Bonjour j’essaie d’installer hellahella, une interface web de hellanzb.
J’ai suivi scrupuleusement les instructions d’installation du site http://hellanzb.com/trac/hellanzb/wiki/HellaHella
et j’ai le résultat suivant:
# python ez_setup.py -U hellahella==dev
Searching for hellahella==dev
Reading http://www.python.org/pypi/hellahella/
Reading http://hellanzb.com/trac/hellanzb/wiki/HellaHella
Reading http://www.python.org/pypi/hellahella/0.1
Best match: hellahella dev
Downloading http://hellanzb.com/hellanzb/hellahella/trunk#egg=hellahella-dev
Doing subversion checkout from http://hellanzb.com/hellanzb/hellahella/trunk to /tmp/easy_install-cZP0DE/trunk
Processing trunk
Running setup.py -q bdist_egg --dist-dir /tmp/easy_install-cZP0DE/trunk/egg-dist-tmp-Cm8Kat
Traceback (most recent call last):
File "ez_setup.py", line 223, in ?
main(sys.argv[1:])
File "ez_setup.py", line 176, in main
main(list(argv)+[download_setuptools(delay=0)])
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/easy_install.py", line 1588, in main
with_ei_usage(lambda:
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/easy_install.py", line 1577, in with_ei_usage
return f()
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/easy_install.py", line 1591, in <lambda>
distclass=DistributionWithoutHelpCommands, **kw
File "distutils/core.py", line 149, in setup
File "distutils/dist.py", line 946, in run_commands
File "distutils/dist.py", line 966, in run_command
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/easy_install.py", line 211, in run
self.easy_install(spec, not self.no_deps)
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/easy_install.py", line 446, in easy_install
return self.install_item(spec, dist.location, tmpdir, deps)
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/easy_install.py", line 471, in install_item
dists = self.install_eggs(spec, download, tmpdir)
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/easy_install.py", line 655, in install_eggs
return self.build_and_install(setup_script, setup_base)
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/easy_install.py", line 930, in build_and_install
self.run_setup(setup_script, setup_base, args)
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/easy_install.py", line 919, in run_setup
run_setup(setup_script, args)
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/sandbox.py", line 26, in run_setup
DirectorySandbox(setup_dir).run(
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/sandbox.py", line 63, in run
return func()
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/sandbox.py", line 29, in <lambda>
{'__file__':setup_script, '__name__':'__main__'}
File "setup.py", line 50, in ?
File "distutils/dist.py", line 965, in run_command
File "/usr/lib/python2.4/cmd.py", line 117, in ensure_finalized
pass
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/bdist_egg.py", line 94, in finalize_options
ei_cmd = self.ei_cmd = self.get_finalized_command("egg_info")
File "/usr/lib/python2.4/cmd.py", line 319, in get_finalized_command
for name in names:
pass
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/egg_info.py", line 85, in finalize_options
self.vtags = self.tags()
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/egg_info.py", line 179, in tags
): version += '-r%s' % self.get_svn_revision()
File "/usr/lib/python2.4/site-packages/setuptools-0.6c1-py2.4.egg/setuptools/command/egg_info.py", line 196, in get_svn_revision
dirurl = urlre.search(data).group(1) # get repository URL
AttributeError: 'NoneType' object has no attribute 'group'
Si quelqu’un pouvait m’expliquer…
Merci d’avance
