Je viens de faire un apt-get remove --purge linux-image-2.6.18-6-amd64 puis un apt-get install linux-image-2.6-amd64 et il a bien installé le paquet. Je n’ose pas rebooter par contre…
Pour le du -xh / :
0 /dev
1,0K /opt
5,0K /etc/dhcp3/dhclient-enter-hooks.d
2,0K /etc/dhcp3/dhclient-exit-hooks.d
10K /etc/dhcp3
2,0K /etc/rc5.d
341K /etc/init.d
1,0K /etc/apt/sources.list.d
3,0K /etc/apt/apt.conf.d
18K /etc/apt
2,0K /etc/rcS.d
1,0K /etc/hotplug/blacklist.d
2,0K /etc/hotplug
1,0K /etc/opt
6,0K /etc/skel
2,0K /etc/rc3.d
5,0K /etc/logcheck/ignore.d.server
2,0K /etc/logcheck/violations.ignore.d
8,0K /etc/logcheck
17K /etc/python2.4
2,0K /etc/smartmontools/run.d
3,0K /etc/smartmontools
12K /etc/fail2ban/filter.d
18K /etc/fail2ban/action.d
35K /etc/fail2ban
3,0K /etc/munin/plugin-conf.d
1,0K /etc/munin/plugins
6,0K /etc/munin
1,0K /etc/postfix/sasl
58K /etc/postfix
12K /etc/zsh
1,0K /etc/initramfs-tools/scripts/nfs-top
1,0K /etc/initramfs-tools/scripts/init-bottom
1,0K /etc/initramfs-tools/scripts/local-premount
1,0K /etc/initramfs-tools/scripts/nfs-premount
1,0K /etc/initramfs-tools/scripts/local-bottom
1,0K /etc/initramfs-tools/scripts/nfs-bottom
1,0K /etc/initramfs-tools/scripts/init-premount
1,0K /etc/initramfs-tools/scripts/local-top
1,0K /etc/initramfs-tools/scripts/init-top
10K /etc/initramfs-tools/scripts
1,0K /etc/initramfs-tools/hooks
2,0K /etc/initramfs-tools/conf.d
17K /etc/initramfs-tools
21K /etc/courier
2,0K /etc/cron.hourly
3,0K /etc/emacs/site-start.d
4,0K /etc/emacs
25K /etc/default
3,0K /etc/openoffice
4,0K /etc/cron.d
2,0K /etc/dpkg/origins
7,0K /etc/dpkg
2,0K /etc/rc4.d
1,0K /etc/lsb-base
2,0K /etc/rc1.d
4,0K /etc/apm/event.d
5,0K /etc/apm
2,0K /etc/resolvconf/update-libc.d
3,0K /etc/resolvconf
2,0K /etc/calendar
2,0K /etc/bash_completion.d
2,0K /etc/modprobe.d/arch
12K /etc/modprobe.d
3,0K /etc/cron.monthly
21K /etc/cron.daily
2,0K /etc/ppp/ip-down.d
3,0K /etc/ppp/ip-up.d
6,0K /etc/ppp
2,0K /etc/rc0.d
141K /etc/ssh
3,0K /etc/udev/rules.d
1,0K /etc/udev/.dev
38K /etc/udev
7,0K /etc/console
2,0K /etc/rc2.d
2,0K /etc/ld.so.conf.d
2,0K /etc/modutils
16K /etc/security
5,0K /etc/vim
2,0K /etc/python
1,0K /etc/perl/CPAN
1,0K /etc/perl/Net
3,0K /etc/perl
1,0K /etc/network/if-post-down.d
2,0K /etc/network/run
1,0K /etc/network/if-pre-up.d
9,0K /etc/network/if-up.d
2,0K /etc/network/if-down.d
17K /etc/network
2,0K /etc/ldap
2,0K /etc/terminfo
7,0K /etc/cron.weekly
7,0K /etc/logrotate.d
3,0K /etc/groff
5,0K /etc/arno-iptables-firewall/plugins
57K /etc/arno-iptables-firewall
2,0K /etc/rc6.d
2,0K /etc/ssl/private
3,0K /etc/ssl/certs
16K /etc/ssl
20K /etc/exim
4,0K /etc/alternatives
5,0K /etc/console-tools
2,0K /etc/dictionaries-common
2,0K /etc/acpi/events
4,0K /etc/acpi
20K /etc/pam.d
1,6M /etc
4,0K /var
4,4M /bin
1,0K /srv
0 /proc
1,0K /initrd
1,0K /tmp
0 /sys
3,2M /sbin
4,0K /home
1,0K /media/cdrom0
1,0K /media/floppy0
3,0K /media
4,0K /usr
12K /lost+found
1,0K /root/.aptitude
1,0K /root/Mail
5,0K /root/.ssh
1,0K /root/.gnupg
2,0K /root/ssh
48K /root
170K /boot/grub
13M /boot
1,0K /mnt
588K /lib/modules/2.6.18-6-amd64/kernel/crypto
36K /lib/modules/2.6.18-6-amd64/kernel/sound/isa/sb
37K /lib/modules/2.6.18-6-amd64/kernel/sound/isa
28K /lib/modules/2.6.18-6-amd64/kernel/sound/pcmcia/vx
30K /lib/modules/2.6.18-6-amd64/kernel/sound/pcmcia/pdaudiocf
59K /lib/modules/2.6.18-6-amd64/kernel/sound/pcmcia
99K /lib/modules/2.6.18-6-amd64/kernel/sound/core/oss
21K /lib/modules/2.6.18-6-amd64/kernel/sound/core/seq/instr
60K /lib/modules/2.6.18-6-amd64/kernel/sound/core/seq/oss
289K /lib/modules/2.6.18-6-amd64/kernel/sound/core/seq
748K /lib/modules/2.6.18-6-amd64/kernel/sound/core
46K /lib/modules/2.6.18-6-amd64/kernel/sound/usb/usx2y
209K /lib/modules/2.6.18-6-amd64/kernel/sound/usb
887K /lib/modules/2.6.18-6-amd64/kernel/sound/oss
74K /lib/modules/2.6.18-6-amd64/kernel/sound/i2c/other
110K /lib/modules/2.6.18-6-amd64/kernel/sound/i2c
39K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/ali5451
519K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/echoaudio
177K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/rme9652
90K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/trident
209K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/ac97
219K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/ice1712
86K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/nm256
44K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/riptide
326K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/hda
60K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/ca0106
60K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/korg1212
226K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/emu10k1
118K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/cs46xx
28K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/vx222
179K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/au88x0
57K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/mixart
110K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/ymfpci
61K /lib/modules/2.6.18-6-amd64/kernel/sound/pci/pcxhr
3,4M /lib/modules/2.6.18-6-amd64/kernel/sound/pci
51K /lib/modules/2.6.18-6-amd64/kernel/sound/drivers/opl3
53K /lib/modules/2.6.18-6-amd64/kernel/sound/drivers/vx
40K /lib/modules/2.6.18-6-amd64/kernel/sound/drivers/mpu401
238K /lib/modules/2.6.18-6-amd64/kernel/sound/drivers
55K /lib/modules/2.6.18-6-amd64/kernel/sound/synth/emux
70K /lib/modules/2.6.18-6-amd64/kernel/sound/synth
5,7M /lib/modules/2.6.18-6-amd64/kernel/sound
522K /lib/modules/2.6.18-6-amd64/kernel/net/sched
56K /lib/modules/2.6.18-6-amd64/kernel/net/ipx
914K /lib/modules/2.6.18-6-amd64/kernel/net/ipv4/netfilter
254K /lib/modules/2.6.18-6-amd64/kernel/net/ipv4/ipvs
1,5M /lib/modules/2.6.18-6-amd64/kernel/net/ipv4
29K /lib/modules/2.6.18-6-amd64/kernel/net/lapb
33K /lib/modules/2.6.18-6-amd64/kernel/net/econet
58K /lib/modules/2.6.18-6-amd64/kernel/net/key
68K /lib/modules/2.6.18-6-amd64/kernel/net/appletalk
386K /lib/modules/2.6.18-6-amd64/kernel/net/netfilter
229K /lib/modules/2.6.18-6-amd64/kernel/net/bridge/netfilter
322K /lib/modules/2.6.18-6-amd64/kernel/net/bridge
224K /lib/modules/2.6.18-6-amd64/kernel/net/tipc
129K /lib/modules/2.6.18-6-amd64/kernel/net/rxrpc
103K /lib/modules/2.6.18-6-amd64/kernel/net/sunrpc/auth_gss
326K /lib/modules/2.6.18-6-amd64/kernel/net/sunrpc
12K /lib/modules/2.6.18-6-amd64/kernel/net/decnet/netfilter
143K /lib/modules/2.6.18-6-amd64/kernel/net/decnet
37K /lib/modules/2.6.18-6-amd64/kernel/net/8021q
37K /lib/modules/2.6.18-6-amd64/kernel/net/bluetooth/hidp
35K /lib/modules/2.6.18-6-amd64/kernel/net/bluetooth/bnep
41K /lib/modules/2.6.18-6-amd64/kernel/net/bluetooth/cmtp
68K /lib/modules/2.6.18-6-amd64/kernel/net/bluetooth/rfcomm
346K /lib/modules/2.6.18-6-amd64/kernel/net/bluetooth
195K /lib/modules/2.6.18-6-amd64/kernel/net/llc
209K /lib/modules/2.6.18-6-amd64/kernel/net/ipv6/netfilter
750K /lib/modules/2.6.18-6-amd64/kernel/net/ipv6
82K /lib/modules/2.6.18-6-amd64/kernel/net/netrom
48K /lib/modules/2.6.18-6-amd64/kernel/net/ieee80211/softmac
166K /lib/modules/2.6.18-6-amd64/kernel/net/ieee80211
