Bonjour a tous. J’essaye depuis quelque temps d’installer vmware. Mais lorsque je lance /usr/bin/vmware-config.pl voici ce qui me retourne :
Making sure services for VMware Server are stopped.
Stopping VMware autostart virtual machines:
Virtual machines failed
Stopping VMware management services:
VMware Virtual Infrastructure Web Access
VMware Server Host Agent failed
Stopping VMware services:
VMware Authentication Daemon done
Virtual machine monitor done
None of the pre-built vmmon modules for VMware Server is suitable for your
running kernel. Do you want this program to try to build the vmmon module for
your system (you need to have a C compiler installed on your system)? [yes]
Using compiler “/usr/bin/gcc”. Use environment variable CC to override.
Your kernel was built with “gcc” version “4.3.5”, while you are trying to use
"/usr/bin/gcc" version “4.4.5”. This configuration is not recommended and
VMware Server may crash if you’ll continue. Please try to use exactly same
compiler as one used for building your kernel. Do you want to go with compiler
"/usr/bin/gcc" version “4.4.5” anyway? [no] y
What is the location of the directory of C header files that match your running
kernel? [/lib/modules/2.6.32-5-amd64/build/include]
Extracting the sources of the vmmon module.
Building the vmmon module.
Using 2.6.x kernel build system.
make: entrant dans le répertoire « /tmp/vmware-config0/vmmon-only »
make -C /lib/modules/2.6.32-5-amd64/build/include/… SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: entrant dans le répertoire « /usr/src/linux-headers-2.6.32-5-amd64 »
/tmp/vmware-config0/vmmon-only/Makefile:106: *** Inappropriate build environment: you wanted to use gcc version 4.4.5 while kernel attempts to use gcc version 4.3.5.
/tmp/vmware-config0/vmmon-only/Makefile:108: *** For proper build you’ll have to replace gcc-4.3 with symbolic link to /usr/bin/gcc. Arrêt.
make[3]: *** [module/tmp/vmware-config0/vmmon-only] Erreur 2
make[2]: *** [sub-make] Erreur 2
make[1]: *** [all] Erreur 2
make[1]: quittant le répertoire « /usr/src/linux-headers-2.6.32-5-amd64 »
make: *** [vmmon.ko] Erreur 2
make: quittant le répertoire « /tmp/vmware-config0/vmmon-only »
Unable to build the vmmon module.
For more information on how to troubleshoot module-related problems, please
visit our Web site at “http://www.vmware.com/go/unsup-linux-products” and
"http://www.vmware.com/go/unsup-linux-tools".
Execution aborted.
Je ne sais plus quoi faire. Merci de bien vouloir m’aider !
