bonjour tout le monde
je debute dans le monde de linux
voila j’ai un soucis avec la frequence de rafraichessement de mon moniteur (ecran 17" cathodique flat)
j’ai editer le fichier xorg.conf comme ce qui suit
[code]# xorg.conf (X.Org X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option “XkbRules” "xorg"
Option “XkbModel” "pc104"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
Option “XkbOptions” " altwin:meta_win"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
Driver "nvidia"
Option “UseEDID” "FALSE"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 30.0 - 75.0
VertRefresh 50.0 - 150.0
Option "DPMS"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes “1280x1024” “1152x864” “1024x768” “800x600” “640x480”
EndSubSection
EndSection[/code]
mais je n’arrive pas à avoir 75hz en frequence de rafraichissement
les fequences que j’ai sont dans gnome
52 59 60 61 62hz (etranges frequences) actuellement je suis en 60hz apparemment 62hz ne marche pas
voici mon log
[code]
X.Org X Server 1.4.2
Release Date: 11 June 2008
X Protocol Version 11, Revision 0
Build Operating System: Linux Debian (xorg-server 2:1.4.2-10.lenny2)
Current Operating System: Linux localhost 2.6.26-2-686 #1 SMP Fri Oct 23 23:43:53 UTC 2009 i686
Build Date: 08 June 2009 09:12:57AM
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (–) probed, () from config file, (==) default setting,
(==) Log file: “/var/log/Xorg.0.log”, Time: Tue Nov 24 13:45:04 2009
(==) Using config file: “/etc/X11/xorg.conf”
(==) No Layout section. Using the first Screen section.
() |–>Screen “Screen0” (0)
() | |–>Monitor “Monitor0”
(==) No device specified for screen “Screen0”.
Using the first device section listed.
() | |–>Device “Configured Video Device”
(==) |–>Input Device “Configured Mouse”
(==) |–>Input Device “Generic Keyboard”
(==) The core pointer device wasn’t specified explicitly in the layout.
Using the first mouse device.
(==) The core keyboard device wasn’t specified explicitly in the layout.
Using the first keyboard device.
(==) Automatically adding devices
(==) Automatically enabling devices
(==) No FontPath specified. Using compiled-in default.
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(==) RgbPath set to “/etc/X11/rgb”
(==) ModulePath set to “/usr/lib/xorg/modules”
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81e38c0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 2.0
X.Org XInput driver : 2.0
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: “pcidata”
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.0.0
ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,2570 card 1043,80f2 rev 02 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2571 card 0000,0000 rev 02 class 06,04,00 hdr 01
(II) PCI: 00:1d:0: chip 8086,24d2 card 1043,80a6 rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,24d4 card 1043,80a6 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,24d7 card 1043,80a6 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,24de card 1043,80a6 rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,24dd card 1043,80a6 rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev c2 class 06,04,00 hdr 01
(II) PCI: 00:1f:0: chip 8086,24d0 card 0000,0000 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,24db card 1043,80a6 rev 02 class 01,01,8a hdr 00
(II) PCI: 00:1f:2: chip 8086,24d1 card 1043,80a6 rev 02 class 01,01,8f hdr 00
(II) PCI: 00:1f:3: chip 8086,24d3 card 1043,80a6 rev 02 class 0c,05,00 hdr 00
(II) PCI: 00:1f:5: chip 8086,24d5 card 1043,812a rev 02 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0332 card 1462,9370 rev a1 class 03,00,00 hdr 00
(II) PCI: 02:03:0: chip 1106,3044 card 1043,808a rev 80 class 0c,00,10 hdr 00
(II) PCI: 02:05:0: chip 11ab,4320 card 1043,811a rev 13 class 02,00,00 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xfc900000 - 0xfe9fffff (0x2100000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xe7f00000 - 0xf7efffff (0x10000000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x0000d000 - 0x0000dfff (0x1000) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xfea00000 - 0xfeafffff (0x100000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0x50000000 - 0x500fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(–) PCI:*(1:0:0) nVidia Corporation NV35 [GeForce FX 5900XT] rev 161, Mem @ 0xfd000000/24, 0xe8000000/27, BIOS @ 0xfe9e0000/17
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xf8000000 from 0xfbffffff to 0xf7ffffff
(II) Active PCI resource ranges:
[0] -1 0 0xfeaf8000 - 0xfeafbfff (0x4000) MX[B]
[1] -1 0 0xfeaff800 - 0xfeafffff (0x800) MX[B]
[2] -1 0 0xfebff400 - 0xfebff4ff (0x100) MX[B]
[3] -1 0 0xfebff800 - 0xfebff9ff (0x200) MX[B]
[4] -1 0 0x50100000 - 0x501003ff (0x400) MX[B]
[5] -1 0 0xfebffc00 - 0xfebfffff (0x400) MX[B]
[6] -1 0 0xf8000000 - 0xf7ffffff (0x0) MX[B]O
[7] -1 0 0xfe9e0000 - 0xfe9fffff (0x20000) MXB
[8] -1 0 0xe8000000 - 0xefffffff (0x8000000) MXB
[9] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MXB
[10] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[11] -1 0 0x0000dc00 - 0x0000dc7f (0x80) IX[B]
[12] -1 0 0x0000ee80 - 0x0000eebf (0x40) IX[B]
