Problème DHCP
Bonjour tous à tous,
J’ai besoin de votre aide, j’ai un souci l’installation DHCP à la fin de configuration
si je fais service isc-dhcp-server restart
il m’affiche ce message Job for isc-dhcp-server.service failed. See ‘systemctl status isc-dhcp-server.service’ and ‘journoulctl -xn’ for datails.
Alors j’ai chercher l’erreur, en tapantles commandes pour les logs, il m’affiche :
Dec 27 16:00:50 ServerDeb isc-dhcp-server[744]: Launching IPv4 server only.
Dec 27 16:00:50 ServerDeb dhcpd[753]: Internet Systems Consortium DHCP Server 4.4.1
Dec 27 16:00:50 ServerDeb dhcpd[753]: Copyright 2004-2018 Internet Systems Consortium.
Dec 27 16:00:50 ServerDeb dhcpd[753]: All rights reserved.
Dec 27 16:00:50 ServerDeb dhcpd[753]: For info, please visit http s://www.isc.org/software/dhcp/
Dec 27 16:00:50 ServerDeb isc-dhcp-server[744]: Starting ISC DHCPv4 server: dhcpddhcpd service already running (pid file /var/run/dhcpd.pid currenty exists) … failed!
Dec 27 16:00:50 ServerDeb systemd[1]: isc-dhcp-server.service: Control process exited, code=exited, status=1/FAILURE
Dec 27 16:00:50 ServerDeb systemd[1]: isc-dhcp-server.service: Failed with result ‹ exit-code ›.
Dec 27 16:02:03 ServerDeb systemd[1]: isc-dhcp-server.service: Found left-over process 665 (dhcpd) in control group while starting unit. Ignoring.
Dec 27 16:02:03 ServerDeb isc-dhcp-server[765]: Launching IPv4 server only.
Dec 27 16:02:03 ServerDeb dhcpd[774]: Internet Systems Consortium DHCP Server 4.4.1
Dec 27 16:02:03 ServerDeb dhcpd[774]: Copyright 2004-2018 Internet Systems Consortium.
Dec 27 16:02:03 ServerDeb dhcpd[774]: All rights reserved.
Dec 27 16:02:03 ServerDeb dhcpd[774]: For info, please visit http s://www.isc.org/software/dhcp/
Dec 27 16:02:03 ServerDeb isc-dhcp-server[765]: Starting ISC DHCPv4 server: dhcpddhcpd service already running (pid file /var/run/dhcpd.pid currenty exists) … failed!
Dec 27 16:02:03 ServerDeb systemd[1]: isc-dhcp-server.service: Control process exited, code=exited, status=1/FAILURE
Dec 27 16:02:03 ServerDeb systemd[1]: isc-dhcp-server.service: Failed with result ‹ exit-code ›.
Dec 27 16:02:23 ServerDeb systemd[1]: isc-dhcp-server.service: Found left-over process 665 (dhcpd) in control group while starting unit. Ignoring.
Dec 27 16:02:23 ServerDeb isc-dhcp-server[791]: Launching IPv4 server only.
Dec 27 16:02:23 ServerDeb dhcpd[800]: Internet Systems Consortium DHCP Server 4.4.1
Dec 27 16:02:23 ServerDeb dhcpd[800]: Copyright 2004-2018 Internet Systems Consortium.
Dec 27 16:02:23 ServerDeb dhcpd[800]: All rights reserved.
Dec 27 16:02:23 ServerDeb dhcpd[800]: For info, please visit http s://www.isc.org/software/dhcp/
Dec 27 16:02:23 ServerDeb isc-dhcp-server[791]: Starting ISC DHCPv4 server: dhcpddhcpd service already running (pid file /var/run/dhcpd.pid currenty exists) … failed!
Dec 27 16:02:23 ServerDeb systemd[1]: isc-dhcp-server.service: Control process exited, code=exited, status=1/FAILURE
Dec 27 16:02:23 ServerDeb systemd[1]: isc-dhcp-server.service: Failed with result ‹ exit-code ›.
root@ServerDeb:~#
Si vous avait une solution svp je suis preneur.
Merci d’avance
isc-dhcp-server a un bug.
Par défaut, il démarre en IPv4 et IPv6. Si un seul des deux ne fonctionne pas, il n’est plus capable d’arrêter le processus.
Donc regarde si un processus DHCP ne tourne pas en faisant un ps -eaf | grep -i dhcp, si c’est le cas, fait un kill -9 du process.
Ensuite efface le fichier qui est indiqué dans la ligne de log:
Concernant la configuration, assures toi bien d’avoir correctement paramétré le fichier /etc/default/isc-dhcp-server avec les seules interfaces voulues.
Merci pour ta réponse, j’ai fais comme tu m’as indiquer et ça fonctionne.
pense à mettre le message correspondant en « résolu ».
Attention, à chaque fois que tu as une erreur dans la configuration du serveur et que celui-ci ne reémarre pas, il faut faire cette manipulation (en gros à chaque arrêt sur erreur, mais pas sur un stop / start volontaire).
Nickel, merci pour le conseil. :innocent:
