Merci pour ta réponse voici le header d’un mail en question
[quote]Return-Path: contact@MONSITE.COM
X-Original-To: contact@MONSITE.COM
Delivered-To: contact@MONSITE.COM
Received: from MONSERVEUR.COM (localhost.localdomain [127.0.0.1])
by MONSERVEUR.COM (Postfix) with ESMTP id DF33B6DB04
for contact@MONSITE.COM; Fri, 25 Sep 2009 02:23:27 +0200 (CEST)
DKIM-Signature: v=1; a=rsa-sha1; c=relaxed; d=MONSITE.COM; h=to:subject
:from:mime-version:content-type:message-id:date; s=selector1;
bh=OgNbAZNRH2KCqJFplZTAJqkoCfI=; b=h8ubgv28XHB0wjOIWKAOFi74VUZ7
ryKkWWWHpB4BPwwriS0fBqPxnitOIWp2W3rQAXHXsPeGRvQtUniU8gRn4MomGhoK
l8+XZ9BHHrbTZkKcI/XnolDvxEjbC2f80KUIzouoYvBX7FMYbBV8dnv9JtqBRdk4
6iOHHwQIaSxX2ek=
DomainKey-Signature: a=rsa-sha1; c=nofws; d=MONSITE.COM; h=to:subject:from
:mime-version:content-type:message-id:date; q=dns; s=selector1;
b=ZUkTwS+RP0BghEZHg6+TP+BHJno41RmjohLvug1GC46chpF7JCkZPf+cOiVIE
yafOq3Uu89vW4RuG6MICRlvL+52w6gWwvW/G0X3Sx9M/GdiWRaoYQASBi4R96Mib
7RFXNetFAEIqFLydNXXIl7f4fiWigKrI1w+ZlpG1BE13GU=
Received: from c9510c0c.virtua.com.br (c9510c0c.virtua.com.br [201.81.12.12])
by MONSERVEUR.COM (Postfix) with SMTP id 3F8046DB36
for contact@MONSITE.COM; Fri, 25 Sep 2009 02:23:15 +0200 (CEST)
Subject: Can’t find you, darling
MIME-Version: 1.0
Importance: High
Content-Type: text/html
Message-Id: 20090925002319.3F8046DB36@MONSERVEUR.COM
Date: Fri, 25 Sep 2009 02:23:15 +0200 (CEST)[/quote]
Et le log associé à ce mail
[quote]mail.info:Sep 25 02:23:27 r11223 postfix/smtpd[3019]: DF33B6DB04: client=c9510c0c.virtua.com.br[201.81.12.12]
mail.info:Sep 25 02:23:28 r11223 postfix/cleanup[3017]: DF33B6DB04: message-id=20090925002319.3F8046DB36@MONSERVEUR.FR
mail.info:Sep 25 02:23:28 r11223 postfix/qmgr[4089]: DF33B6DB04: from=contact@MONSITE.COM, size=1706, nrcpt=1 (queue active)
mail.info:Sep 25 02:23:28 r11223 postfix/smtp[3018]: 3F8046DB36: to=contact@MONSITE.COM, relay=127.0.0.1[127.0.0.1]:10028, delay=13, delays=12/0/0.01/0.39, dsn=2.0.0, status=sent (250 2.0.0 Ok: queued as DF33B6DB04)
mail.info:Sep 25 02:23:28 r11223 postfix/virtual[3020]: DF33B6DB04: to=contact@MONSITE.COM, relay=virtual, delay=0.69, delays=0.39/0/0/0.3, dsn=2.0.0, status=sent (delivered to maildir)
mail.info:Sep 25 02:23:28 r11223 postfix/qmgr[4089]: DF33B6DB04: removed
mail.log:Sep 25 02:23:27 r11223 postfix/smtpd[3019]: DF33B6DB04: client=c9510c0c.virtua.com.br[201.81.12.12]
mail.log:Sep 25 02:23:28 r11223 postfix/cleanup[3017]: DF33B6DB04: message-id=20090925002319.3F8046DB36@MONSERVEUR.FR
mail.log:Sep 25 02:23:28 r11223 postfix/qmgr[4089]: DF33B6DB04: from=contact@MONSITE.COM, size=1706, nrcpt=1 (queue active)
mail.log:Sep 25 02:23:28 r11223 postfix/smtp[3018]: 3F8046DB36: to=contact@MONSITE.COM, relay=127.0.0.1[127.0.0.1]:10028, delay=13, delays=12/0/0.01/0.39, dsn=2.0.0, status=sent (250 2.0.0 Ok: queued as DF33B6DB04)
mail.log:Sep 25 02:23:28 r11223 postfix/virtual[3020]: DF33B6DB04: to=contact@MONSITE.COM, relay=virtual, delay=0.69, delays=0.39/0/0/0.3, dsn=2.0.0, status=sent (delivered to maildir)
mail.log:Sep 25 02:23:28 r11223 postfix/qmgr[4089]: DF33B6DB04: removed
syslog.1:Sep 25 02:23:27 r11223 postfix/smtpd[3019]: DF33B6DB04: client=c9510c0c.virtua.com.br[201.81.12.12]
syslog.1:Sep 25 02:23:28 r11223 postfix/cleanup[3017]: DF33B6DB04: message-id=20090925002319.3F8046DB36@MONSERVEUR.FR
syslog.1:Sep 25 02:23:28 r11223 postfix/qmgr[4089]: DF33B6DB04: from=contact@MONSITE.COM, size=1706, nrcpt=1 (queue active)
syslog.1:Sep 25 02:23:28 r11223 postfix/smtp[3018]: 3F8046DB36: to=contact@MONSITE.COM, relay=127.0.0.1[127.0.0.1]:10028, delay=13, delays=12/0/0.01/0.39, dsn=2.0.0, status=sent (250 2.0.0 Ok: queued as DF33B6DB04)
syslog.1:Sep 25 02:23:28 r11223 postfix/virtual[3020]: DF33B6DB04: to=contact@MONSITE.COM, relay=virtual, delay=0.69, delays=0.39/0/0/0.3, dsn=2.0.0, status=sent (delivered to maildir)
syslog.1:Sep 25 02:23:28 r11223 postfix/qmgr[4089]: DF33B6DB04: removed[/quote]
Ma conf postfix au passage
[quote]root@rxxxxx:~# postconf -n
append_dot_mydomain = yes
biff = no
config_directory = /etc/postfix
disable_vrfy_command = yes
inet_interfaces = all
mydestination = localhost, localhost.localdomain
mydomain = MONSERVEUR.fr
myhostname = MONSERVEUR.fr
mynetworks = 127.0.0.0/8 192.168.0.0/24
relayhost =
smtpd_banner = $myhostname ESMTP (Debian/GNU)
smtpd_client_restrictions = reject_unknown_client, permit_mynetworks
smtpd_helo_required = yes
smtpd_recipient_restrictions = permit_mynetworks, reject_unauth_destination, reject_unknown_recipient_domain, reject_non_fqdn_recipient
smtpd_sender_restrictions = permit_mynetworks, reject_unknown_sender_domain, warn_if_reject reject_unverified_sender
virtual_alias_maps = mysql:/etc/postfix/mysql-virtual_aliases.cf,mysql:/etc/postfix/mysql-virtual_aliases_mailbox.cf
virtual_gid_maps = static:5000
virtual_mailbox_base = /var/spool/vmail
virtual_mailbox_domains = mysql:/etc/postfix/mysql-virtual_domains.cf
virtual_mailbox_maps = mysql:/etc/postfix/mysql-virtual_mailboxes.cf
virtual_uid_maps = static:5000[/quote]
