Merci pour vos réponses.
Le retour du lsblk -o TYPE,SIZE,NAME,FSTYPE,UUID,LABEL,MOUNTPOINT:
TYPE SIZE NAME FSTYPE UUID LABEL MOUNTPOINT
disk 931.5G sda
part 243M ├─sda1 linux_raid_member ec59d93e-bf1e-918f-5b45-5536753334ea debian:0
raid1 243M │ └─md0 ext4 4e6ecda6-b1a4-4011-928f-93836252ddad /boot
part 931.3G └─sda2 linux_raid_member 439e64e2-0379-490c-072b-4d6bf5266ecb debian:1
raid1 931.3G └─md1 LVM2_member LiPefI-SMVP-53mh-GEIG-y1fg-lGpc-aGsnlI
lvm 48.1G ├─vg-root (dm-0) ext4 feeff1a4-d258-4b94-937f-c468238ce5a0 /
lvm 7.6G ├─vg-swap (dm-1) swap 7d5c5158-c182-497e-badb-b83583a5a7ff [SWAP]
lvm 800G └─vg-home (dm-2) ext4 f01e4a07-1e2c-421e-ad12-f6b392bca8cc /home
disk 931.5G sdb
part 243M ├─sdb1 linux_raid_member ec59d93e-bf1e-918f-5b45-5536753334ea debian:0
part 931.3G └─sdb2 linux_raid_member 439e64e2-0379-490c-072b-4d6bf5266ecb debian:1
J’ai en effet uniquement 2 DD de 1To en RAID1, le tout géré avec LVM:
Le vgdisplay:
--- Volume group ---
VG Name vg
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 5
VG Access read/write
VG Status resizable
MAX LV 0
Cur LV 3
Open LV 3
Max PV 0
Cur PV 1
Act PV 1
VG Size 931.27 GiB
PE Size 4.00 MiB
Total PE 238405
Alloc PE / Size 219078 / 855.77 GiB
Free PE / Size 19327 / 75.50 GiB
VG UUID Ed986V-LLN7-oklz-icmw-xTHN-yL09-88dA1L
Le lvdisplay:
--- Logical volume ---
LV Path /dev/vg/swap
LV Name swap
VG Name vg
LV UUID MQolvI-Qs9F-HtyS-onTp-YgwP-iWOc-kvesWe
LV Write Access read/write
LV Creation host, time ,
LV Status available
# open 2
LV Size 7.63 GiB
Current LE 1953
Segments 1
Allocation inherit
Read ahead sectors auto
- currently set to 256
Block device 253:1
LV Path /dev/vg/root
LV Name root
VG Name vg
LV UUID 6jJdlk-78DV-e5Bn-xoLR-QeZ3-PEUf-nhFy2l
LV Status available
# open 1
LV Size 48.14 GiB
Current LE 12325
Segments 2
Allocation inherit
Block device 253:0
LV Path /dev/vg/home
LV Name home
VG Name vg
LV UUID kjC3Vc-cT8V-Vvb2-l3hZ-NzLa-95nT-eDHlAM
LV Status available
# open 1
LV Size 800.00 GiB
Current LE 204800
Segments 1
Allocation inherit
Block device 253:2
Le mount:
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,relatime,size=10240k,nr_inodes=1014685,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=813060k,mode=755)
/dev/mapper/vg-root on / type ext4 (rw,noatime,errors=remount-ro,user_xattr,acl,barrier=1,data=ordered)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /run/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=1626100k)
/dev/md0 on /boot type ext4 (rw,nosuid,nodev,noexec,noatime,user_xattr,acl,barrier=1,data=ordered)
/dev/mapper/vg-home on /home type ext4 (rw,nosuid,nodev,noatime,user_xattr,acl,barrier=1,data=ordered)
Et je ne comprends pas par quelle manip tu obtiens le chiffre de 44%, puisque ce n’est pas df -h qui te le donne. la commande ‘du’ ?
J’obtiens le 44% après le reboot serveur (pendant ~16/18 heures) puis ça repasse à 100% sur la racine.
Dans ce cas il pourrait s’agir d’un ou plusieurs fichiers temporaires qui grossissent et ne sont libérés qu’à l’arrêt du système (ou plus exactement du processus qui les maintient ouvert). Tu peux rechercher dans /tmp et /var qui sont normalement les seuls endroits où ce genre de fichier peut être.
Un du -sh de /tmp et /var m’indique que les répertoires ne dépasse pas 500Mo:
4.0K /tmp
410M /var
Je vais voir du côté lsof et je reviens vers vous.
Merci beaucoup pour votre aide dans tout les cas.
