Merci de vos réponses.
J’ai bien python 2.7
ls -l /usr/bin/python renvoit
lrwxrwxrwx 1 root root 9 févr. 8 2013 /usr/bin/python -> python2.7
hp-check
M’indique que hplip n’est pas compatible avec debian 7.1 et propose de mettre la version 6.
Ceci dit je comprends pas tout ce que renvoi cette commande.
[code]HP Linux Imaging and Printing System (ver. 3.13.9)
Dependency/Version Check Utility ver. 15
Copyright © 2001-14 Hewlett-Packard Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Note: hp-check can be run in three modes:
- Compile-time check mode (-c or --compile): Use this mode before compiling the
HPLIP supplied tarball (.tar.gz or .run) to determine if the proper dependencies
are installed to successfully compile HPLIP.
- Run-time check mode (-r or --run): Use this mode to determine if a distro
supplied package (.deb, .rpm, etc) or an already built HPLIP supplied tarball
has the proper dependencies installed to successfully run.
- Both compile- and run-time check mode (-b or --both) (Default): This mode
will check both of the above cases (both compile- and run-time dependencies).
Check types:
a. EXTERNALDEP - External Dependencies
b. GENERALDEP - General Dependencies (required both at compile and run time)
c. COMPILEDEP - Compile time Dependencies
d. [All are run-time checks]
PYEXT SCANCONF QUEUES PERMISSION
Status Types:
OK
MISSING - Missing Dependency or Permission or Plug-in
INCOMPAT - Incompatible dependency-version or Plugin-version
Saving output in log file: /home/franck/hp-check.log
Initializing. Please wait…
warning: debian-7.1 version is not supported. Using debian-6.0.5 versions dependencies to verify and install…
Kernel: 3.2.0-4-amd64 #1 SMP Debian 3.2.46-1+deb7u1 GNU/Linux
Host: debian
Proc: 3.2.0-4-amd64 #1 SMP Debian 3.2.46-1+deb7u1 GNU/Linux
Distribution: debian 7.1
HPLIP-Version: HPLIP 3.13.9
HPLIP-Home: /usr/share/hplip
warning: HPLIP-Installation: Auto installation is not supported for debian distro 7.1 version
Current contents of ‘/etc/hp/hplip.conf’ file:
hplip.conf. Generated from hplip.conf.in by configure.
[hplip]
version=3.13.9
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/hplip/HP
ppdbase=/usr/share/ppd/hplip
doc=/usr/share/doc/hplip-3.13.9
icon=/usr/share/applications
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv/hp
bin=/usr/bin
Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
libusb01-build=no
pp-build=no
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=no
foomatic-drv-install=no
foomatic-ppd-install=no
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.13.9
restricted-build=no
ui-toolkit=qt4
qt3=no
qt4=yes
policy-kit=no
lite-build=no
udev-acl-rules=no
udev_sysfs_rules=no
hpcups-only-build=no
hpijs-only-build=no
Current contents of ‘/var/lib/hp/hplip.state’ file:
Plugins are not installed. Could not access file: Aucun fichier ou dossier de ce type
Current contents of ‘~/.hplip/hplip.conf’ file:
[upgrade]
notify_upgrade = true
last_upgraded_time = 1380347006
pending_upgrade_time = 0
[installation]
date_time = 29/09/2013 13:00:08
version = 3.13.9
<Required/Optional>
gs Ghostscript REQUIRED 7.05 9.05 OK -
network Network-wget OPTIONAL - 1.13.4 OK -
dbus DBus REQUIRED - 1.6.8 OK -
scanimage Shell-Scanning OPTIONAL 1.0 1.0.22 OK -
policykit Admin-Policy-framework OPTIONAL - 0.105 OK -
xsane SANE-GUI OPTIONAL 0.9 0.998 OK -
cups CUPS REQUIRED 1.1 1.5.3 OK ‘CUPS Scheduler is running’
reportlab Python-PDF-Lib OPTIONAL 2.0 2.5 OK -
libcrypto OpenSSL-Crypto-Lib REQUIRED - 1.0.1 OK -
pil Python-Image-Lib OPTIONAL - 1.1.7 OK -
pyqt4-dbus PyQt4-DBUS REQUIRED 4.0 4.9.3 OK -
libjpeg JPEG-Lib REQUIRED - - OK -
libpthread POSIX-Threads-Lib REQUIRED - 2.13 OK -
python-dbus Python-DBUS REQUIRED 0.80.0 1.1.1 OK -
python-devel Python-SDK REQUIRED 2.2 2.7.3 OK -
pyqt4 Python-Qt4 REQUIRED 4.0 4.9.3 OK -
cups-devel CUPS-SDK REQUIRED - 1.5.3 OK -
sane-devel SANE-SDK REQUIRED - 1.0.22 OK -
libusb USB-Lib REQUIRED - 1.0 OK -
sane Scan-Lib REQUIRED - 1.0.22 OK -
cups-image CUPS-Image-Lib REQUIRED - 1.5.3 OK -
libnetsnmp-devel SNMP-Networking-SDK REQUIRED 5.0.9 5.4.3 OK -
python-xml Python-XML-Lib REQUIRED - 2.1.0 OK -
python-notify Desktop-notifications OPTIONAL - - OK -
| Compile Time Dependencies |
gcc gcc-Compiler REQUIRED - 4.7.2 OK -
libtool Build-tools REQUIRED - 2.4.2 OK -
make GNU-Build-tools REQUIRED 3.0 3.81 OK -
cupsext CUPS-Extension REQUIRED - 3.13.9 OK -
pcardext PhotoCard-Extension REQUIRED - 3.13.9 OK -
error: NOT FOUND OR FAILED TO LOAD! Please reinstall HPLIP and check for the proper installation of hpmudext.