117K /lib/modules/2.6.18-6-amd64/kernel/net/atm
30K /lib/modules/2.6.18-6-amd64/kernel/net/wanrouter
259K /lib/modules/2.6.18-6-amd64/kernel/net/sctp
119K /lib/modules/2.6.18-6-amd64/kernel/net/irda/ircomm
90K /lib/modules/2.6.18-6-amd64/kernel/net/irda/irlan
46K /lib/modules/2.6.18-6-amd64/kernel/net/irda/irnet
601K /lib/modules/2.6.18-6-amd64/kernel/net/irda
83K /lib/modules/2.6.18-6-amd64/kernel/net/rose
10K /lib/modules/2.6.18-6-amd64/kernel/net/802
99K /lib/modules/2.6.18-6-amd64/kernel/net/ax25
38K /lib/modules/2.6.18-6-amd64/kernel/net/xfrm
25K /lib/modules/2.6.18-6-amd64/kernel/net/dccp/ccids/lib
70K /lib/modules/2.6.18-6-amd64/kernel/net/dccp/ccids
252K /lib/modules/2.6.18-6-amd64/kernel/net/dccp
72K /lib/modules/2.6.18-6-amd64/kernel/net/x25
6,8M /lib/modules/2.6.18-6-amd64/kernel/net
32K /lib/modules/2.6.18-6-amd64/kernel/arch/x86_64/crypto
69K /lib/modules/2.6.18-6-amd64/kernel/arch/x86_64/oprofile
63K /lib/modules/2.6.18-6-amd64/kernel/arch/x86_64/kernel/cpufreq
113K /lib/modules/2.6.18-6-amd64/kernel/arch/x86_64/kernel
215K /lib/modules/2.6.18-6-amd64/kernel/arch/x86_64
216K /lib/modules/2.6.18-6-amd64/kernel/arch
35K /lib/modules/2.6.18-6-amd64/kernel/drivers/w1/slaves
52K /lib/modules/2.6.18-6-amd64/kernel/drivers/w1/masters
133K /lib/modules/2.6.18-6-amd64/kernel/drivers/w1
61K /lib/modules/2.6.18-6-amd64/kernel/drivers/input/keyboard
32K /lib/modules/2.6.18-6-amd64/kernel/drivers/input/misc
73K /lib/modules/2.6.18-6-amd64/kernel/drivers/input/serio
99K /lib/modules/2.6.18-6-amd64/kernel/drivers/input/mouse
76K /lib/modules/2.6.18-6-amd64/kernel/drivers/input/touchscreen
38K /lib/modules/2.6.18-6-amd64/kernel/drivers/input/joystick/iforce
394K /lib/modules/2.6.18-6-amd64/kernel/drivers/input/joystick
85K /lib/modules/2.6.18-6-amd64/kernel/drivers/input/gameport
880K /lib/modules/2.6.18-6-amd64/kernel/drivers/input
48K /lib/modules/2.6.18-6-amd64/kernel/drivers/misc/ibmasm
49K /lib/modules/2.6.18-6-amd64/kernel/drivers/misc
48K /lib/modules/2.6.18-6-amd64/kernel/drivers/serial/jsm
91K /lib/modules/2.6.18-6-amd64/kernel/drivers/serial
24K /lib/modules/2.6.18-6-amd64/kernel/drivers/base
71K /lib/modules/2.6.18-6-amd64/kernel/drivers/edac
191K /lib/modules/2.6.18-6-amd64/kernel/drivers/char/rio
109K /lib/modules/2.6.18-6-amd64/kernel/drivers/char/ip2
39K /lib/modules/2.6.18-6-amd64/kernel/drivers/char/hw_random
121K /lib/modules/2.6.18-6-amd64/kernel/drivers/char/pcmcia
694K /lib/modules/2.6.18-6-amd64/kernel/drivers/char/drm
462K /lib/modules/2.6.18-6-amd64/kernel/drivers/char/watchdog
97K /lib/modules/2.6.18-6-amd64/kernel/drivers/char/agp
208K /lib/modules/2.6.18-6-amd64/kernel/drivers/char/ipmi
57K /lib/modules/2.6.18-6-amd64/kernel/drivers/char/mwave
2,9M /lib/modules/2.6.18-6-amd64/kernel/drivers/char
488K /lib/modules/2.6.18-6-amd64/kernel/drivers/ide/pci
25K /lib/modules/2.6.18-6-amd64/kernel/drivers/ide/legacy
872K /lib/modules/2.6.18-6-amd64/kernel/drivers/ide
43K /lib/modules/2.6.18-6-amd64/kernel/drivers/block/aoe
459K /lib/modules/2.6.18-6-amd64/kernel/drivers/block/paride
1,1M /lib/modules/2.6.18-6-amd64/kernel/drivers/block
234K /lib/modules/2.6.18-6-amd64/kernel/drivers/scsi/lpfc
213K /lib/modules/2.6.18-6-amd64/kernel/drivers/scsi/qla2xxx
111K /lib/modules/2.6.18-6-amd64/kernel/drivers/scsi/sym53c8xx_2
600K /lib/modules/2.6.18-6-amd64/kernel/drivers/scsi/aic7xxx
73K /lib/modules/2.6.18-6-amd64/kernel/drivers/scsi/pcmcia
36K /lib/modules/2.6.18-6-amd64/kernel/drivers/scsi/arcmsr
99K /lib/modules/2.6.18-6-amd64/kernel/drivers/scsi/aacraid
120K /lib/modules/2.6.18-6-amd64/kernel/drivers/scsi/megaraid
4,0M /lib/modules/2.6.18-6-amd64/kernel/drivers/scsi
223K /lib/modules/2.6.18-6-amd64/kernel/drivers/video/matrox
243K /lib/modules/2.6.18-6-amd64/kernel/drivers/video/aty
51K /lib/modules/2.6.18-6-amd64/kernel/drivers/video/intelfb
18K /lib/modules/2.6.18-6-amd64/kernel/drivers/video/backlight
40K /lib/modules/2.6.18-6-amd64/kernel/drivers/video/savage
60K /lib/modules/2.6.18-6-amd64/kernel/drivers/video/nvidia
28K /lib/modules/2.6.18-6-amd64/kernel/drivers/video/kyro
301K /lib/modules/2.6.18-6-amd64/kernel/drivers/video/sis
1,3M /lib/modules/2.6.18-6-amd64/kernel/drivers/video
236K /lib/modules/2.6.18-6-amd64/kernel/drivers/pcmcia
662K /lib/modules/2.6.18-6-amd64/kernel/drivers/md
239K /lib/modules/2.6.18-6-amd64/kernel/drivers/bluetooth
70K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/chelsio
65K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/ixgb
15K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/appletalk
84K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/wireless/prism54
287K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/wireless/bcm43xx
417K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/wireless/hostap
65K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/wireless/zd1211rw
1,7M /lib/modules/2.6.18-6-amd64/kernel/drivers/net/wireless
311K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/pcmcia
67K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/myri10ge
105K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/tokenring
52K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/wan/lmc
450K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/wan
116K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/skfp
129K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/bonding
537K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/irda
169K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/e1000
170K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/arcnet
185K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/hamradio
330K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/tulip
118K /lib/modules/2.6.18-6-amd64/kernel/drivers/net/phy
7,0M /lib/modules/2.6.18-6-amd64/kernel/drivers/net
130K /lib/modules/2.6.18-6-amd64/kernel/drivers/mmc
146K /lib/modules/2.6.18-6-amd64/kernel/drivers/telephony
1,5M /lib/modules/2.6.18-6-amd64/kernel/drivers/hwmon
67K /lib/modules/2.6.18-6-amd64/kernel/drivers/firmware
363K /lib/modules/2.6.18-6-amd64/kernel/drivers/usb/input
77K /lib/modules/2.6.18-6-amd64/kernel/drivers/usb/misc/sisusbvga
411K /lib/modules/2.6.18-6-amd64/kernel/drivers/usb/misc
1,2M /lib/modules/2.6.18-6-amd64/kernel/drivers/usb/serial
195K /lib/modules/2.6.18-6-amd64/kernel/drivers/usb/host
45K /lib/modules/2.6.18-6-amd64/kernel/drivers/usb/image
57K /lib/modules/2.6.18-6-amd64/kernel/drivers/usb/class
293K /lib/modules/2.6.18-6-amd64/kernel/drivers/usb/net
160K /lib/modules/2.6.18-6-amd64/kernel/drivers/usb/atm
236K /lib/modules/2.6.18-6-amd64/kernel/drivers/usb/gadget
131K /lib/modules/2.6.18-6-amd64/kernel/drivers/usb/storage
3,1M /lib/modules/2.6.18-6-amd64/kernel/drivers/usb
841K /lib/modules/2.6.18-6-amd64/kernel/drivers/ieee1394
292K /lib/modules/2.6.18-6-amd64/kernel/drivers/rtc
92K /lib/modules/2.6.18-6-amd64/kernel/drivers/cpufreq
484K /lib/modules/2.6.18-6-amd64/kernel/drivers/atm
292K /lib/modules/2.6.18-6-amd64/kernel/drivers/message/fusion
221K /lib/modules/2.6.18-6-amd64/kernel/drivers/message/i2o
514K /lib/modules/2.6.18-6-amd64/kernel/drivers/message
