[quote=“dchost99”]hello,
http://packages.debian.org/sid/smartmontools
Self-Monitoring, Analysis and Reporting Technology
le disque integré un auto-diagnostique que tu peux interroger avec smartctl
https://fedoraproject.org/wiki/Smartctl[/quote]
Voici ce que j’ai eu comme sortie:
[code]smartctl 5.41 2011-06-09 r3365 [i686-linux-3.2.0-4-686-pae] (local build)
Copyright © 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model: TOSHIBA MK5056GSY
Serial Number: 502KT5M2T
LU WWN Device Id: 5 000039 2819808ed
Firmware Version: LH003C
User Capacity: 500,107,862,016 bytes [500 GB]
Sector Size: 512 bytes logical/physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Sat Mar 2 12:48:48 2013 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 120) seconds.
capabilities: (0x51) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 117) minutes.
SCT capabilities: (0x0033) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 100 100 050 Pre-fail Always - 0
2 Throughput_Performance 0x0007 100 100 050 Pre-fail Always - 0
3 Spin_Up_Time 0x0003 100 100 002 Pre-fail Always - 2192
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 5763
5 Reallocated_Sector_Ct 0x0033 089 089 010 Pre-fail Always - 235
7 Seek_Error_Rate 0x000f 100 100 050 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 088 088 000 Old_age Always - 5115
10 Spin_Retry_Count 0x0013 214 100 030 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 1073
183 Runtime_Bad_Block 0x0022 100 100 001 Old_age Always - 3
184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0
185 Unknown_Attribute 0x0032 100 100 001 Old_age Always - 65535
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 2442
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 001 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 055 027 045 Old_age Always In_the_past 45 (Min/Max 26/45)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 7310
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 18153749
193 Load_Cycle_Count 0x0032 074 074 000 Old_age Always - 261980
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 210
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 82
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 2917 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It “wraps” after 49.710 days.
Error 2917 occurred at disk power-on lifetime: 5115 hours (213 days + 3 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 41 02 00 08 00 40 Error: UNC at LBA = 0x00000800 = 2048
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 08 00 00 08 00 40 00 00:48:35.429 READ FPDMA QUEUED
ef 10 02 00 00 00 a0 00 00:48:35.429 SET FEATURES [Reserved for Serial ATA]
ec 00 00 00 00 00 a0 00 00:48:35.428 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 00:48:35.428 SET FEATURES [Set transfer mode]
ef 10 02 00 00 00 a0 00 00:48:35.428 SET FEATURES [Reserved for Serial ATA]
Error 2916 occurred at disk power-on lifetime: 5115 hours (213 days + 3 hours)
60 08 00 00 08 00 40 00 00:48:32.379 READ FPDMA QUEUED
ef 10 02 00 00 00 a0 00 00:48:32.379 SET FEATURES [Reserved for Serial ATA]
ec 00 00 00 00 00 a0 00 00:48:32.378 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 00:48:32.378 SET FEATURES [Set transfer mode]
ef 10 02 00 00 00 a0 00 00:48:32.378 SET FEATURES [Reserved for Serial ATA]
Error 2915 occurred at disk power-on lifetime: 5115 hours (213 days + 3 hours)
60 08 00 00 08 00 40 00 00:48:29.329 READ FPDMA QUEUED
ef 10 02 00 00 00 a0 00 00:48:29.329 SET FEATURES [Reserved for Serial ATA]
ec 00 00 00 00 00 a0 00 00:48:29.328 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 00:48:29.328 SET FEATURES [Set transfer mode]
ef 10 02 00 00 00 a0 00 00:48:29.328 SET FEATURES [Reserved for Serial ATA]
Error 2914 occurred at disk power-on lifetime: 5115 hours (213 days + 3 hours)
60 08 00 00 08 00 40 00 00:48:26.279 READ FPDMA QUEUED
ef 10 02 00 00 00 a0 00 00:48:26.278 SET FEATURES [Reserved for Serial ATA]
ec 00 00 00 00 00 a0 00 00:48:26.278 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 00:48:26.278 SET FEATURES [Set transfer mode]
Error 2913 occurred at disk power-on lifetime: 5115 hours (213 days + 3 hours)
60 08 00 00 08 00 40 00 00:48:23.228 READ FPDMA QUEUED
ef 10 02 00 00 00 a0 00 00:48:23.227 SET FEATURES [Reserved for Serial ATA]
ec 00 00 00 00 00 a0 00 00:48:23.227 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 00:48:23.227 SET FEATURES [Set transfer mode]
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
1 Short offline Completed without error 00% 3 -
2 Short offline Completed without error 00% 2 -
3 Short offline Completed without error 00% 2 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
