problème de sources.list, même le dimanche
voilà depuis quelques temps un icône triangulaire apparaît en haut de la barre gnome, je suis sous la dernière version Lenny 5.0.4 que j’ai installée par cdrom.
D’abord voilà le message d’erreur
[code]The repository may no longer be available or could not be contacted because of network problems. If available an older version of the failed index will be used. Otherwise the repository will be ignored. Check your network connection and ensure the repository address in the preferences is correct.
http://security.debian.org/lenny/updates/dists/main/contrib/source/Sources: 404 Not Found [IP : 130.89.149.225 80]
http://security.debian.org/lenny/updates/dists/main/non-free/source/Sources: 404 Not Found [IP : 130.89.149.225 80]
http://ftp.fr.debian.org/dists/lenny/main/binary-i386/Packages: 404 Not Found
http://ftp.fr.debian.org/dists/lenny/contrib/binary-i386/Packages: 404 Not Found[/code]
Puis mon sources.list un peu chargé certes, mais il y a des logiciels que j’aimerais pouvoir récupérer, donc
[code]# deb cdrom:[Debian GNU/Linux 5.0.4 Lenny - Official i386 CD Binary-1 20100131-18:53]/ lenny main
#deb cdrom:[Debian GNU/Linux 5.0.4 Lenny - Official i386 CD Binary-1 20100131-18:53]/ lenny main
deb http://ftp.fr.debian.org/debian/ lenny main
deb-src http://ftp.fr.debian.org/debian/ lenny main
deb http://security.debian.org/ lenny/updates main
deb-src http://security.debian.org/ lenny/updates main
deb http://volatile.debian.org/debian-volatile lenny/volatile main
deb-src http://volatile.debian.org/debian-volatile lenny/volatile main
#Depot Debian contrib non-free
deb http://ftp.fr.debian.org/ lenny main contrib non-free
deb-src http://ftp.fr.debian.org/ lenny main contrib non-free
#Stable security
deb http://security.debian.org/ lenny/updates main contrib non-free
deb-src http://security.debian.org/lenny/updates main contrib non-free
#volatile
deb http://volatile.debian.org/debian-volatile stable/volatile main contrib non-free
deb-src http://volatile.debian.org/debian-volatile stable/volatile main contrib non-free
#lenny-backports
deb http://www.backports.org/debian lenny-backports main contrib non-free
deb-src http://www.backports.org/debian lenny-backports main contrib non-free
#Depot debian multimedia
deb http://www.debian-multimedia.org stable main non-free
deb-src http://www.debian-multimedia.org stable main non-free
#Depot Debian Virtualbox
deb http://download.virtualbox.org/virtualbox/debian lenny non-free[/code]
Merci si vous avez 5 minutes
Tu as plein de doublons…
Par exemple :
deb ftp.fr.debian.org/debian/ lenny main
et
deb ftp.fr.debian.org/ lenny main contrib non-free
Commente tous les deb-src (à moins que tu ne compile…).
Commente toutes les lignes, et dé-commente ligne après ligne en faisant un apt-get update à chaque ligne dé-commentée, tu finira pas tomber sur la (ou les) lignes fautives…
:smt006
merci lol,
je lance là dessus de suite,
merci je te tiens au courant
merci,
super ça marche il faut juste que j’obtienne la clé public de backports
merci lol
c’est réglé.
[quote=“hannao”]merci lol
c’est réglé.[/quote]
Cool !
J’étais un peu gêné de ne pas éplucher plus en avant ton sources.list, mais j’ai une petite connexion ce soir, et vérifier les dépôts c’était un peu galère…
Ceci dit, c’est bien de savoir procéder par élimination !
Bonne soirée. :smt006
