J’ai installé récemment une debian 9.2(Stretch) sur deux machines un pc portable et un pc Fixe.J’ai pris une ISO Debian 9.2(Stretch) DVD 1 lorsque j’ai voulu installer le logiciel packettracer ou d’autres je rencontre le problème suivant:
ramalingompoulle@PCWORK:~$ su
Mot de passe :
root@PCWORK:/home/ramalingompoulle# cd Téléchargements
root@PCWORK:/home/ramalingompoulle/Téléchargements# cd PacketTracer63
root@PCWORK:/home/ramalingompoulle/Téléchargements/PacketTracer63# '/home/ramalingompoulle/Téléchargements/PacketTracer63/install'
Welcome to Cisco Packet Tracer 6.3 Installation
Read the following End User License Agreement "EULA" carefully. You must accept the terms of this EULA to install and use Cisco Packet Tracer.
Press the Enter key to read the EULA.
Cisco Packet Tracer
Software License Agreement
IMPORTANT: PLEASE READ THIS CISCO PACKET TRACER SOFTWARE LICENSE AGREEMENT (THE
"AGREEMENT") CAREFULLY. DOWNLOADING, INSTALLING OR USING THE CISCO PACKET
TRACER SOFTWARE CONSTITUTES ACCEPTANCE OF THIS AGREEMENT. IF YOU DO NOT AGREE
TO ALL OF THE TERMS OF THIS AGREEMENT, THEN CISCO SYSTEMS, INC. ("CISCO") IS
UNWILLING TO LICENSE THE SOFTWARE TO YOU AND YOU ARE NOT AUTHORIZED TO
DOWNLOAD, INSTALL OR USE THE SOFTWARE.
I. DISTRIBUTION RIGHTS. The terms in this Section I ("Distribution
Rights") of the Agreement apply solely to any Cisco Networking Academy
instructor, administrator or other person or entity approved in writing by
Cisco Systems, Inc. (each, an "Instructor") to distribute and use the Cisco
Packet Tracer software and related documentation (collectively, the "Software")
in accordance with the terms and conditions of this Agreement.
Subject to the terms and conditions of the End User License Agreement
set forth in Section II below (the "EULA"), Cisco grants Instructor a
limited, nonexclusive, nontransferable license to distribute the
Software using the Permitted Distribution Methods (defined below),
during the term of the Agreement to Permitted End Users (defined below)
solely as reasonably necessary to provide networking training or
Do you accept the terms of the EULA? (Y)es/(N)o
Yes
You have accepted the terms to the EULA. Congratulations. Packet Tracer will now be installed.
Enter location to install Cisco Packet Tracer or press enter for default [/opt/pt]:
It appears that Packet Tracer is already installed. Do you wish to replace it? [Yn] Y
Installing into /opt/pt
Copied all files successfully to /opt/pt
Installing 32 bit libraries for Packet Tracer.
Les paquets suivants ont été installés automatiquement et ne sont plus nécessaires :
libminizip1 libre2-3
Veuillez utiliser « apt autoremove » pour les supprimer.
The following additional packages will be installed:
libc6-i386
lib32z1 libc6-i386
0 mis à jour, 2 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de prendre 0 o/2 684 ko dans les archives.
Après cette opération, 11,7 Mo d'espace disque supplémentaires seront utilisés.
Media change: please insert the disc labeled
'Debian GNU/Linux 9.2.1 _Stretch_ - Official amd64 DVD Binary-1 20171013-13:09'
in the drive '/media/cdrom/' and press [Enter]
^C
Est-ce un problème de dépots ou du sources.list svp ?