407K /lib/modules/2.6.18-6-amd64/kernel/drivers/i2c/busses
56K /lib/modules/2.6.18-6-amd64/kernel/drivers/i2c/algos
127K /lib/modules/2.6.18-6-amd64/kernel/drivers/i2c/chips
649K /lib/modules/2.6.18-6-amd64/kernel/drivers/i2c
206K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/bt8xx
67K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/et61x251
43K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/ovcamchip
209K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/usbvideo
319K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/saa7134
109K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/pwc
124K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/sn9c102
47K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/cx25840
81K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/em28xx
284K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/cx88
218K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/pvrusb2
77K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/zc0301
66K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video/cpia2
3,8M /lib/modules/2.6.18-6-amd64/kernel/drivers/media/video
168K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/common
139K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/dvb/bt8xx
32K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/dvb/cinergyT2
568K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/dvb/frontends
121K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/dvb/dvb-core
80K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/dvb/b2c2
53K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/dvb/ttusb-dec
21K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/dvb/pluto2
289K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/dvb/dvb-usb
47K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/dvb/ttusb-budget
304K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/dvb/ttpci
1,7M /lib/modules/2.6.18-6-amd64/kernel/drivers/media/dvb
73K /lib/modules/2.6.18-6-amd64/kernel/drivers/media/radio
5,6M /lib/modules/2.6.18-6-amd64/kernel/drivers/media
263K /lib/modules/2.6.18-6-amd64/kernel/drivers/pci/hotplug
264K /lib/modules/2.6.18-6-amd64/kernel/drivers/pci
29K /lib/modules/2.6.18-6-amd64/kernel/drivers/spi
38K /lib/modules/2.6.18-6-amd64/kernel/drivers/leds
22K /lib/modules/2.6.18-6-amd64/kernel/drivers/dma
173K /lib/modules/2.6.18-6-amd64/kernel/drivers/isdn/capi
847K /lib/modules/2.6.18-6-amd64/kernel/drivers/isdn/hisax
230K /lib/modules/2.6.18-6-amd64/kernel/drivers/isdn/i4l
30K /lib/modules/2.6.18-6-amd64/kernel/drivers/isdn/divert
541K /lib/modules/2.6.18-6-amd64/kernel/drivers/isdn/hardware/eicon
181K /lib/modules/2.6.18-6-amd64/kernel/drivers/isdn/hardware/avm
723K /lib/modules/2.6.18-6-amd64/kernel/drivers/isdn/hardware
177K /lib/modules/2.6.18-6-amd64/kernel/drivers/isdn/gigaset
2,2M /lib/modules/2.6.18-6-amd64/kernel/drivers/isdn
191K /lib/modules/2.6.18-6-amd64/kernel/drivers/mtd/devices
137K /lib/modules/2.6.18-6-amd64/kernel/drivers/mtd/maps
225K /lib/modules/2.6.18-6-amd64/kernel/drivers/mtd/chips
25K /lib/modules/2.6.18-6-amd64/kernel/drivers/mtd/onenand
100K /lib/modules/2.6.18-6-amd64/kernel/drivers/mtd/nand
895K /lib/modules/2.6.18-6-amd64/kernel/drivers/mtd
394K /lib/modules/2.6.18-6-amd64/kernel/drivers/infiniband/core
175K /lib/modules/2.6.18-6-amd64/kernel/drivers/infiniband/hw/mthca
338K /lib/modules/2.6.18-6-amd64/kernel/drivers/infiniband/hw/ipath
514K /lib/modules/2.6.18-6-amd64/kernel/drivers/infiniband/hw
57K /lib/modules/2.6.18-6-amd64/kernel/drivers/infiniband/ulp/iser
45K /lib/modules/2.6.18-6-amd64/kernel/drivers/infiniband/ulp/srp
77K /lib/modules/2.6.18-6-amd64/kernel/drivers/infiniband/ulp/ipoib
180K /lib/modules/2.6.18-6-amd64/kernel/drivers/infiniband/ulp
1,1M /lib/modules/2.6.18-6-amd64/kernel/drivers/infiniband
409K /lib/modules/2.6.18-6-amd64/kernel/drivers/acpi
22K /lib/modules/2.6.18-6-amd64/kernel/drivers/connector
62K /lib/modules/2.6.18-6-amd64/kernel/drivers/cdrom
179K /lib/modules/2.6.18-6-amd64/kernel/drivers/parport
38M /lib/modules/2.6.18-6-amd64/kernel/drivers
62K /lib/modules/2.6.18-6-amd64/kernel/fs/affs
25K /lib/modules/2.6.18-6-amd64/kernel/fs/qnx4
334K /lib/modules/2.6.18-6-amd64/kernel/fs/cifs
292K /lib/modules/2.6.18-6-amd64/kernel/fs/ntfs
78K /lib/modules/2.6.18-6-amd64/kernel/fs/ncpfs
76K /lib/modules/2.6.18-6-amd64/kernel/fs/hfs
61K /lib/modules/2.6.18-6-amd64/kernel/fs/coda
35K /lib/modules/2.6.18-6-amd64/kernel/fs/adfs
177K /lib/modules/2.6.18-6-amd64/kernel/fs/jffs2
1020K /lib/modules/2.6.18-6-amd64/kernel/fs/nls
102K /lib/modules/2.6.18-6-amd64/kernel/fs/lockd
64K /lib/modules/2.6.18-6-amd64/kernel/fs/jffs
53K /lib/modules/2.6.18-6-amd64/kernel/fs/minix
45K /lib/modules/2.6.18-6-amd64/kernel/fs/befs
89K /lib/modules/2.6.18-6-amd64/kernel/fs/ufs
79K /lib/modules/2.6.18-6-amd64/kernel/fs/fat
108K /lib/modules/2.6.18-6-amd64/kernel/fs/udf
31K /lib/modules/2.6.18-6-amd64/kernel/fs/autofs
30K /lib/modules/2.6.18-6-amd64/kernel/fs/bfs
662K /lib/modules/2.6.18-6-amd64/kernel/fs/xfs
107K /lib/modules/2.6.18-6-amd64/kernel/fs/jbd
41K /lib/modules/2.6.18-6-amd64/kernel/fs/autofs4
117K /lib/modules/2.6.18-6-amd64/kernel/fs/9p
99K /lib/modules/2.6.18-6-amd64/kernel/fs/ext2
12K /lib/modules/2.6.18-6-amd64/kernel/fs/nfs_common
283K /lib/modules/2.6.18-6-amd64/kernel/fs/nfsd
197K /lib/modules/2.6.18-6-amd64/kernel/fs/ext3
26K /lib/modules/2.6.18-6-amd64/kernel/fs/efs
21K /lib/modules/2.6.18-6-amd64/kernel/fs/msdos
53K /lib/modules/2.6.18-6-amd64/kernel/fs/sysv
49K /lib/modules/2.6.18-6-amd64/kernel/fs/configfs
106K /lib/modules/2.6.18-6-amd64/kernel/fs/hfsplus
16K /lib/modules/2.6.18-6-amd64/kernel/fs/exportfs
130K /lib/modules/2.6.18-6-amd64/kernel/fs/ocfs2/cluster
316K /lib/modules/2.6.18-6-amd64/kernel/fs/ocfs2/dlm
986K /lib/modules/2.6.18-6-amd64/kernel/fs/ocfs2
50K /lib/modules/2.6.18-6-amd64/kernel/fs/isofs
25K /lib/modules/2.6.18-6-amd64/kernel/fs/vfat
20K /lib/modules/2.6.18-6-amd64/kernel/fs/romfs
239K /lib/modules/2.6.18-6-amd64/kernel/fs/jfs
352K /lib/modules/2.6.18-6-amd64/kernel/fs/nfs
318K /lib/modules/2.6.18-6-amd64/kernel/fs/reiserfs
92K /lib/modules/2.6.18-6-amd64/kernel/fs/smbfs
28K /lib/modules/2.6.18-6-amd64/kernel/fs/freevxfs
69K /lib/modules/2.6.18-6-amd64/kernel/fs/fuse
111K /lib/modules/2.6.18-6-amd64/kernel/fs/hpfs
102K /lib/modules/2.6.18-6-amd64/kernel/fs/afs
6,9M /lib/modules/2.6.18-6-amd64/kernel/fs
28K /lib/modules/2.6.18-6-amd64/kernel/lib/zlib_deflate
16K /lib/modules/2.6.18-6-amd64/kernel/lib/reed_solomon
101K /lib/modules/2.6.18-6-amd64/kernel/lib
58M /lib/modules/2.6.18-6-amd64/kernel
59M /lib/modules/2.6.18-6-amd64
590K /lib/modules/2.6.18-5-amd64/kernel/crypto
36K /lib/modules/2.6.18-5-amd64/kernel/sound/isa/sb
37K /lib/modules/2.6.18-5-amd64/kernel/sound/isa
28K /lib/modules/2.6.18-5-amd64/kernel/sound/pcmcia/vx
30K /lib/modules/2.6.18-5-amd64/kernel/sound/pcmcia/pdaudiocf
59K /lib/modules/2.6.18-5-amd64/kernel/sound/pcmcia
99K /lib/modules/2.6.18-5-amd64/kernel/sound/core/oss
21K /lib/modules/2.6.18-5-amd64/kernel/sound/core/seq/instr
60K /lib/modules/2.6.18-5-amd64/kernel/sound/core/seq/oss
