debian:/home/tux# dmesg
Linux version 2.6.18-6-686 (Debian 2.6.18.dfsg.1-23) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Mon Oct 13 16:13:09 UTC 2008
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000ce000 - 00000000000d0000 (reserved)
BIOS-e820: 00000000000dc000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001f6f0000 (usable)
BIOS-e820: 000000001f6f0000 - 000000001f6fb000 (ACPI data)
BIOS-e820: 000000001f6fb000 - 000000001f700000 (ACPI NVS)
BIOS-e820: 000000001f700000 - 0000000020000000 (reserved)
BIOS-e820: 00000000fec10000 - 00000000fec20000 (reserved)
BIOS-e820: 00000000ffb00000 - 00000000ffc00000 (reserved)
BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
502MB LOWMEM available.
On node 0 totalpages: 128752
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 124656 pages, LIFO batch:31
DMI 2.3 present.
ACPI: RSDP (v000 FUJ ) @ 0x000f5b00
ACPI: RSDT (v001 FUJ FJNB185 0x01100000 FUJ 0x00000100) @ 0x1f6f49c6
ACPI: FADT (v001 FUJ FJNB185 0x01100000 FUJ 0x00000100) @ 0x1f6faf8c
ACPI: SSDT (v001 FUJ FJNB185 0x01100000 INTL 0x20030522) @ 0x1f6faaf8
ACPI: SSDT (v001 FUJ FJNB185 0x01100000 MSFT 0x0100000e) @ 0x1f6faf1a
ACPI: BOOT (v001 FUJ FJNB185 0x01100000 FUJ 0x00000100) @ 0x1f6faf64
ACPI: DSDT (v001 FUJ FJNB185 0x01100000 MSFT 0x0100000e) @ 0x00000000
ACPI: PM-Timer IO Port: 0xfc08
Allocating PCI resources starting at 30000000 (gap: 20000000:dec10000)
Detected 1700.130 MHz processor.
Built 1 zonelists. Total pages: 128752
Kernel command line: root=/dev/hda1 ro
Local APIC disabled by BIOS – you can enable it with "lapic"
mapped APIC to ffffd000 (013fa000)
Enabling fast FPU save and restore… done.
Enabling unmasked SIMD FPU exception support… done.
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 8192 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 502580k/515008k available (1541k kernel code, 11904k reserved, 580k data, 196k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode… Ok.
Calibrating delay using timer specific routine… 3402.24 BogoMIPS (lpj=6804498)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: afe9f9bf 00000000 00000000 00000000 00000180 00000000 00000000
CPU: After vendor identify, caps: afe9f9bf 00000000 00000000 00000000 00000180 00000000 00000000
CPU: L1 I cache: 32K, L1 D cache: 32K
CPU: L2 cache: 2048K
CPU: After all inits, caps: afe9f9bf 00000000 00000000 00000040 00000180 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking ‘hlt’ instruction… OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 12k freed
ACPI: Core revision 20060707
ACPI: setting ELCR to 0200 (from 0800)
CPU0: Intel® Pentium® M processor 1.70GHz stepping 06
SMP motherboard not detected.
Local APIC not detected. Using dummy APIC emulation.
Brought up 1 CPUs
migration_cost=0
checking if image is initramfs… it is
Freeing initrd memory: 4788k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfd972, last bus=3
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:00:02.0
PCI quirk: region fc00-fc7f claimed by ICH4 ACPI/GPIO/TCO
PCI quirk: region fc80-fcbf claimed by ICH4 GPIO
PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
PCI: Transparent bridge - 0000:00:1e.0
PCI: Bus #03 (-#06) is hidden behind transparent bridge #01 (-#03) (try ‘pci=assign-busses’)
Please report the result to linux-kernel to fix this permanently
PCI: Bus #07 (-#0a) is hidden behind transparent bridge #01 (-#03) (try ‘pci=assign-busses’)
ACPI: PCI Interrupt Routing Table [_SB_.PCI0.PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 9 10 *11)
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 10 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 9 10 *11)
ACPI: PCI Interrupt Routing Table [_SB.PCI0.HUB_._PRT]
Linux Plug and Play Support v0.97 © Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 11 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn’t work, try “pci=routeirq”. If it helps, post a report
PCI: Ignore bogus resource 6 [0:0] of 0000:00:02.0
PCI: Bus 2, cardbus bridge: 0000:01:0a.0
IO window: 00003000-000030ff
IO window: 00003400-000034ff
PREFETCH window: 30000000-31ffffff
MEM window: 38000000-39ffffff
PCI: Bus 3, cardbus bridge: 0000:01:0a.1
IO window: 00003800-000038ff
IO window: 00003c00-00003cff
PREFETCH window: 32000000-33ffffff
MEM window: 3a000000-3bffffff
PCI: Bus 7, cardbus bridge: 0000:01:0a.3
IO window: 00004000-000040ff
IO window: 00004400-000044ff
PREFETCH window: 34000000-35ffffff
MEM window: 3c000000-3dffffff
PCI: Bridge: 0000:00:1e.0
IO window: 3000-4fff
MEM window: d0200000-d02fffff
PREFETCH window: 30000000-35ffffff
PCI: Setting latency timer of device 0000:00:1e.0 to 64
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:01:0a.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI Interrupt 0000:01:0a.1[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
PCI: Enabling device 0000:01:0a.3 (0080 -> 0083)
ACPI: PCI Interrupt 0000:01:0a.3[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:01:0a.3 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
Simple Boot Flag at 0x7f set to 0x1
audit: initializing netlink socket (disabled)
audit(1225848183.820:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
isapnp: Scanning for PnP cards…
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS3 at I/O 0x2e8 (irq = 3) is a 16550A
00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
ACPI: PCI Interrupt 0000:00:1f.6[B] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI interrupt for device 0000:00:1f.6 disabled
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
i8042.c: Detected active multiplexing controller, rev 1.1.
