Probleme graphique avec x-plane 9
il a pas de couleur et ses blanc partout
Fichier log.txt
[code]log.txt for X-Plane 9.21rc2 X-Plane 92102 compiled on Sep 23 2008 19:23:58
This log file is generated automatically by Laminar Research applications and contains diagnostics about your graphics hardware, installation, and any error conditions.
If you need to contact tech support or file a bug, please send us this file. NOTE: this file is rewritten every time you start ANY of your X-System applications.
If you got a hard system crash and want to report this to Laminar Research, then be sure to send your crash_report.txt file generated by the crash as well!
processor : 0
model name : Genuine Intel® CPU T2050 @ 1.60GHz
cpu MHz : 1600.000
processor : 1
cpu MHz : 800.000
MemTotal: 1026368 kB
X-System folder:’/home/alexandre/X-Plane 9/’, case sensitive=1
OpenGL Vendor : Tungsten Graphics, Inc
OpenGL Render : Mesa DRI Intel® 945GM 20061017 x86/MMX/SSE2
OpenGL Version : 1.3 Mesa 7.0.4 (130)
OpenGL Extensions: GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_cull_vertex GL_EXT_compiled_vertex_array GL_EXT_convolution GL_EXT_copy_texture GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_polygon_offset GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_vertex_array GL_3DFX_texture_compression_FXT1 GL_APPLE_client_storage GL_APPLE_packed_pixels GL_ATI_blend_equation_separate GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_MESA_window_pos GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texture_rectangle GL_NV_texgen_reflection GL_NV_vertex_program GL_NV_vertex_program1_1 GL_OES_read_format GL_SGI_color_matrix GL_SGI_color_table GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SUN_multi_draw_arrays
GLX Extensions: GLX_ARB_get_proc_address GLX_ARB_multisample GLX_EXT_import_context GLX_EXT_visual_info GLX_EXT_visual_rating GLX_MESA_allocate_memory GLX_MESA_copy_sub_buffer GLX_MESA_swap_control GLX_MESA_swap_frame_usage GLX_OML_swap_method GLX_OML_sync_control GLX_SGI_make_current_read GLX_SGI_swap_control GLX_SGI_video_sync GLX_SGIS_multisample GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGIX_visual_select_group GLX_EXT_texture_from_pixmap
use_vsync1 : 0
use_vsync2 : 0
tex_clamp_avail : 1
add_env_avail : 1
combine_avail : 1
dis_fog_avail : 0
tex_comp_avail : 1
vbo_avail : 1
pbo_avail : 0
vprog_avail : 1 (128)
fprog_avail : 1 (96/64/32/4)
automini_avail : 1
aniso_avail : 1
fsaa_avail : 1
sprites_avail : 0
depth_tex_avail : 1
occlude_avail : 0
shad_objs_avail : 0
vshader_avail : 0 (0/0/0/0/0/0)
fshader_avail : 0 (0)
gshader_avail : 0
buniform_avail : 0
glsl_avail : 0 (n/a)
framebuf_avail : 0
sblend_avail : 1
tex_float_avail : 0
packed_stencil : 0
threaded_avail : 1
first-gen shaders: 1
max tex units : 8 (8/8)
max iso filtering: 2.000000
max texture size : 2048
max point size : 3.000000
CPU count : 2
Unable to get config from visual. Using main window.
Fetching plugins for /home/alexandre/X-Plane 9/Resources/plugins
Loaded: /home/alexandre/X-Plane 9/Resources/plugins/PluginAdmin/lin.xpl.
OpenAL version : 1.0
OpenAL hardware :
OpenAL extensions:
I found the following scenery packages (prioritized in this order):
0 Custom Scenery/KSBD Demo Area/
1 Custom Scenery/LOWI Demo Area/
2 Custom Scenery/LOWI Demo overlay/
3 Custom Scenery/LOWI Demo terrain/
4 Custom Scenery/Mars Demo Area/
5 Resources/default scenery/700 roads/
6 Resources/default scenery/900 beaches/
7 Resources/default scenery/900 europe objects/
8 Resources/default scenery/900 forests/
9 Resources/default scenery/900 roads/
10 Resources/default scenery/900 us objects/
11 Resources/default scenery/900 world object placeholders/
12 Resources/default scenery/900 world terrain/
13 Resources/default scenery/default apt dat/
14 Resources/default scenery/sim objects/
Starting scenery shift at 0
DSF rotate time: 2 for 0 DSFs.
DEF load time: 9740 for water.
OK check MemoryLog.txt! I just sent him a dump from This is the dump_mem_stats call from the following code: if(type==t_exit || type == t_alert || recursive_error)
J’ai trouvé une zone sans paysage installé! Vous ne verrez rien d’autre que de l’eau autour des aéroports dans la mesure où aucun paysage ,n’est installé dans cette zone!
