j’ai installé debian sur le disque dur WD my book live wdbacg0030hch-eesn ,L’objectif est Rendre le disque dur comme un mini-serveur
Chaque fois que je lance apt-get upgrade, je trouve l’erreur suivant :
Errors were encountered while processing:
/var/cache/apt/archives/dpkg_1.15.8.13_powerpc.deb
aussi
MyBookLive:~# apt-get update
Hit security.debian.org squeeze/updates Release.gpg
Hit ftp.fr.debian.org squeeze Release.gpg
Ign security.debian.org squeeze/updates/main Packages/DiffIndex
Ign security.debian.org squeeze/updates/contrib Packages/DiffIndex
Ign security.debian.org squeeze/updates/non-free Packages/DiffIndex
Ign security.debian.org squeeze/updates/main Sources/DiffIndex
Ign security.debian.org squeeze/updates/contrib Sources/DiffIndex
Ign security.debian.org squeeze/updates/non-free Sources/DiffIndex
Hit security.debian.org squeeze/updates/main Packages
Hit security.debian.org squeeze/updates/contrib Packages
Hit security.debian.org squeeze/updates/non-free Packages
Hit security.debian.org squeeze/updates/main Sources
Hit security.debian.org squeeze/updates/contrib Sources
Ign ftp.fr.debian.org squeeze/main Packages/DiffIndex
Hit security.debian.org squeeze/updates/non-free Sources
Ign ftp.fr.debian.org squeeze/contrib Packages/DiffIndex
Ign ftp.fr.debian.org squeeze/non-free Packages/DiffIndex
Ign ftp.fr.debian.org squeeze/main Sources/DiffIndex
Ign ftp.fr.debian.org squeeze/contrib Sources/DiffIndex
Ign ftp.fr.debian.org squeeze/non-free Sources/DiffIndex
Hit ftp.fr.debian.org squeeze/main Packages
Hit ftp.fr.debian.org squeeze/contrib Packages
Hit ftp.fr.debian.org squeeze/non-free Packages
Hit ftp.fr.debian.org squeeze/main Sources
Hit ftp.fr.debian.org squeeze/contrib Sources
Hit ftp.fr.debian.org squeeze/non-free Sources
Reading package lists… Done
MyBookLive:~# apt-get upgrade
Building dependency tree
Reading state information… Done
You might want to run `apt-get -f install’ to correct these.
The following packages have unmet dependencies:
libept1: Depends: libapt-pkg4.10
E: Unmet dependencies. Try using -f.
et quand j’ai fait apt-get -f install
Do you want to continue [Y/n]? y
Get:1 ftp.fr.debian.org squeeze/main aptitude 0.6.3-3.2+squeeze1 [3870kB]
Get:2 ftp.fr.debian.org squeeze/main apt 0.8.10.3+squeeze1 [2212kB]
Fetched 6081kB in 2s (2539kB/s)
debconf: delaying package configuration, since apt-utils is not installed
(Reading database …
dpkg: warning: files list file for package `ramlog’ missing, assuming package has no files currently installed.
(Reading database … 25587 files and directories currently installed.)
Preparing to replace aptitude 0.4.11.11-1~lenny1 (using …/aptitude_0.6.3-3.2+squeeze1_powerpc.deb) …
Unpacking replacement aptitude …
dpkg: error processing /var/cache/apt/archives/aptitude_0.6.3-3.2+squeeze1_powerpc.deb (–unpack):
trying to overwrite ‘/etc/logrotate.d/aptitude’, which is also in package wd-nas 02.50.00-101173
Processing triggers for man-db …
Des idées ?
Par avance, merci.