[13] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[14] -1 0 0x00000400 - 0x0000041f (0x20) IX[B]
[15] -1 0 0x0000ef60 - 0x0000ef6f (0x10) IX[B]
[16] -1 0 0x0000efa8 - 0x0000efab (0x4) IX[B]
[17] -1 0 0x0000efa0 - 0x0000efa7 (0x8) IX[B]
[18] -1 0 0x0000efac - 0x0000efaf (0x4) IX[B]
[19] -1 0 0x0000efe0 - 0x0000efe7 (0x8) IX[B]
[20] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[21] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[22] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[23] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[24] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[25] -1 0 0x0000ef80 - 0x0000ef9f (0x20) IX[B]
[26] -1 0 0x0000ef40 - 0x0000ef5f (0x20) IX[B]
[27] -1 0 0x0000ef20 - 0x0000ef3f (0x20) IX[B]
[28] -1 0 0x0000ef00 - 0x0000ef1f (0x20) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xfeaf8000 - 0xfeafbfff (0x4000) MX[B]
[5] -1 0 0xfeaff800 - 0xfeafffff (0x800) MX[B]
[6] -1 0 0xfebff400 - 0xfebff4ff (0x100) MX[B]
[7] -1 0 0xfebff800 - 0xfebff9ff (0x200) MX[B]
[8] -1 0 0x50100000 - 0x501003ff (0x400) MX[B]
[9] -1 0 0xfebffc00 - 0xfebfffff (0x400) MX[B]
[10] -1 0 0xf8000000 - 0xf7ffffff (0x0) MX[B]O
[11] -1 0 0xfe9e0000 - 0xfe9fffff (0x20000) MXB
[12] -1 0 0xe8000000 - 0xefffffff (0x8000000) MXB
[13] -1 0 0xfd000000 - 0xfdffffff (0x1000000) MXB
[14] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[15] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[16] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[17] -1 0 0x0000dc00 - 0x0000dc7f (0x80) IX[B]
[18] -1 0 0x0000ee80 - 0x0000eebf (0x40) IX[B]
[19] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[20] -1 0 0x00000400 - 0x0000041f (0x20) IX[B]
[21] -1 0 0x0000ef60 - 0x0000ef6f (0x10) IX[B]
[22] -1 0 0x0000efa8 - 0x0000efab (0x4) IX[B]
[23] -1 0 0x0000efa0 - 0x0000efa7 (0x8) IX[B]
[24] -1 0 0x0000efac - 0x0000efaf (0x4) IX[B]
[25] -1 0 0x0000efe0 - 0x0000efe7 (0x8) IX[B]
[26] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[27] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[28] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[29] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[30] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[31] -1 0 0x0000ef80 - 0x0000ef9f (0x20) IX[B]
[32] -1 0 0x0000ef40 - 0x0000ef5f (0x20) IX[B]
[33] -1 0 0x0000ef20 - 0x0000ef3f (0x20) IX[B]
[34] -1 0 0x0000ef00 - 0x0000ef1f (0x20) IX[B]
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module 173.14.09 Thu Jun 5 00:07:40 PDT 2008
(II) Loading extension GLX
(II) LoadModule: “freetype”
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 1.4.2, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.4.2, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: “nvidia”
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: X.Org Video Driver
(II) LoadModule: “mouse”
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 1.4.0.90, module version = 1.3.0
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: “kbd”
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 1.4.0.90, module version = 1.3.1
(II) NVIDIA dlloader X Driver 173.14.09 Wed Jun 4 23:47:25 PDT 2008
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(–) Assigning device section with no busID to primary device
(–) Chipset NVIDIA GPU found
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module “wfb”
(II) LoadModule: “wfb”
(II) Loading /usr/lib/xorg/modules//libwfb.so
(II) Module wfb: vendor=“X.Org Foundation"
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”(II) Module “ramdac” already built-in
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[14] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[15] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[16] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[18] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[19] -1 0 0x0000d800 - 0x0000d8ff (0x100) IX[B]
[20] -1 0 0x0000dc00 - 0x0000dc7f (0x80) IX[B]
[21] -1 0 0x0000ee80 - 0x0000eebf (0x40) IX[B]
[22] -1 0 0x0000e800 - 0x0000e8ff (0x100) IX[B]
[23] -1 0 0x00000400 - 0x0000041f (0x20) IX[B]
[24] -1 0 0x0000ef60 - 0x0000ef6f (0x10) IX[B]
[25] -1 0 0x0000efa8 - 0x0000efab (0x4) IX[B]
[26] -1 0 0x0000efa0 - 0x0000efa7 (0x8) IX[B]
[27] -1 0 0x0000efac - 0x0000efaf (0x4) IX[B]
[28] -1 0 0x0000efe0 - 0x0000efe7 (0x8) IX[B]
[29] -1 0 0x0000fc00 - 0x0000fc0f (0x10) IX[B]
[30] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[31] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[32] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[33] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[34] -1 0 0x0000ef80 - 0x0000ef9f (0x20) IX[B]
[35] -1 0 0x0000ef40 - 0x0000ef5f (0x20) IX[B]
[36] -1 0 0x0000ef20 - 0x0000ef3f (0x20) IX[B]
[37] -1 0 0x0000ef00 - 0x0000ef1f (0x20) IX[B]
[38] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[39] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
() NVIDIA(0): Depth 24, (–) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
() NVIDIA(0): Option “UseEDID” “FALSE”
() NVIDIA(0): Enabling RENDER acceleration
() NVIDIA(0): Ignoring EDIDs
(II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
(II) NVIDIA(0): enabled.
