoubleLoginWarning=true
Should a second login always resume the current session and switch VT’s on
#AlwaysLoginCurrentSession=true
If true then the last login information is printed to the user before being
prompted for password. While this gives away some info on what users are on
a system, it on the other hand should give the user an idea of when they
logged in and if it doesn’t seem kosher to them, they can just abort the
login and contact the sysadmin (avoids running malicious startup scripts).
#DisplayLastLogin=false
Program used to play sounds. Should not require any ‘daemon’ or anything
like that as it will be run when no one is logged in yet.
These are the languages that the console cannot handle because of font
issues. Here we mean the text console, not X. This is only used when there
are errors to report and we cannot start X.
This is the default:
#ConsoleCannotHandle=am,ar,az,bn,el,fa,gu,hi,ja,ko,ml,mr,pa,ta,zh
This determines whether GDM will honor requests DYNAMIC requests from the
gdmdynamic command.
#DynamicXServers=false
This determines whether GDM will send notifications to the console.
#ConsoleNotify=true
How long gdm should wait before it assumes a started Xserver is defunct and
kills it. 10 seconds should be long enough for X, but Xgl may need 20 or 25.
GdmXserverTimeout=10
[security]
Allow root to login. It makes sense to turn this off for kiosk use, when
you want to minimize the possibility of break in.
AllowRoot=false
Allow login as root via XDMCP. This value will be overridden and set to
false if the /etc/default/login file exists and contains
“CONSOLE=/dev/login”, and set to true if the /etc/default/login file exists
and contains any other value or no value for CONSOLE.
AllowRemoteRoot=false
This will allow remote timed login.
AllowRemoteAutoLogin=false
0 is the most restrictive, 1 allows group write permissions, 2 allows all
write permissions.
RelaxPermissions=1
Check if directories are owned by logon user. Set to false, if you have, for
example, home directories owned by some other user.
CheckDirOwner=true
If your HOME is managed by automounter, set to true
SupportAutomount=false
Number of seconds to wait after a failed login
#RetryDelay=1
Maximum size of a file we wish to read. This makes it hard for a user to DoS
us by using a large file.
#UserMaxFile=65536
If true this will basically append -nolisten tcp to every X command line, a
good default to have (why is this a “negative” setting? because if it is
false, you could still not allow it by setting command line of any particular
server). It’s probably better to ship with this on since most users will not
need this and it’s more of a security risk then anything else.
Note: Anytime we find a -query or -indirect on the command line we do not add
a “-nolisten tcp”, as then the query just wouldn’t work, so this setting only
affects truly attached sessions.
DisallowTCP=true
By default never place cookies if we “detect” NFS. We detect NFS by
detecting “root-squashing”. It seems bad practice to place cookies on things
that go over the network by default and thus we do not do it by default.
Sometimes you can however use safe remote filesystems where this is OK and
you may want to have the cookie in your home directory.
#NeverPlaceCookiesOnNFS=true
Will cause PAM_DISALLOW_NULL_AUTHTOK to be passed as a flag to
pam_authenticate and pam_acct_mgmt, disallowing NULL password. This setting
will only take effect if PAM is being used by GDM. This value will be
overridden with the value from /etc/default/login if it contains
“PASSREQ=[YES|NO]”
#PasswordRequired=false
Specifies the PAM Stack to use, “gdm” by default.
PamStack=gdm
GDM allows configuration of how ut_line is set when it does utmp/wtmp and
audit processing. If VT is being used, then ut_line will be set to the
device associated with the VT. If the console is attached and has a device
name specified in the [servers] section, then this value will be used.
Otherwise the value is defaulted to the value specified in UtmpLineAttached
for attached displays and UtmpLineRemote for remote displays. The value
can be left empty which means that ut_line will be set to an empty value
(if not VT and no value specified in the [servers] section. The values
can contain “%d” which is translated to the DISPLAY value or %h which
is translated to the hostname. The values for both keys must begin with
“/dev/”.
UtmpLineAttached=/dev/console
UtmpLineRemote=
If true and the specified UtmpLineAttached or UtmpLineRemote does not exist,
then create a pseudo-device filename that will be touched when the utmp
record is updated. Creating such a psuedo-device ensures that programs
that stat the utmp device associated with ut_line such as finger, last,
etc. work in a reasonable way.