serio: i8042 AUX0 port at 0x60,0x64 irq 12
serio: i8042 AUX1 port at 0x60,0x64 irq 12
serio: i8042 AUX2 port at 0x60,0x64 irq 12
serio: i8042 AUX3 port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI No-Shortcut mode
ACPI: (supports S0 S3 S4 S5)
Time: tsc clocksource has been installed.
Freeing unused kernel memory: 196k freed
ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
input: AT Translated Set 2 keyboard as /class/input/input0
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt 0000:00:1d.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1d.0 to 64
uhci_hcd 0000:00:1d.0: UHCI Host Controller
uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1d.0: irq 11, io base 0x000020c0
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
ACPI: PCI Interrupt 0000:00:1d.1[B] -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1d.1 to 64
uhci_hcd 0000:00:1d.1: UHCI Host Controller
uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:1d.1: irq 11, io base 0x000020e0
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ieee1394: Initialized config rom entry `ip1394’
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
ACPI: PCI Interrupt 0000:00:1d.2[C] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1d.2 to 64
uhci_hcd 0000:00:1d.2: UHCI Host Controller
uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:1d.2: irq 11, io base 0x00002400
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
Time: acpi_pm clocksource has been installed.
ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 11
ACPI: PCI Interrupt 0000:00:1d.7[D] -> Link [LNKH] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1d.7 to 64
ehci_hcd 0000:00:1d.7: EHCI Host Controller
ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 4
ehci_hcd 0000:00:1d.7: debug port 1
PCI: cache line size of 32 is not supported by device 0000:00:1d.7
ehci_hcd 0000:00:1d.7: irq 11, io mem 0xd0100000
ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 6 ports detected
ICH4: IDE controller at PCI slot 0000:00:1f.1
PCI: Enabling device 0000:00:1f.1 (0005 -> 0007)
ACPI: PCI Interrupt 0000:00:1f.1[A] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
ICH4: chipset revision 3
ICH4: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0x2440-0x2447, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0x2448-0x244f, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0…
hda: FUJITSU MHT2040AT, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1…
hdc: MATSHITADVD-RAM UJ-820S, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
tg3.c:v3.65 (August 07, 2006)
ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 11
ACPI: PCI Interrupt 0000:01:0c.0[A] -> Link [LNKE] -> GSI 11 (level, low) -> IRQ 11
eth0: Tigon3 [partno(BCM95788MT58) rev 3003 PHY(5705)] (PCI:33MHz:32-bit) 10/100/1000BaseT Ethernet 00:0b:5d:74:36:ea
eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] Split[0] WireSpeed[0] TSOcap[1]
eth0: dma_rwctrl[763f0000] dma_mask[64-bit]
ACPI: PCI Interrupt Link [LNKF] enabled at IRQ 11
ACPI: PCI Interrupt 0000:01:0e.0[A] -> Link [LNKF] -> GSI 11 (level, low) -> IRQ 11
ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[11] MMIO=[d0216000-d02167ff] Max Packet=[2048] IR/IT contexts=[4/8]
hda: max request size: 128KiB
hda: 78140160 sectors (40007 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(100)
hda: cache flushes supported
hda: hda1 hda2 < hda5 >
hdc: ATAPI 24X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ieee1394: Host added: ID:BUS[0-00:1023] GUID[00000e1002929818]
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
eth1394: eth0: IEEE-1394 IPv4 over 1394 Ethernet (fw-host0)
Linux agpgart interface v0.101 © Dave Jones
agpgart: Detected an Intel 855 Chipset.
agpgart: Detected 8060K stolen memory.
agpgart: AGP aperture is 128M @ 0xd8000000
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
input: PC Speaker as /class/input/input1
intel_rng: FWH not detected
Real Time Clock Driver v1.12ac
Yenta: CardBus bridge found at 0000:01:0a.0 [10cf:11c4]
Yenta O2: res at 0x94/0xD4: ea/00
Yenta O2: enabling read prefetch/write burst
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
irda_init()
NET: Registered protocol family 23
Yenta: ISA IRQ mask 0x0438, PCI irq 11
Socket status: 30000410
pcmcia: parent PCI bridge I/O window: 0x3000 - 0x4fff
cs: IO port probe 0x3000-0x4fff: clean.
