Salut tout le monde,
Voilà j’ai un probleme, je n’arrive pas a installer cette fichu carte wifi mini pci sur mon ordinateur portable. Voila le lspci correspondant:
root@delp3:/home/mimimati# lspci
00:00.0 Host bridge: Intel Corporation 82830 830 Chipset Host Bridge
(rev 04)
00:01.0 PCI bridge: Intel Corporation 82830 830 Chipset AGP Bridge (rev
04)
00:1d.0 USB Controller: Intel Corporation 82801CA/CAM USB (Hub #1) (rev
02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 42)
00:1f.0 ISA bridge: Intel Corporation 82801CAM ISA Bridge (LPC) (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801CAM IDE U100 (rev 02)
00:1f.5 Multimedia audio controller: Intel Corporation 82801CA/CAM AC'97
Audio Controller (rev 02)
00:1f.6 Modem: Intel Corporation 82801CA/CAM AC'97 Modem Controller (rev
02)
01:00.0 VGA compatible controller: ATI Technologies Inc Radeon Mobility
M6 LY
02:00.0 Ethernet controller: 3Com Corporation 3c905C-TX/TX-M [Tornado]
(rev 78)
02:01.0 CardBus bridge: Texas Instruments PCI1420
02:01.1 CardBus bridge: Texas Instruments PCI1420
02:03.0 Network controller: Intersil Corporation ISL3890 [Prism GT/Prism
Duette]/ISL3886 [Prism Javelin/Prism Xbow] (rev 01)
et lspci -v:
root@delp3:/home/mimimati# lspci -v
(rev 04)
Flags: bus master, fast devsel, latency 0
Memory at d0000000 (32-bit, prefetchable) [size=256M]
Capabilities: [40] Vendor Specific Information
Capabilities: [a0] AGP version 2.0
04) (prog-if 00 [Normal decode])
Flags: bus master, 66MHz, fast devsel, latency 32
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: fc000000-fdffffff
Prefetchable memory behind bridge: e0000000-e7ffffff
02) (prog-if 00 [UHCI])
Subsystem: Intel Corporation Latitude C640
Flags: bus master, medium devsel, latency 0, IRQ 11
I/O ports at bf80 [size=32]
Bus: primary=00, secondary=02, subordinate=10, sec-latency=32
I/O behind bridge: 0000e000-0000ffff
Memory behind bridge: f4000000-fbffffff
Prefetchable memory behind bridge: 20000000-24ffffff
(prog-if 8a [Master SecP PriP])
I/O ports at <ignored>
I/O ports at bfa0 [size=16]
Memory at 25000000 (32-bit, non-prefetchable) [size=1K]
Subsystem: Cirrus Logic Crystal WMD Audio Codec
Flags: bus master, medium devsel, latency 0, IRQ 5
I/O ports at d800 [size=256]
I/O ports at dc80 [size=64]
02) (prog-if 00 [Generic])
Subsystem: PCTel Inc Dell Inspiron 2100 internal modem
I/O ports at d400 [size=256]
I/O ports at dc00 [size=128]
M6 LY (prog-if 00 [VGA])
Subsystem: Dell Unknown device 00e3
Flags: bus master, VGA palette snoop, stepping, 66MHz, medium
devsel, latency 32, IRQ 11
Memory at e0000000 (32-bit, prefetchable) [size=128M]
I/O ports at c000 [size=256]
Memory at fcff0000 (32-bit, non-prefetchable) [size=64K]
[virtual] Expansion ROM at fc000000 [disabled] [size=128K]
Capabilities: [58] AGP version 2.0
Capabilities: [50] Power Management version 2
(rev 78)
Flags: bus master, medium devsel, latency 32, IRQ 11
I/O ports at ec80 [size=128]
Memory at f8fffc00 (32-bit, non-prefetchable) [size=128]
Expansion ROM at 24000000 [disabled] [size=128K]
Capabilities: [dc] Power Management version 2
Flags: bus master, medium devsel, latency 168, IRQ 11
