Voilà j’ai un soucis à l’installation de alternc sur mon serveur dédié.
avec un apt-get install alternc (alternc à l’air déetre installé, mais un probleme de config arrive)
Reading package lists... Done
Building dependency tree... Done
alternc is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0B of archives.
After unpacking 0B of additional disk space will be used.
Setting up alternc (0.9.9) ...
An override for "/var/spool/postfix/var/run/saslauthd" already exists, aborting
Updating /etc/alternc/local.sh
Granting users...
Trying debian.cnf: ERROR 1045 (28000) at line 1: Access denied for user 'debian-sys-maint'@'localhost' (using password: YES)
failed: debian-sys-maintainer doesn't have the right credentials
are we doing an upgrade? Could not open required defaults file: /etc/alternc/my.cnf
Fatal error in defaults handling. Program aborted
No
Assuming clean install (empty root password)... ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
Failed
Assuming pre 0.9.8 version... ERROR 1045 (28000): Access denied for user '-p'@'localhost' (using password: NO)
No.
Can't grant system user sysusr, aborting
dpkg: error processing alternc (--configure):
subprocess post-installation script returned error exit status 1
Errors were encountered while processing:
alternc
La premiere erreur à l’air d’etre due à mysql qui demande un pass root
Un peu normal, vu que j’ai déjà mon serveur opérationnel en http php mysql…
pouvez vous m’aider.
merci
