Problème d'envoie de mail externe avec postfix
J’ai installer et configurer postfix pour l’envoyer les notifications de nagios mais je rencontre un problème d’envoie de mail vers l’extérieur, en local ça fonctionne
mainf.cf
#soft_bounce = no
smtpd_banner = $myhostname ESMTP $mail_name
biff = no
append_dot_mydomain = no
readme_directory = no
# Informations sur les repertoires locaux
queue_directory = /var/spool/postfix
#command_directory = /usr/sbin
#daemon_directory = /usr/libexec/postfix
mail_owner = postfix
myhostname = AM004.fbr***.com
mydomain = fbr***.com
# POUR L'ENVOI DU COURRIER
#myorigin = $myhostname
myorigin = $mydomain
inet_interfaces = all
inet_protocols = all
mydestination = $myhostname, localhost.$mydomain, localhost $mydomain
mynetworks = 127.0.0.0/8, 10.22.**.0/24
mynetworks_style = class
relayhost = $mydomain
#TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
recipient_delimiter = +
mailbox_size_limit = 0
transport_maps = hash:/etc/postfix/transport
#notify_classes = resource, software
#virtual_alias_maps = hash:/etc/postfix/virtual
log postfix
May  3 11:33:25 AM004 postfix/pickup[6613]: 71540404F6: uid=500 from=<nagios>
May  3 11:33:25 AM004 postfix/cleanup[7260]: 71540404F6: message-id=<20170503093325.71540404F6@AM004.fbr***.com>
May  3 11:33:25 AM004 postfix/qmgr[24201]: 71540404F6: from=<nagios@fbr***.com>, size=518, nrcpt=10 (queue active)
May  3 11:33:25 AM004 postfix/error[30191]: 71540404F6: to=<-s@fbr***.com>, orig_to=<-s>, relay=none, delay=0.02, delays=0.01/0/0/0.01, dsn=5.1.3, status=bounced (bad address syntax)
May  3 11:33:25 AM004 postfix/error[3736]: 71540404F6: to=<toto@Mbout.com>, relay=none, delay=0.02, delays=0.01/0/0/0.01, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to fbr***.com[10.168.0.***]:25: Connection refused)
May  3 11:33:25 AM004 postfix/local[702]: 71540404F6: to=<Service@fbr***.com>, orig_to=<Service>, relay=local, delay=0.02, delays=0.01/0.01/0/0, dsn=5.1.1, status=bounced (unknown user: "service")
May  3 11:33:26 AM004 postfix/local[3418]: 71540404F6: to=<sudo@fbr***.com>, orig_to=<sudo>, relay=local, delay=0.83, delays=0.01/0.01/0/0.81, dsn=5.1.1, status=bounced (unknown user: "sudo")
May  3 11:33:26 AM004 postfix/local[1538]: 71540404F6: to=<is@fbr***.com>, orig_to=<is>, relay=local, delay=0.88, delays=0.01/0.01/0/0.86, dsn=5.1.1, status=bounced (unknown user: "is")
May  3 11:33:26 AM004 postfix/local[6347]: 71540404F6: to=<PROBLEM@fbr***.com>, orig_to=<PROBLEM>, relay=local, delay=0.92, delays=0.01/0.01/0/0.9, dsn=5.1.1, status=bounced (unknown user: "problem")
May  3 11:33:26 AM004 postfix/local[2600]: 71540404F6: to=<CRITICAL@fbr***.com>, orig_to=<CRITICAL>, relay=local, delay=1, delays=0.01/0.01/0/0.98, dsn=5.1.1, status=bounced (unknown user: "critical")
May  3 11:33:26 AM004 postfix/local[32591]: 71540404F6: to=<Alert:L02ST31_IPC_Bosch/C: Espace@fbr***.com>, orig_to=<Alert:L02ST31_IPC_Bosch/C: Espace>, relay=local, delay=1.1, delays=0.01/0/0/1, dsn=5.1.1, status=bounced (unknown user: "alert:l02st31_ipc_bosch/c: espace")