289K /lib/modules/2.6.18-5-amd64/kernel/sound/core/seq
747K /lib/modules/2.6.18-5-amd64/kernel/sound/core
46K /lib/modules/2.6.18-5-amd64/kernel/sound/usb/usx2y
209K /lib/modules/2.6.18-5-amd64/kernel/sound/usb
889K /lib/modules/2.6.18-5-amd64/kernel/sound/oss
74K /lib/modules/2.6.18-5-amd64/kernel/sound/i2c/other
110K /lib/modules/2.6.18-5-amd64/kernel/sound/i2c
39K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/ali5451
519K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/echoaudio
177K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/rme9652
90K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/trident
209K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/ac97
219K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/ice1712
86K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/nm256
44K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/riptide
326K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/hda
60K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/ca0106
60K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/korg1212
226K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/emu10k1
118K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/cs46xx
28K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/vx222
179K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/au88x0
57K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/mixart
110K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/ymfpci
61K /lib/modules/2.6.18-5-amd64/kernel/sound/pci/pcxhr
3,4M /lib/modules/2.6.18-5-amd64/kernel/sound/pci
51K /lib/modules/2.6.18-5-amd64/kernel/sound/drivers/opl3
53K /lib/modules/2.6.18-5-amd64/kernel/sound/drivers/vx
40K /lib/modules/2.6.18-5-amd64/kernel/sound/drivers/mpu401
238K /lib/modules/2.6.18-5-amd64/kernel/sound/drivers
55K /lib/modules/2.6.18-5-amd64/kernel/sound/synth/emux
70K /lib/modules/2.6.18-5-amd64/kernel/sound/synth
5,7M /lib/modules/2.6.18-5-amd64/kernel/sound
522K /lib/modules/2.6.18-5-amd64/kernel/net/sched
56K /lib/modules/2.6.18-5-amd64/kernel/net/ipx
914K /lib/modules/2.6.18-5-amd64/kernel/net/ipv4/netfilter
254K /lib/modules/2.6.18-5-amd64/kernel/net/ipv4/ipvs
1,5M /lib/modules/2.6.18-5-amd64/kernel/net/ipv4
29K /lib/modules/2.6.18-5-amd64/kernel/net/lapb
33K /lib/modules/2.6.18-5-amd64/kernel/net/econet
58K /lib/modules/2.6.18-5-amd64/kernel/net/key
68K /lib/modules/2.6.18-5-amd64/kernel/net/appletalk
386K /lib/modules/2.6.18-5-amd64/kernel/net/netfilter
229K /lib/modules/2.6.18-5-amd64/kernel/net/bridge/netfilter
322K /lib/modules/2.6.18-5-amd64/kernel/net/bridge
224K /lib/modules/2.6.18-5-amd64/kernel/net/tipc
129K /lib/modules/2.6.18-5-amd64/kernel/net/rxrpc
103K /lib/modules/2.6.18-5-amd64/kernel/net/sunrpc/auth_gss
326K /lib/modules/2.6.18-5-amd64/kernel/net/sunrpc
12K /lib/modules/2.6.18-5-amd64/kernel/net/decnet/netfilter
143K /lib/modules/2.6.18-5-amd64/kernel/net/decnet
37K /lib/modules/2.6.18-5-amd64/kernel/net/8021q
37K /lib/modules/2.6.18-5-amd64/kernel/net/bluetooth/hidp
35K /lib/modules/2.6.18-5-amd64/kernel/net/bluetooth/bnep
41K /lib/modules/2.6.18-5-amd64/kernel/net/bluetooth/cmtp
68K /lib/modules/2.6.18-5-amd64/kernel/net/bluetooth/rfcomm
346K /lib/modules/2.6.18-5-amd64/kernel/net/bluetooth
195K /lib/modules/2.6.18-5-amd64/kernel/net/llc
209K /lib/modules/2.6.18-5-amd64/kernel/net/ipv6/netfilter
750K /lib/modules/2.6.18-5-amd64/kernel/net/ipv6
82K /lib/modules/2.6.18-5-amd64/kernel/net/netrom
48K /lib/modules/2.6.18-5-amd64/kernel/net/ieee80211/softmac
166K /lib/modules/2.6.18-5-amd64/kernel/net/ieee80211
117K /lib/modules/2.6.18-5-amd64/kernel/net/atm
30K /lib/modules/2.6.18-5-amd64/kernel/net/wanrouter
259K /lib/modules/2.6.18-5-amd64/kernel/net/sctp
119K /lib/modules/2.6.18-5-amd64/kernel/net/irda/ircomm
90K /lib/modules/2.6.18-5-amd64/kernel/net/irda/irlan
46K /lib/modules/2.6.18-5-amd64/kernel/net/irda/irnet
601K /lib/modules/2.6.18-5-amd64/kernel/net/irda
83K /lib/modules/2.6.18-5-amd64/kernel/net/rose
10K /lib/modules/2.6.18-5-amd64/kernel/net/802
99K /lib/modules/2.6.18-5-amd64/kernel/net/ax25
38K /lib/modules/2.6.18-5-amd64/kernel/net/xfrm
25K /lib/modules/2.6.18-5-amd64/kernel/net/dccp/ccids/lib
70K /lib/modules/2.6.18-5-amd64/kernel/net/dccp/ccids
252K /lib/modules/2.6.18-5-amd64/kernel/net/dccp
72K /lib/modules/2.6.18-5-amd64/kernel/net/x25
6,8M /lib/modules/2.6.18-5-amd64/kernel/net
32K /lib/modules/2.6.18-5-amd64/kernel/arch/x86_64/crypto
69K /lib/modules/2.6.18-5-amd64/kernel/arch/x86_64/oprofile
63K /lib/modules/2.6.18-5-amd64/kernel/arch/x86_64/kernel/cpufreq
113K /lib/modules/2.6.18-5-amd64/kernel/arch/x86_64/kernel
215K /lib/modules/2.6.18-5-amd64/kernel/arch/x86_64
216K /lib/modules/2.6.18-5-amd64/kernel/arch
35K /lib/modules/2.6.18-5-amd64/kernel/drivers/w1/slaves
52K /lib/modules/2.6.18-5-amd64/kernel/drivers/w1/masters
133K /lib/modules/2.6.18-5-amd64/kernel/drivers/w1
61K /lib/modules/2.6.18-5-amd64/kernel/drivers/input/keyboard
32K /lib/modules/2.6.18-5-amd64/kernel/drivers/input/misc
73K /lib/modules/2.6.18-5-amd64/kernel/drivers/input/serio
99K /lib/modules/2.6.18-5-amd64/kernel/drivers/input/mouse
76K /lib/modules/2.6.18-5-amd64/kernel/drivers/input/touchscreen
38K /lib/modules/2.6.18-5-amd64/kernel/drivers/input/joystick/iforce
394K /lib/modules/2.6.18-5-amd64/kernel/drivers/input/joystick
85K /lib/modules/2.6.18-5-amd64/kernel/drivers/input/gameport
880K /lib/modules/2.6.18-5-amd64/kernel/drivers/input
48K /lib/modules/2.6.18-5-amd64/kernel/drivers/misc/ibmasm
49K /lib/modules/2.6.18-5-amd64/kernel/drivers/misc
48K /lib/modules/2.6.18-5-amd64/kernel/drivers/serial/jsm
91K /lib/modules/2.6.18-5-amd64/kernel/drivers/serial
24K /lib/modules/2.6.18-5-amd64/kernel/drivers/base
71K /lib/modules/2.6.18-5-amd64/kernel/drivers/edac
191K /lib/modules/2.6.18-5-amd64/kernel/drivers/char/rio
109K /lib/modules/2.6.18-5-amd64/kernel/drivers/char/ip2
39K /lib/modules/2.6.18-5-amd64/kernel/drivers/char/hw_random
121K /lib/modules/2.6.18-5-amd64/kernel/drivers/char/pcmcia
694K /lib/modules/2.6.18-5-amd64/kernel/drivers/char/drm
462K /lib/modules/2.6.18-5-amd64/kernel/drivers/char/watchdog
97K /lib/modules/2.6.18-5-amd64/kernel/drivers/char/agp
208K /lib/modules/2.6.18-5-amd64/kernel/drivers/char/ipmi
57K /lib/modules/2.6.18-5-amd64/kernel/drivers/char/mwave
2,9M /lib/modules/2.6.18-5-amd64/kernel/drivers/char
488K /lib/modules/2.6.18-5-amd64/kernel/drivers/ide/pci
25K /lib/modules/2.6.18-5-amd64/kernel/drivers/ide/legacy
872K /lib/modules/2.6.18-5-amd64/kernel/drivers/ide
43K /lib/modules/2.6.18-5-amd64/kernel/drivers/block/aoe
459K /lib/modules/2.6.18-5-amd64/kernel/drivers/block/paride
1,1M /lib/modules/2.6.18-5-amd64/kernel/drivers/block
234K /lib/modules/2.6.18-5-amd64/kernel/drivers/scsi/lpfc
213K /lib/modules/2.6.18-5-amd64/kernel/drivers/scsi/qla2xxx
111K /lib/modules/2.6.18-5-amd64/kernel/drivers/scsi/sym53c8xx_2
600K /lib/modules/2.6.18-5-amd64/kernel/drivers/scsi/aic7xxx
73K /lib/modules/2.6.18-5-amd64/kernel/drivers/scsi/pcmcia
36K /lib/modules/2.6.18-5-amd64/kernel/drivers/scsi/arcmsr
99K /lib/modules/2.6.18-5-amd64/kernel/drivers/scsi/aacraid
