J’ai besoin d’installer les drivers proprio ATI, ca ca semble ok. Mais l’accélration 3D déconne.
Par exemple si je lance un glxinfo:
[code]
glxinfo
name of display: :0
X Error of failed request: BadRequest (invalid request code or no such operation)
Major opcode of failed request: 157 (ATIFGLEXTENSION)
Minor opcode of failed request: 66 ()
Serial number of failed request: 13
Current serial number in output stream: 13
[code]
L’installation semble pourtant ok
dpkg -l | grep fglrx
ii fglrx-atieventsd 1:15.9-2~bpo8+1 amd64 events daemon for the non-free ATI/AMD RadeonHD display driver
ii fglrx-control 1:15.9-2~bpo8+1 amd64 control panel for the non-free ATI/AMD RadeonHD display driver
ii fglrx-driver 1:15.9-2~bpo8+1 amd64 non-free ATI/AMD RadeonHD display driver
ii fglrx-modules-dkms 1:15.9-2~bpo8+1 amd64 dkms module source for the non-free ATI/AMD RadeonHD display driver
ii glx-alternative-fglrx 0.7.1~bpo8+1 amd64 allows the selection of FGLRX as GLX provider
ii libfglrx:amd64 1:15.9-2~bpo8+1 amd64 non-free ATI/AMD RadeonHD display driver (runtime libraries)
ii libfglrx:i386 1:15.9-2~bpo8+1 i386 non-free ATI/AMD RadeonHD display driver (runtime libraries)
ii libfglrx-amdxvba1:amd64 1:15.9-2~bpo8+1 amd64 AMD XvBA (X-Video Bitstream Acceleration) backend for VA API
ii libfglrx-amdxvba1:i386 1:15.9-2~bpo8+1 i386 AMD XvBA (X-Video Bitstream Acceleration) backend for VA API
ii libgl1-fglrx-glx:amd64 1:15.9-2~bpo8+1 amd64 proprietary libGL for the non-free ATI/AMD RadeonHD display driver
ii libgl1-fglrx-glx:i386 1:15.9-2~bpo8+1 i386 proprietary libGL for the non-free ATI/AMD RadeonHD display driver
ii libgl1-fglrx-glx-i386 1:15.9-2~bpo8+1 i386 ATI/AMD binary OpenGL 32-bit librarie
lspci | grep -i hd
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cypress XT [Radeon HD 5870]
Mon xorg.conf
cat /etc/X11/xorg.conf
Section "ServerLayout"
Identifier "aticonfig Layout"
Screen 0 "aticonfig-Screen[0]-0" 0 0
EndSection
Section "Module"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]-0"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
Option "DPMS" "true"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]-0"
Driver "fglrx"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]-0"
Device "aticonfig-Device[0]-0"
Monitor "aticonfig-Monitor[0]-0"
DefaultDepth 24
SubSection "Display"
Viewport 0 0
Depth 24
EndSubSection
EndSection
Si vous avez une idée…
Merci d’avance