pcmcia: parent PCI bridge Memory window: 0xd0200000 - 0xd02fffff
pcmcia: parent PCI bridge Memory window: 0x30000000 - 0x35ffffff
Yenta: CardBus bridge found at 0000:01:0a.1 [10cf:11c4]
ieee80211_crypt: registered algorithm 'NULL’
Socket status: 30000006
Yenta: Raising subordinate bus# of parent bus (#01) from #03 to #06
Yenta: CardBus bridge found at 0000:01:0a.3 [10cf:11c4]
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright © 2004-2005 Intel Corporation jketreno@linux.intel.com
ipw2200: Intel® PRO/Wireless 2200/2915 Network Driver, 1.1.2kmq
ipw2200: Copyright© 2003-2006 Intel Corporation
input: PS/2 Generic Mouse as /class/input/input2
found SMC SuperIO Chip (devid=0x5a rev=00 base=0x002e): LPC47N227
smsc_superio_flat(): fir: 0x400, sir: 0x2e8, dma: 03, irq: 3, mode: 0x0e
smsc_ircc_present: can’t get sir_base of 0x2e8
Yenta: Raising subordinate bus# of parent bus (#01) from #06 to #0a
ACPI: PCI Interrupt 0000:00:1f.3[B] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
ACPI: PCI Interrupt 0000:00:1f.5[B] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1f.5 to 64
ts: Compaq touchscreen protocol output
pccard: PCMCIA card inserted into slot 0
cs: memory probe 0xd0200000-0xd02fffff: excluding 0xd0200000-0xd021ffff
pcmcia: registering new device pcmcia0.0
intel8x0_measure_ac97_clock: measured 55352 usecs
intel8x0: clocking to 48000
PCI: Enabling device 0000:00:1f.6 (0000 -> 0001)
PCI: Setting latency timer of device 0000:00:1f.6 to 64
ACPI: PCI Interrupt 0000:01:0d.0[A] -> Link [LNKC] -> GSI 11 (level, low) -> IRQ 11
ipw2200: Detected Intel PRO/Wireless 2200BG Network Connection
ipw2200: ipw2200-bss.fw request_firmware failed: Reason -2
ipw2200: Unable to load firmware: -2
ipw2200: failed to register network device
ACPI: PCI interrupt for device 0000:01:0d.0 disabled
ipw2200: probe of 0000:01:0d.0 failed with error -5
cs: IO port probe 0x100-0x3af: clean.
cs: IO port probe 0x3e0-0x4ff: excluding 0x400-0x407 0x4d0-0x4d7
cs: IO port probe 0x820-0x8ff: clean.
cs: IO port probe 0xc00-0xcf7: clean.
cs: IO port probe 0xa00-0xaff: clean.
Adding 1485972k swap on /dev/hda5. Priority:-1 extents:1 across:1485972k
EXT3 FS on hda1, internal journal
loop: loaded (max 8 devices)
SCSI subsystem initialized
ieee1394: sbp2: Driver forced to serialize I/O (serialize_io=1)
ieee1394: sbp2: Try serialize_io=0 for better performance
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
pcmcia: Detected deprecated PCMCIA ioctl usage from process: discover.
pcmcia: This interface will soon be removed from the kernel; please expect breakage unless you upgrade to new tools.
pcmcia: see kernel.org/pub/linux/utils/k … cmcia.html for details.
i8xx TCO timer: failed to reset NO_REBOOT flag, reboot disabled by hardware
PM: Writing back config space on device 0000:01:0c.0 at offset c (was ffff0000, writing 0)
PM: Writing back config space on device 0000:01:0c.0 at offset b (was 165d14e4, writing 127910cf)
PM: Writing back config space on device 0000:01:0c.0 at offset 3 (was 0, writing 4008)
PM: Writing back config space on device 0000:01:0c.0 at offset 2 (was 2000000, writing 2000003)
PM: Writing back config space on device 0000:01:0c.0 at offset 1 (was 2b00000, writing 2b00106)
PM: Writing back config space on device 0000:01:0c.0 at offset 0 (was 165d14e4, writing 165e14e4)
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
ADDRCONF(NETDEV_UP): eth1: link is not ready
IPv6 over IPv4 tunneling driver
ACPI: Battery Slot [CMB1] (battery present)
ACPI: Battery Slot [CMB2] (battery absent)
ACPI: AC Adapter [AC] (on-line)
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
ACPI: Lid Switch [LID]
lp0: using parport0 (interrupt-driven).
ppdev: user-space parallel port driver
Bluetooth: Core ver 2.10
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.8
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
[drm] Initialized drm 1.0.1 20051102
ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
[drm] Initialized i915 1.5.0 20060119 on minor 0
[drm] Initialized i915 1.5.0 20060119 on minor 1
tg3: eth1: Link is up at 100 Mbps, full duplex.
tg3: eth1: Flow control is on for TX and on for RX.
ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
tg3: eth1: Link is down.
ISO 9660 Extensions: Microsoft Joliet Level 3
ISO 9660 Extensions: RRIP_1991A
eth1: no IPv6 routers present
debian:/home/tux#
J’ai connecté un fil pour avoir internet en attendant.