120K /lib/modules/2.6.18-5-amd64/kernel/drivers/scsi/megaraid
4,0M /lib/modules/2.6.18-5-amd64/kernel/drivers/scsi
223K /lib/modules/2.6.18-5-amd64/kernel/drivers/video/matrox
243K /lib/modules/2.6.18-5-amd64/kernel/drivers/video/aty
51K /lib/modules/2.6.18-5-amd64/kernel/drivers/video/intelfb
18K /lib/modules/2.6.18-5-amd64/kernel/drivers/video/backlight
40K /lib/modules/2.6.18-5-amd64/kernel/drivers/video/savage
60K /lib/modules/2.6.18-5-amd64/kernel/drivers/video/nvidia
28K /lib/modules/2.6.18-5-amd64/kernel/drivers/video/kyro
301K /lib/modules/2.6.18-5-amd64/kernel/drivers/video/sis
1,3M /lib/modules/2.6.18-5-amd64/kernel/drivers/video
236K /lib/modules/2.6.18-5-amd64/kernel/drivers/pcmcia
662K /lib/modules/2.6.18-5-amd64/kernel/drivers/md
239K /lib/modules/2.6.18-5-amd64/kernel/drivers/bluetooth
70K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/chelsio
65K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/ixgb
15K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/appletalk
84K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/wireless/prism54
287K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/wireless/bcm43xx
417K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/wireless/hostap
65K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/wireless/zd1211rw
1,7M /lib/modules/2.6.18-5-amd64/kernel/drivers/net/wireless
311K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/pcmcia
67K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/myri10ge
105K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/tokenring
52K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/wan/lmc
450K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/wan
116K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/skfp
129K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/bonding
537K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/irda
169K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/e1000
170K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/arcnet
185K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/hamradio
330K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/tulip
118K /lib/modules/2.6.18-5-amd64/kernel/drivers/net/phy
7,0M /lib/modules/2.6.18-5-amd64/kernel/drivers/net
130K /lib/modules/2.6.18-5-amd64/kernel/drivers/mmc
146K /lib/modules/2.6.18-5-amd64/kernel/drivers/telephony
1,5M /lib/modules/2.6.18-5-amd64/kernel/drivers/hwmon
67K /lib/modules/2.6.18-5-amd64/kernel/drivers/firmware
363K /lib/modules/2.6.18-5-amd64/kernel/drivers/usb/input
77K /lib/modules/2.6.18-5-amd64/kernel/drivers/usb/misc/sisusbvga
411K /lib/modules/2.6.18-5-amd64/kernel/drivers/usb/misc
1,2M /lib/modules/2.6.18-5-amd64/kernel/drivers/usb/serial
195K /lib/modules/2.6.18-5-amd64/kernel/drivers/usb/host
45K /lib/modules/2.6.18-5-amd64/kernel/drivers/usb/image
57K /lib/modules/2.6.18-5-amd64/kernel/drivers/usb/class
293K /lib/modules/2.6.18-5-amd64/kernel/drivers/usb/net
160K /lib/modules/2.6.18-5-amd64/kernel/drivers/usb/atm
236K /lib/modules/2.6.18-5-amd64/kernel/drivers/usb/gadget
131K /lib/modules/2.6.18-5-amd64/kernel/drivers/usb/storage
3,1M /lib/modules/2.6.18-5-amd64/kernel/drivers/usb
841K /lib/modules/2.6.18-5-amd64/kernel/drivers/ieee1394
292K /lib/modules/2.6.18-5-amd64/kernel/drivers/rtc
92K /lib/modules/2.6.18-5-amd64/kernel/drivers/cpufreq
484K /lib/modules/2.6.18-5-amd64/kernel/drivers/atm
292K /lib/modules/2.6.18-5-amd64/kernel/drivers/message/fusion
221K /lib/modules/2.6.18-5-amd64/kernel/drivers/message/i2o
514K /lib/modules/2.6.18-5-amd64/kernel/drivers/message
407K /lib/modules/2.6.18-5-amd64/kernel/drivers/i2c/busses
56K /lib/modules/2.6.18-5-amd64/kernel/drivers/i2c/algos
127K /lib/modules/2.6.18-5-amd64/kernel/drivers/i2c/chips
649K /lib/modules/2.6.18-5-amd64/kernel/drivers/i2c
206K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/bt8xx
67K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/et61x251
43K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/ovcamchip
209K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/usbvideo
319K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/saa7134
109K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/pwc
124K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/sn9c102
47K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/cx25840
81K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/em28xx
284K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/cx88
218K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/pvrusb2
77K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/zc0301
66K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video/cpia2
3,8M /lib/modules/2.6.18-5-amd64/kernel/drivers/media/video
168K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/common
139K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/dvb/bt8xx
32K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/dvb/cinergyT2
568K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/dvb/frontends
121K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/dvb/dvb-core
80K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/dvb/b2c2
53K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/dvb/ttusb-dec
21K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/dvb/pluto2
289K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/dvb/dvb-usb
47K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/dvb/ttusb-budget
304K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/dvb/ttpci
1,7M /lib/modules/2.6.18-5-amd64/kernel/drivers/media/dvb
73K /lib/modules/2.6.18-5-amd64/kernel/drivers/media/radio
5,6M /lib/modules/2.6.18-5-amd64/kernel/drivers/media
263K /lib/modules/2.6.18-5-amd64/kernel/drivers/pci/hotplug
264K /lib/modules/2.6.18-5-amd64/kernel/drivers/pci
29K /lib/modules/2.6.18-5-amd64/kernel/drivers/spi
38K /lib/modules/2.6.18-5-amd64/kernel/drivers/leds
22K /lib/modules/2.6.18-5-amd64/kernel/drivers/dma
173K /lib/modules/2.6.18-5-amd64/kernel/drivers/isdn/capi
847K /lib/modules/2.6.18-5-amd64/kernel/drivers/isdn/hisax
229K /lib/modules/2.6.18-5-amd64/kernel/drivers/isdn/i4l
30K /lib/modules/2.6.18-5-amd64/kernel/drivers/isdn/divert
541K /lib/modules/2.6.18-5-amd64/kernel/drivers/isdn/hardware/eicon
181K /lib/modules/2.6.18-5-amd64/kernel/drivers/isdn/hardware/avm
723K /lib/modules/2.6.18-5-amd64/kernel/drivers/isdn/hardware
177K /lib/modules/2.6.18-5-amd64/kernel/drivers/isdn/gigaset
2,2M /lib/modules/2.6.18-5-amd64/kernel/drivers/isdn
191K /lib/modules/2.6.18-5-amd64/kernel/drivers/mtd/devices
137K /lib/modules/2.6.18-5-amd64/kernel/drivers/mtd/maps
225K /lib/modules/2.6.18-5-amd64/kernel/drivers/mtd/chips
25K /lib/modules/2.6.18-5-amd64/kernel/drivers/mtd/onenand
100K /lib/modules/2.6.18-5-amd64/kernel/drivers/mtd/nand
895K /lib/modules/2.6.18-5-amd64/kernel/drivers/mtd
394K /lib/modules/2.6.18-5-amd64/kernel/drivers/infiniband/core
175K /lib/modules/2.6.18-5-amd64/kernel/drivers/infiniband/hw/mthca
338K /lib/modules/2.6.18-5-amd64/kernel/drivers/infiniband/hw/ipath
514K /lib/modules/2.6.18-5-amd64/kernel/drivers/infiniband/hw
57K /lib/modules/2.6.18-5-amd64/kernel/drivers/infiniband/ulp/iser
