Tout d abord, heureux de rejoindre la communauté! En tant que WebDesigner, j’en suis venu à configurer moi même mon serveur et j’ai choisi d’y installer Debian (lenny) et j’en suis très content!
J’essaye donc d’installer ffmpeg et d’activer l’option vhook afin d’ajouter un watermark dans mes vidéos.
Donc je suis scrupuleusement un tutoriel pour installer les dépendances:
[code]
Step 1: Install some required system libraries
apt-get install ruby make nasm zlib1g-dev wget autoconf automake libtool g++ subversion
Step 2: Download and install FLVTool
FLVTool2 is a manipulation tool for Macromedia Flash Video files
wget http://rubyforge.org/frs/download.php/17497/flvtool2-1.0.6.tgz
tar -zxf flvtool2-1.0.6.tgz
cd flvtool2-1.0.6
ruby setup.rb
cd …/
Step 3: Download and install LAME
LAME: LAME Ain’t an MP3 Encoder
wget http://downloads.sourceforge.net/lame/lame-3.97.tar.gz
tar -zxf lame-3.97.tar.gz
cd lame-3.97
./configure --disable-decoder --enable-nasm && make && make install
cd …/
Step 4: Download and install FAAD
FAAD: Freeware Advanced Audio Coder and Decoder
wget http://downloads.sourceforge.net/faac/faad2-2.6.1.tar.gz
tar -zxf faad2-2.6.1.tar.gz
cd faad2
autoreconf -vif && ./configure --with-mp4v2 && make && make install
cd …/
Step 5: Download and install FAAC
FAAC: Freeware Advanced Audio Coder and Decoder
wget http://downloads.sourceforge.net/faac/faac-1.26.tar.gz
tar -zxf faac-1.26.tar.gz
cd faac
autoreconf -vif && ./configure && make && make install
cd …/
Step 6: Download and install YASM
YASM: Yasm, the modular assembler
wget http://www.tortall.net/projects/yasm/releases/yasm-0.7.1.tar.gz
tar -zxvf yasm-0.7.1.tar.gz
cd yasm-0.7.1
cd …/
Step 7: Download and install x264
x264: x264 is a free library for encoding H264/AVC video streams
wget http://downloads.videolan.org/pub/videolan/x264/snapshots/x264-snapshot-20080702-2245.tar.bz2
bunzip2 x264-snapshot-20080702-2245.tar.bz2
tar -xvf x264-snapshot-20080702-2245.tar
cd x264-snapshot-20080702-2245
./configure --enable-pthread --enable-shared --prefix=/usr && make && make install
cd …/[/code]
Puis j’utilise le svn de ffmpeg de cette façon:
svn checkout -r17768 svn://svn.ffmpeg.org/ffmpeg/trunk ffmpeg
cd fmmpeg
./configure --enable-vhook --enable-shared --enable-libdc1394 --enable-gpl --enable-libfaac --enable-libfaad --enable-libfaadbin --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libxvid --enable-libx264 --enable-libamr-nb --enable-libamr-wb --enable-nonfree && make && make install
Là, Putty m’indique qu’il y a une erreur avec le svn.
J’ai lu quelque part qu’il fallait installer imlib et imlib2 vous avez des infos là dessus?
Merci à vous!