UtmpPseudoDevice=false
XDMCP is the protocol that allows remote login. If you want to log into GDM
remotely (I’d never turn this on on open network, use ssh for such remote
usage). You can then run X with -query to log in, or
-indirect to run a chooser. Look for the ‘Terminal’ server type
at the bottom of this config file.
[xdmcp]
Distributions: Ship with this off. It is never a safe thing to leave out on
the net. Setting up /etc/hosts.allow and /etc/hosts.deny to only allow local
access is another alternative but not the safest. Firewalling port 177 is
the safest if you wish to have xdmcp on. Read the manual for more notes on
the security of XDMCP.
Enable=false
Honor indirect queries, we run a chooser for these, and then redirect the
user to the chosen host. Otherwise we just log the user in locally.
#HonorIndirect=true
Maximum pending requests.
#MaxPending=4
#MaxPendingIndirect=4
Maximum open XDMCP sessions at any point in time.
#MaxSessions=16
Maximum wait times.
#MaxWait=15
#MaxWaitIndirect=15
How many times can a person log in from a single host. Usually better to
keep low to fend off DoS attacks by running many logins from a single host.
This is now set at 2 since if the server crashes then GDM doesn’t know for
some time and wouldn’t allow another session.
#DisplaysPerHost=2
The number of seconds after which a non-responsive session is logged off.
Better keep this low.
#PingIntervalSeconds=15
The port. 177 is the standard port so better keep it that way.
#Port=177
Willing script, none is shipped and by default we’ll send hostname system id.
But if you supply something here, the output of this script will be sent as
status of this host so that the chooser can display it. You could for
example send load, or mail details for some user, or some such.
#Willing=/etc/gdm/Xwilling
[gui]
The specific gtkrc file we use. It should be the full path to the gtkrc that
we need. Unless you need a specific gtkrc that doesn’t correspond to a
specific theme, then just use the GtkTheme key.
#GtkRC=/usr/share/themes/Default/gtk-2.0/gtkrc
The GTK+ theme to use for the GUI.
GtkTheme=Clearlooks
If to allow changing the GTK+ (widget) theme from the greeter. Currently
this only affects the standard greeter as the graphical greeter does not yet
have this ability.
#AllowGtkThemeChange=true
Comma separated list of themes to allow. These must be the names of the
themes installed in the standard locations for gtk themes. You can also
specify ‘all’ to allow all installed themes. These should be just the
basenames of the themes such as ‘Thinice’ or ‘LowContrast’.
#GtkThemesToAllow=all
Maximum size of an icon, larger icons are scaled down.
#MaxIconWidth=128
#MaxIconHeight=128
[greeter]
The following options for setting titlebar and setting window position are
only useful for the standard login (gdmlogin) and are not used by the
themed login (gdmgreeter).
The standard login has a title bar that the user can move.
#TitleBar=true
Don’t allow user to move the standard login window. Only makes sense if
TitleBar is on.
#LockPosition=false
Set a position for the standard login window rather then just centering the
window. If you enter negative values for the position it is taken as an
offset from the right or bottom edge.
#SetPosition=false
#PositionX=0
#PositionY=0
Enable the Face browser. Note that the Browser key is only used by the
standard login (gdmlogin) program. The Face Browser is enabled in
the Graphical greeter by selecting a theme that includes the Face
Browser, such as happygnome-list. The other configuration values that
affect the Face Browser (MinimalUID, DefaultFace, Include, Exclude,
IncludeAll, GlobalFaceDir) are used by both the Standard and Themed
greeter.
Browser=true
The default picture in the browser.
#DefaultFace=/usr/share/pixmaps/nobody.png
User ID’s less than the MinimalUID value will not be included in the face
browser or in the gdmselection list for Automatic/Timed login. They will not
be displayed regardless of the settings for Include and Exclude.
MinimalUID=1000
Users listed in Include will be included in the face browser and in the
gdmsetup selection list for Automatic/Timed login. Users should be separated
by commas.
#Include=
Users listed in Exclude are excluded from the face browser and from the
gdmsetup selection list for Automatic/Timed login. Excluded users will still
be able to log in, but will have to type their username. Users should be
separated by commas.
Exclude=nobody
By default, an empty include list means display no users. By setting
IncludeAll to true, the password file will be scanned and all users will be
displayed except users excluded via the Exclude setting and user ID’s less
than MinimalUID. Scanning the password file can be slow on systems with
large numbers of users and this feature should not be used in such
environments. The setting of IncludeAll does nothing if Include is set to a
non-empty value.
