Ok!
un remove --purge libkdb5-4 serait chaud, alors …
Remplaces ta section “Package: libkdb5-4” par celle qui suit (cela tombe bien je suis également en i386)
[quote=“vincent2459”]Package: libkdb5-4
Priority: standard
Section: libs
Installed-Size: 160
Maintainer: Sam Hartman hartmans@debian.org
Architecture: i386
Source: krb5
Version: 1.8.3+dfsg-4squeeze5^BReplaces: libkadm55 (<< 1.6.dfsg.4~beta1-7)
Depends: libc6 (>= 2.4), libcomerr2 (>= 1.01), libgssrpc4 (>= 1.7dfsg~alpha1), $
Suggests: krb5-doc, krb5-user[/quote]
Mais pour ce faire une précaution s’impose, faire une sauvegarde du fichier /var/lib/dpkg/available
# nano -c /var/lib/dpkg/available
Effectues une recherche du paquet mentionner à l’aide des touches Ctrl +w, “Recherche:” Package: libkdb5-4
- Copier/coller en remplacement de ta section.
Notes: Ctrl +x +o pour enregistrer la modif.
Package: libkdb5-4
Priority: standard
Section: libs
Installed-Size: 160
Maintainer: Sam Hartman <hartmans@debian.org>
Architecture: i386
Source: krb5
Version: 1.8.3+dfsg-4squeeze6
Depends: libc6 (>= 2.4), libcomerr2 (>= 1.01), libgssrpc4 (>= 1.7dfsg~alpha1), libk5crypto3 (>= 1.7+dfsg), libkeyutils1, libkrb5-3 (>= 1.7dfsg), libkrb5support0 (>= 1.7dfsg~beta2)
Breaks: libkadm55, libkadm5srv6
Description: MIT Kerberos runtime libraries - Kerberos database
Kerberos is a system for authenticating users and services on a network.
Kerberos is a trusted third-party service. That means that there is a
third party (the Kerberos server) that is trusted by all the entities on
the network (users and services, usually called "principals").
This is the MIT reference implementation of Kerberos V5.
This package contains the internal Kerberos database libraries.
Homepage: http://web.mit.edu/kerberos/
- Suivit d’une mise à jour.
Que donne ce dernier retour …
