Problème d'envoi de mail serveur postfix/dovecot/sasl
je viens vers vous car j’ai un problème concernant un envoi de mail via le service postfix/dovecot que j’ai installé sur mon vps OVH.
En effet, pour certaines adresses, les mails sont parfaitement transmis. Cependant, pour d’autres, je recois une notification de non délivrance avec l’erreur, le destinataire étant le culture-ion :
[quentin.jousset@culture-ion.fr]: host culture-ion.fr[46.105.171.70] said: 550-Verification failed for [ilt@gaminisen.fr] 550-The mail server could not deliver mail to [ilt@gaminisen.fr] . The account or domain may not exist, they may be blacklisted, or missing the proper dns entries. 550 Sender verify failed (in reply to RCPT TO command)
Je poste également ma configuration ici :
alias_database = hash:/etc/aliases
alias_maps = hash:/etc/aliases
append_dot_mydomain = no
biff = no
compatibility_level = 2
dovecot_destination_recipient_limit = 1
inet_interfaces = all
inet_protocols = ipv4
mailbox_size_limit = 0
mydestination = localhost.ovh.net, localhost
myhostname = gaminisen.fr
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
myorigin = /etc/mailname
readme_directory = no
recipient_delimiter = +
relayhost =
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, rej        ect_unauth_destination
smtpd_relay_restrictions = permit_mynetworks permit_sasl_authenticated defer_una        uth_destination
smtpd_sasl_auth_enable = yes
smtpd_sasl_path = private/auth
smtpd_sasl_type = dovecot
smtpd_tls_auth_only = yes
smtpd_tls_cert_file = /etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file = /etc/ssl/private/ssl-cert-snakeoil.key
smtpd_tls_security_level = may
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtpd_use_tls = yes
virtual_alias_maps = mysql:/etc/postfix/mysql-virtual-alias-maps.cf
virtual_mailbox_domains = mysql:/etc/postfix/mysql-virtual-mailbox-domains.cf
virtual_mailbox_maps = mysql:/etc/postfix/mysql-virtual-mailbox-maps.cf
virtual_transport = dovecot
Merci beaucoup de votre aide !
Un refus de mail en 550- c’est une erreur d’identification de l’emetteur: ton destinataire doit demander que les mails viennent d’un serveur certifié (dkim+spf) et arrive d’une ip non blacklistée pour bien vouloir livrer les mails qui sont transmis.
Le message d’accompagnement donne des pistes, mais le mieux est d’utiliser mail-tester.com, pour avoir plus de détail et améliorer le scoring pour passer les protections antispam.
Ainsi que le site mxtoolbox.com qui est une bonne boîte à outils
Merci pour votre aide . J’ai regardé un peu DKIM mais je ne trouve pas comment le setup…
J’ai déjà mon serveur postfix dovecot chez OVH et mon domaine est chez LWS
J’ai ajouté l’entrée :
TXT key1._domainkey.gaminisen.fr k=rsa; p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIB
Oula !
Ou as tu pris cette clé rsa ?
Pour le dkim, il faut installer opendkim pour signer et c’est lui qui gère les clés dkim des serveurs smtp du domaine, ensuite il faut brancher postfix sur opendkim, et >ensuite<, tu va publier ta clé sur ton dns.
Vaut mieux suivre un tuto, celui là m’a l’air pas mal, avec le spf dedans, et du tls en bonus à la fin):