Memory at f8000000 (32-bit, non-prefetchable) [size=4K]
Bus: primary=02, secondary=03, subordinate=06, sec-latency=176
Memory window 0: 20000000-21fff000 (prefetchable)
Memory window 1: f4000000-f5fff000
I/O window 0: 0000e000-0000e0ff
I/O window 1: 0000e400-0000e4ff
16-bit legacy interface ports at 0001
Memory at f8001000 (32-bit, non-prefetchable) [size=4K]
Bus: primary=02, secondary=07, subordinate=0a, sec-latency=176
Memory window 0: 22000000-23fff000 (prefetchable)
Memory window 1: f6000000-f7fff000
I/O window 0: 0000e800-0000e8ff
I/O window 1: 00001000-000010ff
Subsystem: Creatix Polymedia GmbH Unknown device 2004
Flags: bus master, medium devsel, latency 56, IRQ 5
Memory at f8ffc000 (32-bit, non-prefetchable) [size=8K]
Capabilities: [dc] Power Management version 1
J’ai dabord essayé d’installer les pilotes wfi prism54 ( il n’ya rien marqué sur la carte a propos du fabricant). Sauf qu’au vu des informations de lscpi, je n’ai pas reussi a comprendre quel est le chipset ISL3986 ou ISL3980. Ce qui a une influence au niveau des driver Softmac ou Fullmac.
Puis on comparant le vendor device grace a la comande lspci -n
[code]root@delp3:/home/mimimati# lspci -n
00:00.0 0600: 8086:3575 (rev 04)
00:01.0 0604: 8086:3576 (rev 04)
00:1d.0 0c03: 8086:2482 (rev 02)
00:1e.0 0604: 8086:2448 (rev 42)
00:1f.0 0601: 8086:248c (rev 02)
00:1f.1 0101: 8086:248a (rev 02)
00:1f.5 0401: 8086:2485 (rev 02)
00:1f.6 0703: 8086:2486 (rev 02)
01:00.0 0300: 1002:4c59
02:00.0 0200: 10b7:9200 (rev 78)
02:01.0 0607: 104c:ac51
02:01.1 0607: 104c:ac51
02:03.0 0280: 1260:3890 (rev 01)
J’en ai conclus que cette carte est une netgear wg511 revision 01 (made in china) donc seulement utilsable avec ndiswrapper. Toutefois ce qui est etrange, c’est que la carte netgear wg511 est une carte pci alors que la mienne est une mini pci.
Du coup j’ai installer ndiswrapper avec aptitude et effectuer tout les manipulations (modprobe …). La carte a l’air d’être installer ndiswrapper -l
root@delp3:/home/mimimati# ndiswrapper -l
2802w : driver installed
device (1260:3890) present
mais il n’arrive pas a scanner avec iwlist wlan0 scan:
root@delp3:/home/mimimati# iwlist wlan0 scan
wlan0 No scan results
Jai essayé de configurer l’essid, le canal, la cle wep mais rien n’y fait.
Voila le resultat de ifconfig -a
root@delp3:/home/mimimati# ifconfig -a
eth0 Lien encap:Ethernet HWaddr 00:08:74:98:9C:C0
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Interruption:11 Adresse de base:0x2c00
lo Lien encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:560 (560.0 b) TX bytes:560 (560.0 b)
sit0 Lien encap:IPv6-dans-IPv4
NOARP MTU:1480 Metric:1
wlan0 Lien encap:Ethernet HWaddr 00:07:CA:02:7A:AB
Interruption:5 Mémoire:f8ffc000-f8ffe000
et celui de iwconfig
root@delp3:/home/mimimati# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
sit0 no wireless extensions.
wlan0 IEEE 802.11g ESSID:off/any
Mode:Managed Frequency:2.462 GHz Access Point:
Not-Associated
Bit Rate:2 Mb/s Tx-Power:32 dBm
RTS thr:2347 B Fragment thr:2346 B
Encryption key:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
Si quelqu’un aurait une idée pour me debloquer, Merci