IncludeAll=true
If user or user.png exists in this dir it will be used as his picture.
#GlobalFaceDir=/usr/share/pixmaps/faces/
File which contains the locale we show to the user. Likely you want to use
the one shipped with GDM and edit it. It is not a standard locale.alias
file, although GDM will be able to read a standard locale.alias file as well.
LocaleFile=/etc/gdm/locale.conf
Logo shown in the standard greeter.
Logo=/usr/share/pixmaps/gdmDebianLogo.xpm
Logo shown on file chooser button in gdmsetup (do not modify this value).
#ChooserButtonLogo=/usr/share/pixmaps/gdm-foot-logo.png
The standard greeter should shake if a user entered the wrong username or
password. Kind of cool looking
#Quiver=true
The Actions menu (formerly system menu) is shown in the greeter, this is the
menu that contains reboot, shutdown, suspend, config and chooser. None of
these is available if this is off. They can be turned off individually
however.
#SystemMenu=true
Configuration is available from the system menu of the greeter.
#ConfigAvailable=true
Should the chooser button be shown. If this is shown, GDM can drop into
chooser mode which will run the xdmcp chooser locally and allow the user to
connect to some remote host. Local XDMCP does not need to be enabled,
however.
#ChooserButton=true
Welcome is for all console logins and RemoteWelcome is for remote logins
(through XDMCP).
DefaultWelcome and DefaultRemoteWelcome set the string for Welcome to
“Welcome” and for DefaultWelcome to “Welcome to %n”, and properly translate
the message to the appropriate language. Note that %n gets translated to the
hostname of the machine. These default values can be overridden by setting
DefaultWelcome and/or DefaultRemoteWelcome to false, and setting the Welcome
and DefaultWelcome values as desired. Just make sure the strings are in
utf-8 Note to distributors, if you wish to have a different Welcome string
and wish to have this translated you can have entries such as
“Welcome[cs]=Vitejte na %n”.
DefaultWelcome=true
DefaultRemoteWelcome=true
#Welcome=Welcome
#RemoteWelcome=Welcome to %n
Xinerama screen we use to display the greeter on. Not for true multihead,
currently only works for Xinerama.
#XineramaScreen=0
Background settings for the standard greeter:
Type can be 0=None, 1=Image & Color, 2=Color, 3=Image
#BackgroundType=2
#BackgroundImage=
#BackgroundScaleToFit=true
The Standard greeter (gdmlogin) uses BackgroundColor as the background
color, while the themed greeter (gdmgreeter) uses GraphicalThemedColor
as the background color.
BackgroundColor=#76848F
GraphicalThemedColor=#76848F
XDMCP session should only get a color, this is the sanest setting since you
don’t want to take up too much bandwidth
#BackgroundRemoteOnlyColor=true
Program to run to draw the background in the standard greeter. Perhaps
something like an xscreensaver hack or some such.
#BackgroundProgram=
If this is true then the background program is run always, otherwise it is
only run when the BackgroundType is 0 (None).
#RunBackgroundProgramAlways=false
Delay before starting background program
#BackgroundProgramInitialDelay=30
Should the background program be restarted if it is exited.
#RestartBackgroundProgram=true
Delay before restarting background program
#BackgroundProgramRestartDelay=30
Show the Failsafe sessions. These are much MUCH nicer (focus for xterm for
example) and more failsafe then those supplied by scripts so distros should
use this rather then just running an xterm from a script.
#ShowGnomeFailsafeSession=true
#ShowXtermFailsafeSession=true
Normally there is a session type called ‘Last’ that is shown which refers to
the last session the user used. If off, we will be in ‘switchdesk’ mode
where the session saving stuff is disabled in GDM
#ShowLastSession=true
Always use 24 hour clock no matter what the locale.
#Use24Clock=auto
Do not show any visible feedback in the password field. This is standard for
instance in console, xdm and ssh.
#UseInvisibleInEntry=false
These two keys are for the themed greeter (gdmgreeter). Circles is the
standard shipped theme. If you want GDM to select a random theme from a
list then provide a list that is delimited by /: to the GraphicalThemes
key and set GraphicalThemeRand to true. Otherwise use GraphicalTheme
and specify just one theme.
