Bonjour, je ne comprend pas ce que celà signifie?
jambert@debian:~$ ./indigo/indigo
./indigo/indigo: symbol lookup error: ./indigo/indigo: undefined symbol: _Z13qFlagLocationPKc
mince ma boule de cristal est en panne ![]()
Indigo est un moteur de rendu 3d, l’interface graphique a changé depuis peu, je n’avais aucun problème avec la version précédente.
voiçi le site http://www.indigorenderer.com/
sinon j’ai essayé d’installer la dernière version de GTK+, la 2.16, quand je compile voilà ce qu’il m’affiche
[code]jambert@debian:~/gtk+$ ./configure
checking for a BSD-compatible install… /usr/bin/install -c
checking whether build environment is sane… yes
checking for gawk… no
checking for mawk… mawk
checking whether make sets $(MAKE)… yes
checking build system type… x86_64-unknown-linux-gnu
checking host system type… x86_64-unknown-linux-gnu
checking for native Win32… no
checking for gcc… gcc
checking for C compiler default output file name… a.out
checking whether the C compiler works… yes
checking whether we are cross compiling… no
checking for suffix of executables…
checking for suffix of object files… o
checking whether we are using the GNU C compiler… yes
checking whether gcc accepts -g… yes
checking for gcc option to accept ISO C89… none needed
checking for style of include used by make… GNU
checking dependency style of gcc… gcc3
checking for c++… c++
checking whether we are using the GNU C++ compiler… yes
checking whether c++ accepts -g… yes
checking dependency style of c++… gcc3
checking for a sed that does not truncate output… /bin/sed
checking for grep that handles long lines and -e… /bin/grep
checking for egrep… /bin/grep -E
checking for fgrep… /bin/grep -F
checking for ld used by gcc… /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld… yes
checking for BSD- or MS-compatible name lister (nm)… /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface… BSD nm
checking whether ln -s works… yes
checking the maximum length of command line arguments… 98304
checking whether the shell understands some XSI constructs… yes
checking whether the shell understands “+=”… yes
checking for /usr/bin/ld option to reload object files… -r
checking for objdump… objdump
checking how to recognize dependent libraries… pass_all
checking for ar… ar
checking for strip… strip
checking for ranlib… ranlib
checking command to parse /usr/bin/nm -B output from gcc object… ok
checking how to run the C preprocessor… gcc -E
checking for ANSI C header files… yes
checking for sys/types.h… yes
checking for sys/stat.h… yes
checking for stdlib.h… yes
checking for string.h… yes
checking for memory.h… yes
checking for strings.h… yes
checking for inttypes.h… yes
checking for stdint.h… yes
checking for unistd.h… yes
checking for dlfcn.h… yes
checking whether we are using the GNU C++ compiler… (cached) yes
checking whether c++ accepts -g… (cached) yes
checking dependency style of c++… (cached) gcc3
checking how to run the C++ preprocessor… c++ -E
checking for objdir… .libs
checking if gcc supports -fno-rtti -fno-exceptions… no
checking for gcc option to produce PIC… -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works… yes
checking if gcc static flag -static works… yes
checking if gcc supports -c -o file.o… yes
checking if gcc supports -c -o file.o… (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries… yes
checking whether -lc should be explicitly linked in… no
checking dynamic linker characteristics… GNU/Linux ld.so
checking how to hardcode library paths into programs… immediate
checking whether stripping libraries is possible… yes
checking if libtool supports shared libraries… yes
checking whether to build shared libraries… yes
checking whether to build static libraries… no
checking for ld used by c++… /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld… yes
checking whether the c++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries… yes
checking for c++ option to produce PIC… -fPIC -DPIC
checking if c++ PIC flag -fPIC -DPIC works… yes
checking if c++ static flag -static works… yes
checking if c++ supports -c -o file.o… yes
checking if c++ supports -c -o file.o… (cached) yes
configure: creating ./config.lt
config.lt: creating libtool
checking for special C compiler options needed for large files… no
checking for _FILE_OFFSET_BITS value needed for large files… no
checking for nm… /usr/bin/nm -B
checking whether to enable maintainer-specific portions of Makefiles… no
checking for some Win32 platform… no
checking for library containing strerror… none required
checking for gcc option to accept ANSI C… none needed
checking whether make sets $(MAKE)… (cached) yes
checking for pkg-config… /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0… yes
checking for BASE_DEPENDENCIES… configure: error: Package requirements (glib-2.0 >= 2.19.7 atk >= 1.13.0 pango >= 1.20 cairo >= 1.6) were not met:
No package ‘atk’ found
No package ‘pango’ found
No package ‘cairo’ found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables BASE_DEPENDENCIES_CFLAGS
and BASE_DEPENDENCIES_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
je ne trouve pas ces paquets dans le gestionnaire de paquet synaptic?
Je crois que les deux problèmes sont liés, qu’en pensez-vous?
J’ai installé ces paquets
[list=]libcairo2
libcairo2-dev
libpango1.0-dev
libpango1.0-common
libpango1.0-0
libatk1.0-0
libatk1.0-dev
libgtk2.0-0
libgtk2.0-common
libgtk2.0-dev
libglib2.0-0
libglib2.0-dev[/list]
c’est bon pour la compilation de gtk+
Les deux problème ne sont pas liés, j’en suis donc au point de départ
J’ai trouvé, je dois installer Qt 4.5
Merci tout de même
