Bonjour, je ne peut plus installer un paquet, aurait t’il une manipulation pour restaurer les souces.list , j’ai un message depends :
The following packages have unmet dependencies:
libevent-2.1-6 : Depends: libc6 (>= 2.17) but 2.13-38+deb7u12 is to be installed
libtirpc1 : Depends: libc6 (>= 2.16) but 2.13-38+deb7u12 is to be installed
Depends: libgssapi-krb5-2 (>= 1.14+dfsg) but 1.10.1+dfsg-5+deb7u8 is to be installed
nfs-common : Depends: libc6 (>= 2.15) but 2.13-38+deb7u12 is to be installed
Depends: libdevmapper1.02.1 (>= 2:1.02.97) but 2:1.02.74-8 is to be installed
Depends: libkeyutils1 (>= 1.5.9) but 1.5.5-3+deb7u1 is to be installed
Depends: init-system-helpers (>= 1.18~) but it is not going to be installed
Depends: keyutils but it is not going to be installed
phpmyadmin : Depends: libapache2-mod-php5 but it is not going to be installed or
libapache2-mod-php5filter but it is not going to be installed or
php5-cgi but it is not going to be installed or
php5-fpm but it is not going to be installed or
Depends: php5-mysql but it is not going to be installed or
php5-mysqli but it is not installable or
php5-mysqlnd but it is not going to be installed
Depends: php5-mcrypt but it is not going to be installed
Recommends: php5-gd but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
