je viens vers vous suite à un problème que je n’arrive pas à résoudre.
Pour commencer voici la conf (Debian 7 64):
[quote]00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.1 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4)
00:1c.2 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 3 (rev c4)
00:1c.3 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 4 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation QM77 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Device 682d
01:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI Device aab0
24:00.0 FireWire (IEEE 1394): JMicron Technology Corp. IEEE 1394 Host Controller (rev 30)
24:00.1 System peripheral: JMicron Technology Corp. SD/MMC Host Controller (rev 30)
24:00.2 SD Host controller: JMicron Technology Corp. Standard SD Host Controller (rev 30)
25:00.0 Network controller: Broadcom Corporation BCM43228 802.11a/b/g/n
Le problème:
Je dispose d’un écran secondaire que je ne peux utiliser.
Lorsque je le connecte via la sortie VGA, pour activer la sortie il faut que j’aille dans “Préférence Système”->Affichage.
Une fois cette fenêtre affichée, le second écran s’active.
Si je configure la configuration “Clone” l’écran secondaire fonctionne correctement.
En revanche si je choisi “bureau étendu” alors il affiche le bureau étendu mais il ne raffraichi pas d’écran. Je peux déplacer une fenêtre sur l’écran secondaire mais l’image reste statique.
Typiquement, si je déplace la console sur l’écran secondaire je ne vois pas le curseur clignoter. comme si j’avais mis une capture d’écran. L’écran se met à jour lorsque je passe la souris sur le panel. Vraiment étrange!
Je parle d’une problème de rafraichissement mais je ne connais pas les termes exacts.
Lors de l’installation j’ai installer les drivers ATI. J’ai voulu installer fglrx mais cela à fait planter la conf.
Je vous remercie.