error: hpmudext IO-Extension REQUIRED - 3.13.9 MISSING ‘Not Found or Failed to load, Please reinstall HPLIP’
hpaio HPLIP-SANE-Backend REQUIRED - 3.13.9 OK 'hpaio found in /etc/sane.d/dll.conf’
scanext Scan-SANE-Extension REQUIRED - 3.13.9 OK -
| DISCOVERED SCANNER DEVICES |
No Scanner found.
| INSTALLED CUPS PRINTER QUEUES |
Photosmart_Premium_C309g-m
Type: Printer
Device URI: hp:/usb/Photosmart_Premium_C309g-m?serial=MY9BP5706K05D7
PPD: /etc/cups/ppd/Photosmart_Premium_C309g-m.ppd
PPD Description: HP Photosmart Premium c309g-m, hpcups 3.12.6
Printer status: printer Photosmart_Premium_C309g-m is idle. enabled since sam. 28 sept. 2013 06:51:48 CEST
Photosmart_Premium_C309g-m_2
Type: Printer
PPD: /etc/cups/ppd/Photosmart_Premium_C309g-m_2.ppd
PPD Description: HP Photosmart Premium c309g-m, hpcups 3.13.9
Printer status: printer Photosmart_Premium_C309g-m_2 is idle. enabled since sam. 28 sept. 2013 07:44:48 CEST
groups user-groups Required - - OK franck lp cdrom floppy audio dip video plugdev scanner lpadmin bluetooth netdev
Missing Required Dependencies
error: ‘hpmudext’ package is missing/incompatible
Missing Optional Dependencies
None
Total Errors: 1
Total Warnings: 0
Re-run ‘hp-check --fix’ command to prompt and fix the issues.
Done.
franck@debian:~$ ^C
franck@debian:~$
Je crois avoir compris qu’il faudrait la dernière version de hplip la 3.13.9. Je l’avais bien installé en suivant les instruction du site HP mais lorsque j’installe hplip-gui avec synaptic il n’installe d’office la version précédente d’hplip.
Les deux versions restent installées comme le montre (je crois)
gedit /etc/cups/printers.conf
[code]# Printer configuration file for CUPS v1.5.3
Written by cupsd
DO NOT EDIT THIS FILE WHEN CUPSD IS RUNNING
UUID urn:uuid:ee5fffe5-d0b9-3bac-55f8-1b4f54915c79
Info Photosmart_Premium_C309g-m
MakeModel HP Photosmart Premium c309g-m, hpcups 3.12.6
DeviceURI hp:/usb/Photosmart_Premium_C309g-m?serial=MY9BP5706K05D7
State Idle
StateTime 1380343908
Type 36876
Accepting Yes
Shared Yes
JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
OpPolicy default
ErrorPolicy stop-printer
UUID urn:uuid:71f63fd7-3bbc-32a3-692d-61c1e5326bc2
Info Photosmart_Premium_C309g-m_2
MakeModel HP Photosmart Premium c309g-m, hpcups 3.13.9
State Idle
StateTime 1380347088
Type 36892
Accepting Yes
Shared Yes
JobSheets none none
QuotaPeriod 0
PageLimit 0
KLimit 0
OpPolicy default
Peut-être que quelqu'un d'expérimenté peut y voir une amorce de solution...