GraphicalTheme=debian-moreblue-orbit
#GraphicalThemes=debian-moreblue-orbit:/bijou/:blueswirl/:circles/:debblue-list/:debblue/:ayo/:debian-dawn/:debian-greeter/:debian/:glassfoot/:hantzley/:happygnome/:industrial/:crystal/:linsta
GraphicalThemeDir=/usr/share/gdm/themes/
GraphicalThemeRand=false
If InfoMsgFile points to a file, the greeter will display the contents of the
file in a modal dialog box before the user is allowed to log in.
#InfoMsgFile=
If InfoMsgFile is present then InfoMsgFont can be used to specify the font to
be used when displaying the contents of the file.
#InfoMsgFont=Sans 24
If SoundOnLogin is true, then the greeter will beep when login is ready for
user input. If SoundOnLogin is a file and the greeter finds the ‘play’
executable (see daemon/SoundProgram) it will play that file instead of just
beeping.
SoundOnLogin=true
If SoundOnLoginSuccess, then the greeter will play a sound (as above) when a
user successfully logs in.
If SoundOnLoginFailure, then the greeter will play a sound (as above) when a
user fails to log in.
Specifies a program to be called by the greeter/login program when the
initial screen is displayed. The purpose is to provide a hook where files
used after login can be preloaded to speed performance for the user. The
program will only be called once only, the first time a greeter is displayed.
The gdmprefetch command may be used. This utility will load any libraries
passed in on the command line, or if the argument starts with a “@”
character, it will process the file assuming it is an ASCII file containing a
list of libraries, one per line, and load each library in the file.
PreFetchProgram=/usr/lib/gdmprefetch @/etc/gdm/gdmprefetchlist
The chooser is what’s displayed when a user wants an indirect XDMCP session,
or selects Run XDMCP chooser from the system menu
[chooser]
Default image for hosts.
#DefaultHostImg=/usr/share/pixmaps/nohost.png
Directory with host images, they are named by the hosts: host or host.png.
HostImageDir=/usr/share/hosts/
Time we scan for hosts (well only the time we tell the user we are scanning
actually, we continue to listen even after this has expired).
#ScanTime=4
A comma separated lists of hosts to automatically add (if they answer to a
query of course). You can use this to reach hosts that broadcast cannot
reach.
Hosts=
Broadcast a query to get all hosts on the current network that answer.
Broadcast=true
Set it to true if you want to send a multicast query to hosts.
Multicast=false
It is an IPv6 multicast address.It is hardcoded here and will be replaced
when officially registered xdmcp multicast address of TBD will be available.
#Multicast_Addr=ff02::1
Allow adding random hosts to the list by typing in their names.
#AllowAdd=true
[debug]
This will cause GDM to send debugging information to the system log, which
will create a LOT of output. It is not recommended to turn this on for
normal use, but it can be useful to determine the cause when GDM is not
working properly.
Enable=false
This will enable debug messages for accessibilty gesture listeners into the
syslog. This includes output about key events, mouse button events, and
pointer motion events. This is useful for figuring out the cause of why the
gesture listeners may not be working, but is too verbose for general debug.
Gestures=false
Attached DISPLAY Configuration
[servers]
This section defines which attached DISPLAYS should be started by GDM by
default. You can add as many DISPLAYS as desired and they will always be
started. The key for each entry must be a unique number that cooresponds to
the DISPLAY number to start the X server. For a typical single-display
machine, there will only be one entry “0” for DISPLAY “:0”. The first word
in the value corresponds to an X server definition in the "X Server
Definitions" section of the configuration file. For example, the entry:
0=Standard
Means that DISPLAY “:0” will start an X server as defined in the
[server-Standard] section.
The optional device argument is used to specify the device that is associated
with the DISPLAY. When using Virtual Terminals (VT), this value is ignored
and GDM will use the correct device name associated with the VT. If not
using VT, then GDM will use the value specified by this optional argument.
If the device argument is not defined, then GDM will use the default setting
for attached displays defined in the UtmpLineAttached configuration option.
For the main display (typically DISPLAY “:0”), “/dev/console” is a reasonable
value. For other displays it is probably best to not include this argument
unless you know the specific device associated with the DISPLAY. The device
value can contain “%d” which is translated to the DISPLAY value or %h which
0=Standard device=/dev/console
Example of how to set up DISPLAY :1 to also use Standard.
