Merci pour ron aide,
dans le ifconfig -a, j’ai la même chose que le ifconfig :
[code]ESTEBAN:/home/antichoc# ifconfig
eth0 Lien encap:Ethernet HWaddr 00:50:FC:45:FC:9E
inet adr:192.168.1.10 Bcast:192.168.1.255 Masque:255.255.255.0
adr inet6: 2a01:e35:8bcd:6280:250:fcff:fe45:fc9e/64 Scope:Global
adr inet6: fe80::250:fcff:fe45:fc9e/64 Scope:Lien
RX packets:1429 errors:0 dropped:0 overruns:0 frame:0
TX packets:1548 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:163544 (159.7 KiB) TX bytes:357480 (349.1 KiB)
Interruption:9 Adresse de base:0x3000
lo Lien encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:560 (560.0 b) TX bytes:560 (560.0 b)
ESTEBAN:/home/antichoc# ifconfig -a
RX packets:1441 errors:0 dropped:0 overruns:0 frame:0
TX packets:1557 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:164540 (160.6 KiB) TX bytes:359506 (351.0 KiB)
Pour le interface, j’ai déjà ajouté eth1 dedans :
[code]# This file describes the network interfaces available on your system
auto lo
iface lo inet loopback
The primary network interface
allow-hotplug eth0
iface eth0 inet dhcp
post-up iptables-restore < /etc/iptables.up.rules
J’ai rajouté cela :
# The Secondary network interface
allow-hotplug eth1
iface eth1 inet dhcp
Y a t il autre chose à réaliser ?
Pour info, lsmod :
ESTEBAN:/home/antichoc# lsmod
Module Size Used by
ipv6 242212 24
ac 6212 0
battery 13700 0
xt_state 2528 2
xt_tcpudp 3264 15
iptable_filter 3040 1
iptable_mangle 2880 0
iptable_nat 7044 0
nf_nat 18700 1 iptable_nat
nf_conntrack_ipv4 17544 4 iptable_nat
nf_conntrack 62656 4 xt_state,iptable_nat,nf_nat,nf_conntrack_ipv4
ip_tables 13316 3 iptable_filter,iptable_mangle,iptable_nat
x_tables 14372 4 xt_state,xt_tcpudp,iptable_nat,ip_tables
ext2 65992 1
loop 16996 0
container 4960 0
rtc 13148 0
snd_intel8x0 32092 0
psmouse 36656 0
button 8528 0
snd_ac97_codec 93348 1 snd_intel8x0
i2c_i801 9456 0
ac97_bus 2240 1 snd_ac97_codec
serio_raw 6788 0
pcspkr 3264 0
i2c_core 22656 1 i2c_i801
snd_pcm 72036 2 snd_intel8x0,snd_ac97_codec
snd_timer 21348 1 snd_pcm
intel_rng 5728 0
snd 48772 4 snd_intel8x0,snd_ac97_codec,snd_pcm,snd_timer
soundcore 7680 1 snd
snd_page_alloc 10184 2 snd_intel8x0,snd_pcm
intel_agp 23540 1
agpgart 31912 1 intel_agp
shpchp 31220 0
pci_hotplug 27840 1 shpchp
iTCO_wdt 11396 0
evdev 11200 0
ext3 123368 5
jbd 43892 1 ext3
mbcache 8480 2 ext2,ext3
dm_mirror 21792 0
dm_snapshot 17060 0
dm_mod 56004 15 dm_mirror,dm_snapshot
ide_generic 1280 0 [permanent]
ide_cd 36352 0
cdrom 32672 1 ide_cd
ide_disk 15776 3
ata_generic 7556 0
libata 144560 1 ata_generic
scsi_mod 141516 1 libata
uhci_hcd 23568 0
piix 7556 0 [permanent]
generic 4484 0 [permanent]
usbcore 127724 2 uhci_hcd
ide_core 108740 5 ide_generic,ide_cd,ide_disk,piix,generic
8139too 25728 0
8139cp 22048 0
mii 5344 2 8139too,8139cp
thermal 16092 0
processor 36840 1 thermal
fan 4868 0
et lspci
[code]ESTEBAN:/home/antichoc# lspci
ESTEBAN:/home/antichoc# lspci -v
00:00.0 Host bridge: Intel Corporation 82815 815 Chipset Host Bridge and Memory Controller Hub (rev 02)
Subsystem: Siemens Nixdorf AG Unknown device 005a
Flags: bus master, fast devsel, latency 0
Capabilities: [88] Vendor Specific Information
00:02.0 VGA compatible controller: Intel Corporation 82815 CGC [Chipset Graphics Controller] (rev 02) (prog-if 00 [VGA])
Subsystem: Siemens Nixdorf AG Unknown device 004c
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 11
Memory at f8000000 (32-bit, prefetchable) [size=64M]
Memory at f4000000 (32-bit, non-prefetchable) [size=512K]
Capabilities: [dc] Power Management version 2
00:1e.0 PCI bridge: Intel Corporation 82801AA PCI Bridge (rev 02) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
I/O behind bridge: 00003000-00003fff
Memory behind bridge: f4100000-f41fffff
00:1f.0 ISA bridge: Intel Corporation 82801AA ISA Bridge (LPC) (rev 02)
Flags: bus master, medium devsel, latency 0
00:1f.1 IDE interface: Intel Corporation 82801AA IDE (rev 02) (prog-if 80 [Master])
Subsystem: Intel Corporation 82801AA IDE
[virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled] [size=8]
[virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled] [size=1]
[virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled] [size=8]
[virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled] [size=1]
I/O ports at 2000 [size=16]
00:1f.2 USB Controller: Intel Corporation 82801AA USB (rev 02) (prog-if 00 [UHCI])
Subsystem: Intel Corporation 82801AA USB
Flags: bus master, medium devsel, latency 0, IRQ 9
I/O ports at 1400 [size=32]
00:1f.3 SMBus: Intel Corporation 82801AA SMBus (rev 02)
Subsystem: Intel Corporation 82801AA SMBus
Flags: medium devsel, IRQ 5
I/O ports at 1800 [size=16]
00:1f.5 Multimedia audio controller: Intel Corporation 82801AA AC’97 Audio (rev 02)
Subsystem: Siemens Nixdorf AG Unknown device 0049
Flags: bus master, medium devsel, latency 0, IRQ 5
I/O ports at 1000 [size=256]
I/O ports at 1c00 [size=64]
01:0b.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Subsystem: Realtek Semiconductor Co., Ltd. RT8139
Flags: bus master, medium devsel, latency 64, IRQ 9
I/O ports at 3000 [size=256]
Memory at f4100000 (32-bit, non-prefetchable) [size=256]
[virtual] Expansion ROM at f4110000 [disabled] [size=64K]