45K /lib/modules/2.6.18-5-amd64/kernel/drivers/infiniband/ulp/srp
77K /lib/modules/2.6.18-5-amd64/kernel/drivers/infiniband/ulp/ipoib
180K /lib/modules/2.6.18-5-amd64/kernel/drivers/infiniband/ulp
1,1M /lib/modules/2.6.18-5-amd64/kernel/drivers/infiniband
409K /lib/modules/2.6.18-5-amd64/kernel/drivers/acpi
22K /lib/modules/2.6.18-5-amd64/kernel/drivers/connector
62K /lib/modules/2.6.18-5-amd64/kernel/drivers/cdrom
179K /lib/modules/2.6.18-5-amd64/kernel/drivers/parport
38M /lib/modules/2.6.18-5-amd64/kernel/drivers
62K /lib/modules/2.6.18-5-amd64/kernel/fs/affs
25K /lib/modules/2.6.18-5-amd64/kernel/fs/qnx4
334K /lib/modules/2.6.18-5-amd64/kernel/fs/cifs
292K /lib/modules/2.6.18-5-amd64/kernel/fs/ntfs
78K /lib/modules/2.6.18-5-amd64/kernel/fs/ncpfs
76K /lib/modules/2.6.18-5-amd64/kernel/fs/hfs
61K /lib/modules/2.6.18-5-amd64/kernel/fs/coda
35K /lib/modules/2.6.18-5-amd64/kernel/fs/adfs
177K /lib/modules/2.6.18-5-amd64/kernel/fs/jffs2
1,0M /lib/modules/2.6.18-5-amd64/kernel/fs/nls
102K /lib/modules/2.6.18-5-amd64/kernel/fs/lockd
64K /lib/modules/2.6.18-5-amd64/kernel/fs/jffs
53K /lib/modules/2.6.18-5-amd64/kernel/fs/minix
45K /lib/modules/2.6.18-5-amd64/kernel/fs/befs
89K /lib/modules/2.6.18-5-amd64/kernel/fs/ufs
78K /lib/modules/2.6.18-5-amd64/kernel/fs/fat
108K /lib/modules/2.6.18-5-amd64/kernel/fs/udf
31K /lib/modules/2.6.18-5-amd64/kernel/fs/autofs
30K /lib/modules/2.6.18-5-amd64/kernel/fs/bfs
662K /lib/modules/2.6.18-5-amd64/kernel/fs/xfs
107K /lib/modules/2.6.18-5-amd64/kernel/fs/jbd
41K /lib/modules/2.6.18-5-amd64/kernel/fs/autofs4
117K /lib/modules/2.6.18-5-amd64/kernel/fs/9p
99K /lib/modules/2.6.18-5-amd64/kernel/fs/ext2
12K /lib/modules/2.6.18-5-amd64/kernel/fs/nfs_common
283K /lib/modules/2.6.18-5-amd64/kernel/fs/nfsd
197K /lib/modules/2.6.18-5-amd64/kernel/fs/ext3
26K /lib/modules/2.6.18-5-amd64/kernel/fs/efs
21K /lib/modules/2.6.18-5-amd64/kernel/fs/msdos
53K /lib/modules/2.6.18-5-amd64/kernel/fs/sysv
49K /lib/modules/2.6.18-5-amd64/kernel/fs/configfs
106K /lib/modules/2.6.18-5-amd64/kernel/fs/hfsplus
16K /lib/modules/2.6.18-5-amd64/kernel/fs/exportfs
130K /lib/modules/2.6.18-5-amd64/kernel/fs/ocfs2/cluster
316K /lib/modules/2.6.18-5-amd64/kernel/fs/ocfs2/dlm
986K /lib/modules/2.6.18-5-amd64/kernel/fs/ocfs2
50K /lib/modules/2.6.18-5-amd64/kernel/fs/isofs
25K /lib/modules/2.6.18-5-amd64/kernel/fs/vfat
20K /lib/modules/2.6.18-5-amd64/kernel/fs/romfs
239K /lib/modules/2.6.18-5-amd64/kernel/fs/jfs
352K /lib/modules/2.6.18-5-amd64/kernel/fs/nfs
318K /lib/modules/2.6.18-5-amd64/kernel/fs/reiserfs
92K /lib/modules/2.6.18-5-amd64/kernel/fs/smbfs
28K /lib/modules/2.6.18-5-amd64/kernel/fs/freevxfs
69K /lib/modules/2.6.18-5-amd64/kernel/fs/fuse
111K /lib/modules/2.6.18-5-amd64/kernel/fs/hpfs
102K /lib/modules/2.6.18-5-amd64/kernel/fs/afs
6,9M /lib/modules/2.6.18-5-amd64/kernel/fs
28K /lib/modules/2.6.18-5-amd64/kernel/lib/zlib_deflate
16K /lib/modules/2.6.18-5-amd64/kernel/lib/reed_solomon
101K /lib/modules/2.6.18-5-amd64/kernel/lib
58M /lib/modules/2.6.18-5-amd64/kernel
59M /lib/modules/2.6.18-5-amd64
590K /lib/modules/2.6.18-4-amd64/kernel/crypto
36K /lib/modules/2.6.18-4-amd64/kernel/sound/isa/sb
37K /lib/modules/2.6.18-4-amd64/kernel/sound/isa
28K /lib/modules/2.6.18-4-amd64/kernel/sound/pcmcia/vx
30K /lib/modules/2.6.18-4-amd64/kernel/sound/pcmcia/pdaudiocf
59K /lib/modules/2.6.18-4-amd64/kernel/sound/pcmcia
99K /lib/modules/2.6.18-4-amd64/kernel/sound/core/oss
21K /lib/modules/2.6.18-4-amd64/kernel/sound/core/seq/instr
60K /lib/modules/2.6.18-4-amd64/kernel/sound/core/seq/oss
289K /lib/modules/2.6.18-4-amd64/kernel/sound/core/seq
747K /lib/modules/2.6.18-4-amd64/kernel/sound/core
46K /lib/modules/2.6.18-4-amd64/kernel/sound/usb/usx2y
209K /lib/modules/2.6.18-4-amd64/kernel/sound/usb
889K /lib/modules/2.6.18-4-amd64/kernel/sound/oss
74K /lib/modules/2.6.18-4-amd64/kernel/sound/i2c/other
110K /lib/modules/2.6.18-4-amd64/kernel/sound/i2c
39K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/ali5451
519K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/echoaudio
177K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/rme9652
90K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/trident
209K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/ac97
219K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/ice1712
86K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/nm256
44K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/riptide
326K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/hda
60K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/ca0106
60K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/korg1212
226K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/emu10k1
118K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/cs46xx
28K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/vx222
179K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/au88x0
57K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/mixart
110K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/ymfpci
61K /lib/modules/2.6.18-4-amd64/kernel/sound/pci/pcxhr
3,4M /lib/modules/2.6.18-4-amd64/kernel/sound/pci
51K /lib/modules/2.6.18-4-amd64/kernel/sound/drivers/opl3
53K /lib/modules/2.6.18-4-amd64/kernel/sound/drivers/vx
40K /lib/modules/2.6.18-4-amd64/kernel/sound/drivers/mpu401
238K /lib/modules/2.6.18-4-amd64/kernel/sound/drivers
55K /lib/modules/2.6.18-4-amd64/kernel/sound/synth/emux
70K /lib/modules/2.6.18-4-amd64/kernel/sound/synth
5,7M /lib/modules/2.6.18-4-amd64/kernel/sound
522K /lib/modules/2.6.18-4-amd64/kernel/net/sched
56K /lib/modules/2.6.18-4-amd64/kernel/net/ipx
914K /lib/modules/2.6.18-4-amd64/kernel/net/ipv4/netfilter
254K /lib/modules/2.6.18-4-amd64/kernel/net/ipv4/ipvs
1,5M /lib/modules/2.6.18-4-amd64/kernel/net/ipv4
29K /lib/modules/2.6.18-4-amd64/kernel/net/lapb
33K /lib/modules/2.6.18-4-amd64/kernel/net/econet
58K /lib/modules/2.6.18-4-amd64/kernel/net/key
68K /lib/modules/2.6.18-4-amd64/kernel/net/appletalk
386K /lib/modules/2.6.18-4-amd64/kernel/net/netfilter
229K /lib/modules/2.6.18-4-amd64/kernel/net/bridge/netfilter
322K /lib/modules/2.6.18-4-amd64/kernel/net/bridge
224K /lib/modules/2.6.18-4-amd64/kernel/net/tipc
129K /lib/modules/2.6.18-4-amd64/kernel/net/rxrpc
103K /lib/modules/2.6.18-4-amd64/kernel/net/sunrpc/auth_gss
326K /lib/modules/2.6.18-4-amd64/kernel/net/sunrpc
12K /lib/modules/2.6.18-4-amd64/kernel/net/decnet/netfilter
143K /lib/modules/2.6.18-4-amd64/kernel/net/decnet
37K /lib/modules/2.6.18-4-amd64/kernel/net/8021q
37K /lib/modules/2.6.18-4-amd64/kernel/net/bluetooth/hidp
35K /lib/modules/2.6.18-4-amd64/kernel/net/bluetooth/bnep
41K /lib/modules/2.6.18-4-amd64/kernel/net/bluetooth/cmtp
68K /lib/modules/2.6.18-4-amd64/kernel/net/bluetooth/rfcomm
346K /lib/modules/2.6.18-4-amd64/kernel/net/bluetooth
195K /lib/modules/2.6.18-4-amd64/kernel/net/llc
209K /lib/modules/2.6.18-4-amd64/kernel/net/ipv6/netfilter
750K /lib/modules/2.6.18-4-amd64/kernel/net/ipv6
82K /lib/modules/2.6.18-4-amd64/kernel/net/netrom
48K /lib/modules/2.6.18-4-amd64/kernel/net/ieee80211/softmac
166K /lib/modules/2.6.18-4-amd64/kernel/net/ieee80211
