J’ai installer debian un peu partout. J’aimerai aussi l’installer sur un vieux PC portable (config : 256 Mo RAM et 500 Mhz PIII 80)
Le problème vient de la carte vidéo, qui est une :
Neomagic Corporation NM2200 selon lspci
Voici mon fichier /etc/X11/xorg.conf
[code]# xorg.conf (xorg X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the xorg.conf manual page.
(Type “man xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option “XkbRules” "xorg"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
Option “XkbVariant” "latin9"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/psaux"
Option “Protocol” "PS/2"
Option “Emulate3Buttons” "true"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option “SendCoreEvents” "true"
Option “Protocol” "auto-dev"
Option “HorizScrollDelta” "0"
EndSection
Section "Device"
Identifier "Neomagic Corporation NM2200 [MagicGraph 256AV]"
Driver "neomagic"
BusID "PCI:1:0:0"
Option “UseFBDev” "true"
EndSection
Section "Monitor"
Identifier "Écran générique"
Option "DPMS"
HorizSync 28-38
VertRefresh 43-72
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Neomagic Corporation NM2200 [MagicGraph 256AV]"
Monitor "Écran générique"
DefaultDepth 24
SubSection "Display"
Modes "800x600"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "Synaptics Touchpad"
EndSection[/code]
Dans la section device, driver est neomagic. Si maintenant, je remplace neomagic par vesa, mon affichage est correcte (le problème est qu’il y as des ralentissement (comme si pour un windowsien les pilotes de la cartes graphique n’était pas présent).
Mais depuis que j’ai ajouter ces sources si dans mon sourcelist, j’ai de nouveau des problème d’affichage :
deb ftp://ftp.fr.debian.org/debian/ testing main contrib non-free
deb-src ftp://ftp.fr.debian.org/debian/ testing main contrib non-free
Tout est vert, même google
Avec un
dpkg-reconfigure xserver-xorg
il me remet les driver neomagic par default.
QU’avez vous à me proposer comme solution ??
Merci d’avance.
