Bonsoir,
la commande sensors me renvoit des alertes sur des tensions trop élévés:
sensors
w83627dhg-isa-0290
Adapter: ISA adapter
VCore: +1.30 V (min = +0.00 V, max = +1.74 V)
in1: +11.30 V (min = +8.55 V, max = +0.00 V) ALARM
AVCC: +3.26 V (min = +3.58 V, max = +1.02 V) ALARM
3VCC: +3.26 V (min = +0.00 V, max = +0.38 V) ALARM
in4: +1.44 V (min = +1.15 V, max = +0.01 V) ALARM
in5: +1.67 V (min = +0.51 V, max = +0.07 V) ALARM
in6: +4.68 V (min = +4.92 V, max = +0.00 V) ALARM
VSB: +3.26 V (min = +0.00 V, max = +0.70 V) ALARM
VBAT: +0.00 V (min = +2.05 V, max = +2.05 V) ALARM
Case Fan: 0 RPM (min = 1318 RPM, div = 16) ALARM
CPU Fan: 2576 RPM (min = 0 RPM, div = 4) ALARM
Aux Fan: 0 RPM (min = 10546 RPM, div = 4) ALARM
fan5: 0 RPM (min = 2636 RPM, div = 16) ALARM
Sys Temp: +38°C (high = +68°C, hyst = +72°C)
CPU Temp: +22.0°C (high = +80.0°C, hyst = +75.0°C)
AUX Temp: +119.0°C (high = +80.0°C, hyst = +75.0°C) ALARM
J’ai touché a aucun reglage dans le bios tous est a la config d’origine. J’ai une carte mere pk5k et un core 2 duo e6750. Est des fausses alertes ou dois je en tenir compte?
