/var/lib/dpkg/info/mysql-server-5.1.postinst configure :
root@Cloud-Jouin:~# /var/lib/dpkg/info/mysql-server-5.1.postinst configure
Stopping MySQL database server: mysqld.
130303 17:45:51 [Note] Plugin 'FEDERATED' is disabled.
130303 17:45:51 InnoDB: Initializing buffer pool, size = 8.0M
130303 17:45:51 InnoDB: Completed initialization of buffer pool
130303 17:45:51 InnoDB: Started; log sequence number 0 44233
130303 17:45:51 InnoDB: Starting shutdown...
130303 17:45:56 InnoDB: Shutdown completed; log sequence number 0 44233
Starting MySQL database server: mysqld . . . . . . . . . . . . . . failed!
invoke-rc.d: initscript mysql, action "start" failed.
édit :
aptitude purge ~c :
root@Cloud-Jouin:~# aptitude purge ~c
Aucun paquet ne va être installé, mis à jour ou enlevé.
0 paquets mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 0 o d'archives. Après dépaquetage, 0 o seront utilisés.
s s duu
find / -name “mysql” :
root@Cloud-Jouin:~# find / -name "*mysql*"
/etc/rc5.d/S02mysql
/etc/mysql
/etc/rc0.d/K01mysql
/etc/rc6.d/K01mysql
/etc/rc1.d/K01mysql
/etc/rc3.d/S02mysql
/etc/rc2.d/S02mysql
/etc/rc4.d/S02mysql
/mnt/HD/HD_a2/.systemfile/squeeze/var/lib/mysql
/mnt/HD/HD_a2/.systemfile/squeeze/var/lib/mysql/mysql
find: Boucle détectée dans le système de fichiers ; ""/mnt/HD/HD_a2/squeeze"" est dans la même boucle que "/".
/mnt/root/lib/libmysqlclient.so.16
/mnt/root/lib/libmysqlclient_r.so.16
/mnt/root/usr/sbin/mysqlmgr
/mnt/root/usr/sbin/startup-mysql
/mnt/root/usr/share/mysql
/mnt/root/usr/bin/mysqladmin
/mnt/root/usr/bin/mysqld_safe
/mnt/root/usr/bin/mysql_secure_installation
/mnt/root/usr/bin/mysql_install_db
/var/lib/mysql
/var/lib/update-rc.d/mysql
/var/cache/apt/archives/mysql-server-5.1_5.1.66-0+squeeze1_armel.deb
/var/cache/apt/archives/mysql-server-core-5.1_5.1.66-0+squeeze1_armel.deb
/var/cache/apt/archives/mysql-client-5.1_5.1.66-0+squeeze1_armel.deb
/var/cache/apt/archives/mysql-common_5.1.66-0+squeeze1_all.deb
/var/cache/apt/archives/libmysqlclient16_5.1.66-0+squeeze1_armel.deb
/var/cache/apt/archives/libdbd-mysql-perl_4.016-1_armel.deb
/var/cache/apt/archives/mysql-server_5.1.66-0+squeeze1_all.deb
/var/log/mysql.log
/var/log/mysql
/var/log/mysql.err
/var/tmp/phpmyadmin.phpmyadmin.2013-03-01-00.22.mysql.RfC3tg
/var/run/mysqld
/usr/share/doc/dbconfig-common/examples/db-test-mysql-frontend-2.0
/usr/share/doc/dbconfig-common/examples/db-test-mysql-perl-2.0
/usr/share/doc/dbconfig-common/examples/db-test-mysql-perl-2.0/mysql-install.pl
/usr/share/doc/dbconfig-common/examples/db-test-multidbtype-2.0/mysql.sql
/usr/share/doc/dbconfig-common/examples/db-test-mysql-2.1
/usr/share/doc/dbconfig-common/examples/db-test-mysql-2.1/mysql-upgrade_2.1.sql
/usr/share/doc/dbconfig-common/examples/db-test-mysql-2.1/mysql.sql
/usr/share/doc/dbconfig-common/examples/db-test-mysql-2.0
/usr/share/doc/dbconfig-common/examples/db-test-mysql-2.0/mysql.sql
/usr/share/wwwconfig-common/mysql-createuser.sh
/usr/share/wwwconfig-common/mysql-dropdb.sh
/usr/share/wwwconfig-common/mysql-ifnot-exec.sh
/usr/share/wwwconfig-common/mysql.get
/usr/share/wwwconfig-common/mysql.func
/usr/share/wwwconfig-common/mysql-localadmpass.get
/usr/share/wwwconfig-common/mysql-if-exec.sh
/usr/share/wwwconfig-common/mysql-createdb.sh
/usr/share/wwwconfig-common/mysql-dropuser.sh
/usr/share/wwwconfig-common/mysql-exec.sh
/usr/share/dbconfig-common/internal/mysql
/usr/share/dbconfig-common/dpkg/config.mysql
/usr/share/dbconfig-common/dpkg/frontend.postrm.mysql
/usr/share/dbconfig-common/dpkg/frontend.config.mysql
/usr/share/dbconfig-common/dpkg/postrm.mysql
/usr/share/dbconfig-common/dpkg/preinst.mysql
/usr/share/dbconfig-common/dpkg/frontend.postinst.mysql
/usr/share/dbconfig-common/dpkg/frontend.prerm.mysql
/usr/share/dbconfig-common/dpkg/frontend.preinst.mysql
/usr/share/dbconfig-common/dpkg/prerm.mysql
/usr/share/dbconfig-common/dpkg/postinst.mysql
rm /etc/init.d/mysql :
root@Cloud-Jouin:~# rm /etc/init.d/mysql
rm: impossible de supprimer « /etc/init.d/mysql »: Aucun fichier ou dossier de ce type