#1=Standard
If you wish to run the XDMCP chooser on the local display use the following
line
#0=Chooser
X Server Definitions
Note: Is your X server not listening to TCP requests? Refer to the
security/DisallowTCP setting!
[server-Standard]
name=Standard server
command=/usr/bin/X -audit 0
flexible=true
Indicates that the X server should be started at a different process
priority. Values can be any integer value accepted by the setpriority C
library function (normally between -20 and 20) with 0 being the default. For
highly interactive applications, -5 yields good responsiveness. The default
value is 0 and the setpriority function is not called if the value is 0.
#priority=0
To use this server type you should add -query host or -indirect host to the
command line.
[server-Terminal]
name=Terminal server
Add -terminate to make things behave more nicely
command=/usr/bin/X -audit 0 -terminate
Make this not appear in the flexible servers (we need extra params anyway,
and terminate would be bad for xdmcp choosing). You can make a terminal
server flexible, but not with an indirect query. If you need flexible
indirect query server, then you must get rid of the -terminate and the only
way to kill the flexible server will then be by Ctrl-Alt-Backspace.
flexible=false
Do not handle this X server for attached displays.
handled=false
command line.
[server-Chooser]
name=Chooser server
Make this not appear in the flexible servers for now, but if you wish to
allow a chooser server then make this true. This is the only way to make a
flexible chooser server that behaves nicely.
flexible=false
Run the chooser instead of the greeter. When the user chooses a machine they
will get this same server but run with “-terminate -query hostname”.
chooser=true
[customcommand]
This section allows you specify up to 10 custom commands. Each of the
commands can be defined by the seven parameters listed below. In each of the
descriptions of the parameters N can take on any values between 0 and 9,
i.e. CustomCommand0=,CustomCommand1=,…,CustomCommand9=. The numbers
can have gaps as long as they fit within predefined set of 10, and their
placement order within this section and with respect to each other is
not important.
CustomCommandN, CustomCommandTextN, CustomCommandLabelN,
CustomCommandLRLabelN, CustomCommandTooltipN, CustomCommandIsPersistentN
and CustomCommandNoRestartN should all be defined for a given integer N,
where N can be a number from 0-9 (if not the default values will be
assigned except CustomCommandN for which no default exists).
Custom command to run. Multiple commands may be specified separated by
semicolons. GDM will use the first valid command. Examples:
/sbin/bootwindoze;/usr/bin/bootwindoze, or
/sbin/runupdate;/usr/local/sbin/runupdate
#CustomCommandN=
Custom command dialog message that will appear on all warning dialogs.
This will vary depending on what you want to do. Examples:
Are you sure you want to restart system into Windoze?, or
Are you sure you want do do this?
#CustomCommandTextN=
Custom command label that will appear as stock label on buttons/menu items.
This option can’t contain any semicolon characters (i.e. “;”).
Examples:
_Windoze, or
_Update Me
#CustomCommandLabelN=
Custom command label that will appear as stock label on radio buttons/list
items. The underscore indicates the mnemonic used with this item. Examples:
Restart into _Windoze
Perform system _Update
#CustomCommandLRLabelN=
Custom command tooltip. Examples
Restarts the computer into Windoze
Updates the computer software to the most recent version(s)
#CustomCommandTooltipN=
Custom command persistence option. Setting it to true will allow this
command to appear outside the login manager, e.g. on the desktop through
Log Out/Shut Down dialogs. The default value is false.
#CustomCommandIsPersistentN=
Custom command gdm/system restart option. Setting it to true will not
restart gdm after command execution. The default commands (reboot, shut
down) all reboot the system by default which is why the default setting
is true.
In addition when corresponding CustomCommandIsPersistentN option is set to
true, setting CustomCommandNoRestartN to false will place CustomCommandN
in the Shut Down dialog set of actions, setting it to true will place
CustomCommandN in the Log Out dialog set of actions.
#CustomCommandNoRestartN=
Example layout for more than one command:
#CustomCommand0=
#CustomCommandText0=
#CustomCommandLabel0=
#CustomCommandLRLabel0=
#CustomCommandTooltip0=
#CustomCommandIsPersistent0=
#CustomCommandNoRestart0=
#CustomCommand1=
#CustomCommandText1=
#CustomCommandLabel1=
#CustomCommandLRLabel1=
#CustomCommandTooltip1=
#CustomCommandIsPersistent1=
#CustomCommandNoRestart1=