117K /lib/modules/2.6.18-4-amd64/kernel/net/atm
30K /lib/modules/2.6.18-4-amd64/kernel/net/wanrouter
259K /lib/modules/2.6.18-4-amd64/kernel/net/sctp
119K /lib/modules/2.6.18-4-amd64/kernel/net/irda/ircomm
90K /lib/modules/2.6.18-4-amd64/kernel/net/irda/irlan
46K /lib/modules/2.6.18-4-amd64/kernel/net/irda/irnet
601K /lib/modules/2.6.18-4-amd64/kernel/net/irda
83K /lib/modules/2.6.18-4-amd64/kernel/net/rose
10K /lib/modules/2.6.18-4-amd64/kernel/net/802
99K /lib/modules/2.6.18-4-amd64/kernel/net/ax25
38K /lib/modules/2.6.18-4-amd64/kernel/net/xfrm
25K /lib/modules/2.6.18-4-amd64/kernel/net/dccp/ccids/lib
70K /lib/modules/2.6.18-4-amd64/kernel/net/dccp/ccids
252K /lib/modules/2.6.18-4-amd64/kernel/net/dccp
72K /lib/modules/2.6.18-4-amd64/kernel/net/x25
6,8M /lib/modules/2.6.18-4-amd64/kernel/net
32K /lib/modules/2.6.18-4-amd64/kernel/arch/x86_64/crypto
69K /lib/modules/2.6.18-4-amd64/kernel/arch/x86_64/oprofile
63K /lib/modules/2.6.18-4-amd64/kernel/arch/x86_64/kernel/cpufreq
113K /lib/modules/2.6.18-4-amd64/kernel/arch/x86_64/kernel
215K /lib/modules/2.6.18-4-amd64/kernel/arch/x86_64
216K /lib/modules/2.6.18-4-amd64/kernel/arch
35K /lib/modules/2.6.18-4-amd64/kernel/drivers/w1/slaves
52K /lib/modules/2.6.18-4-amd64/kernel/drivers/w1/masters
133K /lib/modules/2.6.18-4-amd64/kernel/drivers/w1
61K /lib/modules/2.6.18-4-amd64/kernel/drivers/input/keyboard
32K /lib/modules/2.6.18-4-amd64/kernel/drivers/input/misc
73K /lib/modules/2.6.18-4-amd64/kernel/drivers/input/serio
99K /lib/modules/2.6.18-4-amd64/kernel/drivers/input/mouse
76K /lib/modules/2.6.18-4-amd64/kernel/drivers/input/touchscreen
38K /lib/modules/2.6.18-4-amd64/kernel/drivers/input/joystick/iforce
394K /lib/modules/2.6.18-4-amd64/kernel/drivers/input/joystick
85K /lib/modules/2.6.18-4-amd64/kernel/drivers/input/gameport
880K /lib/modules/2.6.18-4-amd64/kernel/drivers/input
48K /lib/modules/2.6.18-4-amd64/kernel/drivers/misc/ibmasm
49K /lib/modules/2.6.18-4-amd64/kernel/drivers/misc
48K /lib/modules/2.6.18-4-amd64/kernel/drivers/serial/jsm
91K /lib/modules/2.6.18-4-amd64/kernel/drivers/serial
24K /lib/modules/2.6.18-4-amd64/kernel/drivers/base
71K /lib/modules/2.6.18-4-amd64/kernel/drivers/edac
191K /lib/modules/2.6.18-4-amd64/kernel/drivers/char/rio
109K /lib/modules/2.6.18-4-amd64/kernel/drivers/char/ip2
39K /lib/modules/2.6.18-4-amd64/kernel/drivers/char/hw_random
121K /lib/modules/2.6.18-4-amd64/kernel/drivers/char/pcmcia
694K /lib/modules/2.6.18-4-amd64/kernel/drivers/char/drm
462K /lib/modules/2.6.18-4-amd64/kernel/drivers/char/watchdog
95K /lib/modules/2.6.18-4-amd64/kernel/drivers/char/agp
208K /lib/modules/2.6.18-4-amd64/kernel/drivers/char/ipmi
57K /lib/modules/2.6.18-4-amd64/kernel/drivers/char/mwave
2,9M /lib/modules/2.6.18-4-amd64/kernel/drivers/char
490K /lib/modules/2.6.18-4-amd64/kernel/drivers/ide/pci
25K /lib/modules/2.6.18-4-amd64/kernel/drivers/ide/legacy
874K /lib/modules/2.6.18-4-amd64/kernel/drivers/ide
43K /lib/modules/2.6.18-4-amd64/kernel/drivers/block/aoe
459K /lib/modules/2.6.18-4-amd64/kernel/drivers/block/paride
1,1M /lib/modules/2.6.18-4-amd64/kernel/drivers/block
234K /lib/modules/2.6.18-4-amd64/kernel/drivers/scsi/lpfc
213K /lib/modules/2.6.18-4-amd64/kernel/drivers/scsi/qla2xxx
111K /lib/modules/2.6.18-4-amd64/kernel/drivers/scsi/sym53c8xx_2
600K /lib/modules/2.6.18-4-amd64/kernel/drivers/scsi/aic7xxx
73K /lib/modules/2.6.18-4-amd64/kernel/drivers/scsi/pcmcia
36K /lib/modules/2.6.18-4-amd64/kernel/drivers/scsi/arcmsr
99K /lib/modules/2.6.18-4-amd64/kernel/drivers/scsi/aacraid
120K /lib/modules/2.6.18-4-amd64/kernel/drivers/scsi/megaraid
4,0M /lib/modules/2.6.18-4-amd64/kernel/drivers/scsi
223K /lib/modules/2.6.18-4-amd64/kernel/drivers/video/matrox
243K /lib/modules/2.6.18-4-amd64/kernel/drivers/video/aty
51K /lib/modules/2.6.18-4-amd64/kernel/drivers/video/intelfb
18K /lib/modules/2.6.18-4-amd64/kernel/drivers/video/backlight
40K /lib/modules/2.6.18-4-amd64/kernel/drivers/video/savage
60K /lib/modules/2.6.18-4-amd64/kernel/drivers/video/nvidia
28K /lib/modules/2.6.18-4-amd64/kernel/drivers/video/kyro
301K /lib/modules/2.6.18-4-amd64/kernel/drivers/video/sis
1,3M /lib/modules/2.6.18-4-amd64/kernel/drivers/video
236K /lib/modules/2.6.18-4-amd64/kernel/drivers/pcmcia
662K /lib/modules/2.6.18-4-amd64/kernel/drivers/md
239K /lib/modules/2.6.18-4-amd64/kernel/drivers/bluetooth
70K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/chelsio
65K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/ixgb
15K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/appletalk
84K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/wireless/prism54
287K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/wireless/bcm43xx
417K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/wireless/hostap
65K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/wireless/zd1211rw
1,7M /lib/modules/2.6.18-4-amd64/kernel/drivers/net/wireless
311K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/pcmcia
67K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/myri10ge
105K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/tokenring
52K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/wan/lmc
450K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/wan
116K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/skfp
129K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/bonding
537K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/irda
169K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/e1000
170K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/arcnet
185K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/hamradio
330K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/tulip
118K /lib/modules/2.6.18-4-amd64/kernel/drivers/net/phy
7,0M /lib/modules/2.6.18-4-amd64/kernel/drivers/net
130K /lib/modules/2.6.18-4-amd64/kernel/drivers/mmc
146K /lib/modules/2.6.18-4-amd64/kernel/drivers/telephony
1,4M /lib/modules/2.6.18-4-amd64/kernel/drivers/hwmon
67K /lib/modules/2.6.18-4-amd64/kernel/drivers/firmware
363K /lib/modules/2.6.18-4-amd64/kernel/drivers/usb/input
77K /lib/modules/2.6.18-4-amd64/kernel/drivers/usb/misc/sisusbvga
410K /lib/modules/2.6.18-4-amd64/kernel/drivers/usb/misc
1,2M /lib/modules/2.6.18-4-amd64/kernel/drivers/usb/serial
195K /lib/modules/2.6.18-4-amd64/kernel/drivers/usb/host
45K /lib/modules/2.6.18-4-amd64/kernel/drivers/usb/image
57K /lib/modules/2.6.18-4-amd64/kernel/drivers/usb/class
293K /lib/modules/2.6.18-4-amd64/kernel/drivers/usb/net
160K /lib/modules/2.6.18-4-amd64/kernel/drivers/usb/atm
236K /lib/modules/2.6.18-4-amd64/kernel/drivers/usb/gadget
131K /lib/modules/2.6.18-4-amd64/kernel/drivers/usb/storage
3,1M /lib/modules/2.6.18-4-amd64/kernel/drivers/usb
841K /lib/modules/2.6.18-4-amd64/kernel/drivers/ieee1394
292K /lib/modules/2.6.18-4-amd64/kernel/drivers/rtc
92K /lib/modules/2.6.18-4-amd64/kernel/drivers/cpufreq
484K /lib/modules/2.6.18-4-amd64/kernel/drivers/atm
292K /lib/modules/2.6.18-4-amd64/kernel/drivers/message/fusion
221K /lib/modules/2.6.18-4-amd64/kernel/drivers/message/i2o
514K /lib/modules/2.6.18-4-amd64/kernel/drivers/message