(II) NVIDIA(GPU-0): Not probing EDID on CRT-0.
(II) NVIDIA(0): NVIDIA GPU GeForce FX 5900XT (NV35) at PCI:1:0:0 (GPU-0)
(–) NVIDIA(0): Memory: 131072 kBytes
(–) NVIDIA(0): VideoBIOS: 04.35.20.38.00
(II) NVIDIA(0): Detected AGP rate: 8X
(–) NVIDIA(0): Interlaced video modes are supported on this GPU
(–) NVIDIA(0): Connected display device(s) on GeForce FX 5900XT at
(–) NVIDIA(0): PCI:1:0:0:
(–) NVIDIA(0): CRT-0
(–) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
(II) NVIDIA(0): Assigned Display Device: CRT-0
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0): “1280x1024”
(II) NVIDIA(0): “1152x864”
(II) NVIDIA(0): “1024x768”
(II) NVIDIA(0): “800x600”
(II) NVIDIA(0): “640x480”
(II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
(WW) NVIDIA(0): Unable to get display device CRT-0’s EDID; cannot compute DPI
(WW) NVIDIA(0): from CRT-0’s EDID.
(==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
(==) NVIDIA(0): Enabling 32-bit ARGB GLX visuals.
(–) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don’t.
(II) resource ranges after preInit:
(II) NVIDIA(0): Initialized AGP GART.
(II) NVIDIA(0): Setting mode “1280x1024”
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
() Option “dpms”
() NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
(WW) Configured Mouse: No Device specified, looking for one…
(II) Configured Mouse: Setting Device option to “/dev/input/mice”
(–) Configured Mouse: Device: “/dev/input/mice”
(==) Configured Mouse: Protocol: “Auto”
() Option “CorePointer”
() Configured Mouse: always reports core events
(==) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
() Configured Mouse: ZAxisMapping: buttons 4 and 5
() Configured Mouse: Buttons: 9
() Configured Mouse: Sensitivity: 1
() Option “CoreKeyboard”
() Generic Keyboard: always reports core events
() Option “Protocol” “standard”
() Generic Keyboard: Protocol: standard
() Option “AutoRepeat” “500 30”
() Option “XkbRules” “xorg”
() Generic Keyboard: XkbRules: “xorg”
() Option “XkbModel” “pc104”
() Generic Keyboard: XkbModel: “pc104”
() Option “XkbLayout” “fr”
() Generic Keyboard: XkbLayout: “fr”
() Option “XkbVariant” “latin9”
() Generic Keyboard: XkbVariant: “latin9”
() Option “XkbOptions” " altwin:meta_win"
() Generic Keyboard: XkbOptions: " altwin:meta_win”
() Option “CustomKeycodes” “off”
() Generic Keyboard: CustomKeycodes disabled
(II) evaluating device (Configured Mouse)
(II) XINPUT: Adding extended input device “Configured Mouse” (type: MOUSE)
(II) evaluating device (Generic Keyboard)
(II) XINPUT: Adding extended input device “Generic Keyboard” (type: KEYBOARD)
(–) Configured Mouse: PnP-detected protocol: “ExplorerPS/2”
(II) Configured Mouse: ps2EnableDataReporting: succeeded
(II) NVIDIA(0): Setting mode “1024x768_70”
(II) 3rd Button detected: disabling emulate3Button[/code]
merci d’avance