Achetez des DVD de paysages sur www.X-Plane.com. Email info@X-Plane.com si vous avez besoin d’aide pour l’installation. Allez sur LOWI pour retourner dans la zone démo!
Désactivez cette alerte dans la fenêtre ‘Opérations et alertes’ dans le menu ‘Paramètres’ pour annuler cette alerte.
Le fichier manquant est +30-130/+37-124.dsf.
(/home/bsupnik/code/design/HLutils/REN/REN_region.cpp line 621)
DEF load time: 10662 for water.
DEF load time: 15445 for water.
DEF load time: 9413 for water.
DEF load time: 9281 for water.
DEF load time: 10005 for water.
Preload time: 939618.
Starting scenery shift at 64
DSF rotate time: 3 for 0 DSFs.
DSF load time: 1485753 for file Custom Scenery/LOWI Demo overlay/Earth nav data/+40+010/+46+010.dsf
DSF load time: 4661728 for file Custom Scenery/LOWI Demo terrain/Earth nav data/+40+010/+46+010.dsf
DSF load time: 3325460 for file Custom Scenery/LOWI Demo overlay/Earth nav data/+40+010/+46+011.dsf
DSF load time: 3583792 for file Custom Scenery/LOWI Demo terrain/Earth nav data/+40+010/+46+011.dsf
DSF load time: 218359 for file Custom Scenery/LOWI Demo overlay/Earth nav data/+40+010/+46+012.dsf
DSF load time: 3814221 for file Custom Scenery/LOWI Demo terrain/Earth nav data/+40+010/+46+012.dsf
DSF load time: 278836 for file Custom Scenery/LOWI Demo overlay/Earth nav data/+40+010/+47+010.dsf
DSF load time: 3484026 for file Custom Scenery/LOWI Demo terrain/Earth nav data/+40+010/+47+010.dsf
DSF load time: 3538333 for file Custom Scenery/LOWI Demo Area/Earth nav data/+40+010/+47+011.dsf
DSF load time: 309933 for file Custom Scenery/LOWI Demo overlay/Earth nav data/+40+010/+47+011.dsf
DSF load time: 3361043 for file Custom Scenery/LOWI Demo terrain/Earth nav data/+40+010/+47+011.dsf
DSF load time: 209214 for file Custom Scenery/LOWI Demo overlay/Earth nav data/+40+010/+47+012.dsf
DSF load time: 3927209 for file Custom Scenery/LOWI Demo terrain/Earth nav data/+40+010/+47+012.dsf
Preload time: 4998430.
Apres avoir fermé cette fenêtre d’alarme, faites vibrer les axes.
By watching what axis moves when you do this, assign each axis to the right function in X-Plane.
Après avoir assigné chaque axe, déplacez le au Maximum pour le calibrer
Puis appuyez sur chaque bouton et selectionnez sur la droite la fonction de ce bouton.
(/home/bsupnik/code/design/HLutils/OOPS_cpp/joys.cpp line 1009)
X-Plane and X-Planner are now here for the iPhone and iPodTouch!
The iPhone version of X-Plane is so fun it is crazy… you TILT the phone to fly!
X-Planner is a flight planner for pilots that will let you choose altitudes and see your time and fuel burn on your iPhone! COOL!
Go to iTunes, then the App Store, and search X-Plane or X-Planner! Or just see the links at the top of www.X-Plane.com! The Planner will pay for itself in only one use!
(/home/bsupnik/code/design/HLutils/GenC/hl_mnw.cpp line 1751)
Clean exit from threads.[/code]
Envoie le tien Yan.
voici mon log.txt
processor : 0
cpu MHz : 800.000
processor : 1
cpu MHz : 800.000
X-System folder:’/home/yan/X-Plane 9 /’, case sensitive=1
use_vsync1 : 0
use_vsync2 : 0
tex_clamp_avail : 1
add_env_avail : 1
combine_avail : 1
dis_fog_avail : 0
tex_comp_avail : 1
vbo_avail : 1
pbo_avail : 0
automini_avail : 1
aniso_avail : 1
fsaa_avail : 1
sprites_avail : 0
depth_tex_avail : 1
occlude_avail : 0
shad_objs_avail : 0
gshader_avail : 0
buniform_avail : 0
framebuf_avail : 0
sblend_avail : 1
tex_float_avail : 0
packed_stencil : 0
threaded_avail : 1
CPU count : 2
Fetching plugins for /home/yan/X-Plane 9 /Resources/plugins
Loaded: /home/yan/X-Plane 9 /Resources/plugins/PluginAdmin/lin.xpl.
OpenAL hardware :
OpenAL extensions:
Pour preciser, c’est qu’il n’y a aucune texture, sur les decors et sur les avions