407K /lib/modules/2.6.18-4-amd64/kernel/drivers/i2c/busses
56K /lib/modules/2.6.18-4-amd64/kernel/drivers/i2c/algos
127K /lib/modules/2.6.18-4-amd64/kernel/drivers/i2c/chips
649K /lib/modules/2.6.18-4-amd64/kernel/drivers/i2c
206K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/bt8xx
67K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/et61x251
43K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/ovcamchip
209K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/usbvideo
319K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/saa7134
109K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/pwc
124K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/sn9c102
47K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/cx25840
81K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/em28xx
284K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/cx88
218K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/pvrusb2
77K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/zc0301
66K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video/cpia2
3,8M /lib/modules/2.6.18-4-amd64/kernel/drivers/media/video
168K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/common
139K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/dvb/bt8xx
32K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/dvb/cinergyT2
568K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/dvb/frontends
121K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/dvb/dvb-core
80K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/dvb/b2c2
53K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/dvb/ttusb-dec
21K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/dvb/pluto2
289K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/dvb/dvb-usb
47K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/dvb/ttusb-budget
304K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/dvb/ttpci
1,7M /lib/modules/2.6.18-4-amd64/kernel/drivers/media/dvb
73K /lib/modules/2.6.18-4-amd64/kernel/drivers/media/radio
5,6M /lib/modules/2.6.18-4-amd64/kernel/drivers/media
263K /lib/modules/2.6.18-4-amd64/kernel/drivers/pci/hotplug
264K /lib/modules/2.6.18-4-amd64/kernel/drivers/pci
29K /lib/modules/2.6.18-4-amd64/kernel/drivers/spi
38K /lib/modules/2.6.18-4-amd64/kernel/drivers/leds
22K /lib/modules/2.6.18-4-amd64/kernel/drivers/dma
173K /lib/modules/2.6.18-4-amd64/kernel/drivers/isdn/capi
847K /lib/modules/2.6.18-4-amd64/kernel/drivers/isdn/hisax
229K /lib/modules/2.6.18-4-amd64/kernel/drivers/isdn/i4l
30K /lib/modules/2.6.18-4-amd64/kernel/drivers/isdn/divert
541K /lib/modules/2.6.18-4-amd64/kernel/drivers/isdn/hardware/eicon
181K /lib/modules/2.6.18-4-amd64/kernel/drivers/isdn/hardware/avm
723K /lib/modules/2.6.18-4-amd64/kernel/drivers/isdn/hardware
177K /lib/modules/2.6.18-4-amd64/kernel/drivers/isdn/gigaset
2,2M /lib/modules/2.6.18-4-amd64/kernel/drivers/isdn
191K /lib/modules/2.6.18-4-amd64/kernel/drivers/mtd/devices
137K /lib/modules/2.6.18-4-amd64/kernel/drivers/mtd/maps
225K /lib/modules/2.6.18-4-amd64/kernel/drivers/mtd/chips
25K /lib/modules/2.6.18-4-amd64/kernel/drivers/mtd/onenand
100K /lib/modules/2.6.18-4-amd64/kernel/drivers/mtd/nand
895K /lib/modules/2.6.18-4-amd64/kernel/drivers/mtd
394K /lib/modules/2.6.18-4-amd64/kernel/drivers/infiniband/core
175K /lib/modules/2.6.18-4-amd64/kernel/drivers/infiniband/hw/mthca
338K /lib/modules/2.6.18-4-amd64/kernel/drivers/infiniband/hw/ipath
514K /lib/modules/2.6.18-4-amd64/kernel/drivers/infiniband/hw
57K /lib/modules/2.6.18-4-amd64/kernel/drivers/infiniband/ulp/iser
45K /lib/modules/2.6.18-4-amd64/kernel/drivers/infiniband/ulp/srp
77K /lib/modules/2.6.18-4-amd64/kernel/drivers/infiniband/ulp/ipoib
180K /lib/modules/2.6.18-4-amd64/kernel/drivers/infiniband/ulp
1,1M /lib/modules/2.6.18-4-amd64/kernel/drivers/infiniband
409K /lib/modules/2.6.18-4-amd64/kernel/drivers/acpi
22K /lib/modules/2.6.18-4-amd64/kernel/drivers/connector
62K /lib/modules/2.6.18-4-amd64/kernel/drivers/cdrom
179K /lib/modules/2.6.18-4-amd64/kernel/drivers/parport
38M /lib/modules/2.6.18-4-amd64/kernel/drivers
62K /lib/modules/2.6.18-4-amd64/kernel/fs/affs
25K /lib/modules/2.6.18-4-amd64/kernel/fs/qnx4
333K /lib/modules/2.6.18-4-amd64/kernel/fs/cifs
292K /lib/modules/2.6.18-4-amd64/kernel/fs/ntfs
78K /lib/modules/2.6.18-4-amd64/kernel/fs/ncpfs
76K /lib/modules/2.6.18-4-amd64/kernel/fs/hfs
61K /lib/modules/2.6.18-4-amd64/kernel/fs/coda
35K /lib/modules/2.6.18-4-amd64/kernel/fs/adfs
176K /lib/modules/2.6.18-4-amd64/kernel/fs/jffs2
1,0M /lib/modules/2.6.18-4-amd64/kernel/fs/nls
102K /lib/modules/2.6.18-4-amd64/kernel/fs/lockd
64K /lib/modules/2.6.18-4-amd64/kernel/fs/jffs
52K /lib/modules/2.6.18-4-amd64/kernel/fs/minix
45K /lib/modules/2.6.18-4-amd64/kernel/fs/befs
89K /lib/modules/2.6.18-4-amd64/kernel/fs/ufs
78K /lib/modules/2.6.18-4-amd64/kernel/fs/fat
108K /lib/modules/2.6.18-4-amd64/kernel/fs/udf
31K /lib/modules/2.6.18-4-amd64/kernel/fs/autofs
30K /lib/modules/2.6.18-4-amd64/kernel/fs/bfs
662K /lib/modules/2.6.18-4-amd64/kernel/fs/xfs
107K /lib/modules/2.6.18-4-amd64/kernel/fs/jbd
41K /lib/modules/2.6.18-4-amd64/kernel/fs/autofs4
117K /lib/modules/2.6.18-4-amd64/kernel/fs/9p
99K /lib/modules/2.6.18-4-amd64/kernel/fs/ext2
12K /lib/modules/2.6.18-4-amd64/kernel/fs/nfs_common
283K /lib/modules/2.6.18-4-amd64/kernel/fs/nfsd
197K /lib/modules/2.6.18-4-amd64/kernel/fs/ext3
26K /lib/modules/2.6.18-4-amd64/kernel/fs/efs
21K /lib/modules/2.6.18-4-amd64/kernel/fs/msdos
53K /lib/modules/2.6.18-4-amd64/kernel/fs/sysv
49K /lib/modules/2.6.18-4-amd64/kernel/fs/configfs
106K /lib/modules/2.6.18-4-amd64/kernel/fs/hfsplus
16K /lib/modules/2.6.18-4-amd64/kernel/fs/exportfs
130K /lib/modules/2.6.18-4-amd64/kernel/fs/ocfs2/cluster
316K /lib/modules/2.6.18-4-amd64/kernel/fs/ocfs2/dlm
986K /lib/modules/2.6.18-4-amd64/kernel/fs/ocfs2
50K /lib/modules/2.6.18-4-amd64/kernel/fs/isofs
25K /lib/modules/2.6.18-4-amd64/kernel/fs/vfat
20K /lib/modules/2.6.18-4-amd64/kernel/fs/romfs
239K /lib/modules/2.6.18-4-amd64/kernel/fs/jfs
352K /lib/modules/2.6.18-4-amd64/kernel/fs/nfs
318K /lib/modules/2.6.18-4-amd64/kernel/fs/reiserfs
92K /lib/modules/2.6.18-4-amd64/kernel/fs/smbfs
28K /lib/modules/2.6.18-4-amd64/kernel/fs/freevxfs
69K /lib/modules/2.6.18-4-amd64/kernel/fs/fuse
111K /lib/modules/2.6.18-4-amd64/kernel/fs/hpfs
102K /lib/modules/2.6.18-4-amd64/kernel/fs/afs
6,9M /lib/modules/2.6.18-4-amd64/kernel/fs
28K /lib/modules/2.6.18-4-amd64/kernel/lib/zlib_deflate
16K /lib/modules/2.6.18-4-amd64/kernel/lib/reed_solomon
101K /lib/modules/2.6.18-4-amd64/kernel/lib
58M /lib/modules/2.6.18-4-amd64/kernel
59M /lib/modules/2.6.18-4-amd64
177M /lib/modules
808K /lib/iptables
0 /lib/init/rw
16K /lib/init
1,0K /lib/firmware
1,0K /lib/x86_64-linux-gnu
1,0K /lib/udev/devices
154K /lib/udev
409K /lib/security
9,0K /lib/lsb
8,0K /lib/terminfo/r
3,0K /lib/terminfo/a
10K /lib/terminfo/s
3,0K /lib/terminfo/l
5,0K /lib/terminfo/m
3,0K /lib/terminfo/p
3,0K /lib/terminfo/E
2,0K /lib/terminfo/d
20K /lib/terminfo/x
5,0K /lib/terminfo/w
8,0K /lib/terminfo/v
5,0K /lib/terminfo/c
3,0K /lib/terminfo/h
79K /lib/terminfo
184M /lib
205M /