May  3 11:33:26 AM004 postfix/local[705]: 71540404F6: to=<disque@fbr***.com>, orig_to=<disque>, relay=local, delay=1.2, delays=0.01/0.01/0/1.2, dsn=5.1.1, status=bounced (unknown user: "disque")
May  3 11:33:27 AM004 postfix/pickup[6613]: A857E43BBE: uid=500 from=<nagios>
May  3 11:33:27 AM004 postfix/cleanup[5335]: A857E43BBE: message-id=<20170503093327.A857E43BBE@AM004.fbr***.com>
May  3 11:33:27 AM004 postfix/qmgr[24201]: A857E43BBE: from=<nagios@fbr***.com>, size=523, nrcpt=9 (queue active)
May  3 11:33:27 AM004 postfix/error[4422]: A857E43BBE: to=<-s@fbr***.com>, orig_to=<-s>, relay=none, delay=0.03, delays=0.02/0/0/0.01, dsn=5.1.3, status=bounced (bad address syntax)
May  3 11:33:27 AM004 postfix/error[3741]: A857E43BBE: to=<toto@Mbout.com>, relay=none, delay=0.03, delays=0.02/0/0/0, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to fbr***.com[10.168.0.***]:25: Connection refused)
May  3 11:33:27 AM004 postfix/local[32096]: A857E43BBE: to=<UNKNOWN@fbr***.com>, orig_to=<UNKNOWN>, relay=local, delay=0.03, delays=0.02/0.01/0/0, dsn=5.1.1, status=bounced (unknown user: "unknown")
May  3 11:33:27 AM004 postfix/local[3479]: 71540404F6: to=<**@fbr***.com>, orig_to=<**>, relay=local, delay=2.4, delays=0.01/0/0/2.4, dsn=5.1.1, status=bounced (unknown user: "**")
May  3 11:33:27 AM004 postfix/cleanup[7260]: D5D5E43BC9: message-id=<20170503093327.D5D5E43BC9@AM004.fbr***.com>
May  3 11:33:27 AM004 postfix/bounce[3421]: 71540404F6: sender non-delivery notification: D5D5E43BC9
May  3 11:33:27 AM004 postfix/qmgr[24201]: D5D5E43BC9: from=<>, size=4364, nrcpt=1 (queue active)
May  3 11:33:27 AM004 postfix/local[32722]: D5D5E43BC9: to=<nagios@fbr***.com>, relay=local, delay=0.01, delays=0.01/0/0/0, dsn=2.0.0, status=sent (delivered to mailbox)
May  3 11:33:27 AM004 postfix/qmgr[24201]: D5D5E43BC9: removed
May  3 11:33:28 AM004 postfix/local[5322]: A857E43BBE: to=<Alert:L15STC30.1_Panel/UPTIME@fbr***.com>, orig_to=<Alert:L15STC30.1_Panel/UPTIME>, relay=local, delay=0.81, delays=0.02/0/0/0.79, dsn=5.1.1, status=bounced (unknown user: "alert:l15stc30.1_panel/uptime")
May  3 11:33:28 AM004 postfix/local[1506]: A857E43BBE: to=<**@fbr***.com>, orig_to=<**>, relay=local, delay=0.87, delays=0.02/0/0/0.85, dsn=5.1.1, status=bounced (unknown user: "**")
commands.cfg
# ‘notify-service-by-email’ command definition
define command{
command_name notify-service-by-email
command_line /usr/bin/printf “%b” “***** Nagios ***\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n $NOTIFICATIONCOMMENT$\n" | /usr/sbin/sendmail.postfix sudo -s " $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **” $CONTACTEMAIL$
merci pour votre aide
bonsoir,
tu peux nous ajouter ton fichier transport?
Merci de ta réponse mais j’ai désinstallé postfix et installer sSMTP à la place
