j’ai un soucis sur un de mes serveurs (Debian 7.3 64b) avec aptitude, j’avais une serie de message d’erreur. Après recherche sur le web, je pense avoir compris que c’était ‘initscripts’ qui causait problème.
Mais impossible de configurer initscripts, je tourne en rond et a force de bricoler j’ai planté mysql (si si j’en suis capable).
Si une bonne âme sait comment résoudre ce problème je suis preneur
dpkg --configure initscripts
root@xyz:/home/franck# dpkg --configure initscripts
Paramétrage de initscripts (2.88dsf-41+deb7u1) ...
insserv: warning: script 'S99flumotion' missing LSB tags and overrides
insserv: warning: script 'flumotion' missing LSB tags and overrides
insserv: There is a loop at service flumotion if started
insserv: There is a loop between service minissdpd and mountnfs if started
insserv: loop involving service mountnfs at depth 9
insserv: loop involving service networking at depth 8
insserv: loop involving service mountnfs-bootclean at depth 11
insserv: loop involving service rpcbind at depth 10
insserv: There is a loop between service flumotion and mountall if started
insserv: loop involving service mountall at depth 7
insserv: loop involving service checkfs at depth 6
insserv: There is a loop between service minissdpd and urandom if started
insserv: loop involving service urandom at depth 9
insserv: loop involving service mountall-bootclean at depth 8
insserv: Starting flumotion depends on minissdpd and therefore on system facility `$all' which can not be true!
insserv: Max recursions depth 99 reached
insserv: loop involving service atd at depth 13
insserv: There is a loop between service minissdpd and mountdevsubfs if started
insserv: loop involving service mountdevsubfs at depth 2
insserv: loop involving service udev at depth 1
insserv: There is a loop at service minissdpd if started
insserv: loop involving service nfs-common at depth 12
insserv: loop involving service apache2 at depth 14
insserv: There is a loop between service minissdpd and checkroot if started
insserv: loop involving service checkroot at depth 5
insserv: loop involving service hwclock at depth 4
insserv: loop involving service flumotion at depth 1
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: erreur de traitement de initscripts (--configure) :
le sous-processus script post-installation installé a retourné une erreur de sortie d'état 1
initscripts
aptitude install -f :
root@xyz:/home/franck# aptitude install -f
bind9
acl{u} fontconfig{u} gconf-service{u} gconf2{u} gconf2-common{u} gir1.2-atk-1.0{u} gir1.2-freedesktop{u} gir1.2-glib-2.0{u} gir1.2-pango-1.0{u}
hicolor-icon-theme{u} liba52-0.7.4{u} libaa1{u} libaacs0{u} libass4{u} libatk1.0-0{u} libatk1.0-data{u} libatk1.0-dev{u} libaudio2{u}
libavahi-client3{u} libavahi-common-data{u} libavahi-common3{u} libavc1394-0{u} libblas3{u} libbluray1{u} libcairo-gobject2{u}
libcairo-script-interpreter2{u} libcairo2{u} libcairo2-dev{u} libcanberra0{u} libcddb2{u} libcolord1{u} libcrystalhd3{u} libcups2{u} libdatrie1{u}
libdca0{u} libdirac-decoder0{u} libdvbpsi7{u} libdvdnav4{u} libdvdread4{u} libebml3{u} libelf1{u} libenca0{u} libexif12{u} libfaad2{u}
libfile-copy-recursive-perl{u} libfontconfig1-dev{u} libfreetype6-dev{u} libgconf-2-4{u} libgdk-pixbuf2.0-common{u} libgfortran3{u}
libgirepository-1.0-1{u} libglib2.0-bin{u} libglib2.0-dev{u} libgphoto2-l10n{u} libgphoto2-port0{u} libgtk2.0-common{u} libgudev-1.0-0{u} libgusb2{u}
libice-dev{u} libieee1284-3{u} libiso9660-8{u} libkate1{u} liblapack3{u} liblcms1{u} liblcms2-2{u} liblircclient0{u} liblua5.1-0{u} libmad0{u}
libmatroska5{u} libmodplug1{u} libmozjs10d{u} libmpcdec6{u} libmpeg2-4{u} libmtp-common{u} libmtp-runtime{u} libmtp9{u} libnspr4{u} libpango1.0-0{u}
libpango1.0-dev{u} libpcre3-dev{u} libpcrecpp0{u} libpixman-1-0{u} libpixman-1-dev{u} libpng12-dev{u} libpolkit-agent-1-0{u} libpolkit-backend-1-0{u}
libproxy0{u} libpthread-stubs0{u} libpthread-stubs0-dev{u} libqtcore4{u} libresid-builder0c2a{u} libsane-common{u} libsane-extras{u}
libsane-extras-common{u} libshout3{u} libsidplay2{u} libsm-dev{u} libsmbclient{u} libspeexdsp1{u} libtag1-vanilla{u} libtag1c2a{u} libthai-data{u}
libthai0{u} libtwolame0{u} libupnp6{u} libva-x11-1{u} libvcdinfo0{u} libvlc5{u} libvlccore5{u} libvorbisfile3{u} libwebp2{u} libx11-dev{u}
libx11-doc{u} libxau-dev{u} libxcb-composite0{u} libxcb-keysyms1{u} libxcb-randr0{u} libxcb-render0{u} libxcb-render0-dev{u} libxcb-shm0{u}
libxcb-shm0-dev{u} libxcb-xfixes0{u} libxcb-xv0{u} libxcb1-dev{u} libxcomposite-dev{u} libxcursor-dev{u} libxdamage-dev{u} libxdmcp-dev{u}
libxext-dev{u} libxfixes-dev{u} libxft-dev{u} libxi-dev{u} libxinerama-dev{u} libxrandr-dev{u} libxrender-dev{u} libzvbi-common{u} libzvbi0{u}
pkg-config{u} policykit-1{u} python-cairo{u} python-gobject-2{u} python-gobject-2-dev{u} python-numpy{u} update-inetd{u} vlc-data{u}
x11proto-composite-dev{u} x11proto-core-dev{u} x11proto-damage-dev{u} x11proto-fixes-dev{u} x11proto-input-dev{u} x11proto-kb-dev{u}
x11proto-randr-dev{u} x11proto-render-dev{u} x11proto-xext-dev{u} x11proto-xinerama-dev{u} xorg-sgml-doctools{u} xtrans-dev{u}
Les paquets partiellement installés suivants seront configurés :
initscripts
0 paquets mis à jour, 1 nouvellement installés, 157 à enlever et 41 non mis à jour.
Il est nécessaire de télécharger 0 o/371 ko d'archives. Après dépaquetage, 188 Mo seront libérés.
Voulez-vous continuer ? [Y/n/?] y
Préconfiguration des paquets...
initscripts
Échec de l'installation d'un paquet. Tentative de réparation :
initscripts
