Bonsoir,
Dans mes logs postfix j’ai ce message d’erreur qui apparait :
Jan 6 17:35:03 web postfix/smtpd[10571]: connect from web.srv-home.fr[192.168.0.253]
Jan 6 17:35:03 web postfix/smtpd[10571]: lost connection after CONNECT from web.srv-home.fr[192.168.0.253]
Jan 6 17:35:03 web postfix/smtpd[10571]: disconnect from web.srv-home.fr[192.168.0.253]
Jan 6 17:35:03 web dovecot: imap-login: Disconnected (no auth attempts): rip=192.168.0.253, lip=192.168.0.253, TLS handshaking: Disconnected
J’ai cherché sur le net mais je n’ai rien trouvé de concluant.
Voici mon main.cf
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
delay_warning_time = 1h
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
mydestination = web.srv-home.fr, localhost.srv-home.fr, localhost
relayhost =
mydomain = web.srv-home.fr
mynetworks = 127.0.0.0/8 192.168.0.0/24
inet_interfaces = all
recipient_delimiter = +
transport_maps = hash:/etc/postfix/transport
myorigin = /etc/mailname
mailbox_command = procmail -a "$EXTENSION"
mailbox_size_limit = 0
inet_protocols = ipv4
virtual_uid_maps = static:3000
virtual_gid_maps = static:3000
virtual_mailbox_base = /home/srv-home
virtual_transport = dovecot
virtual_mailbox_domains = mysql:/etc/postfix/mysql_virtual_mailbox_domains.cf
virtual_mailbox_maps = mysql:/etc/postfix/mysql_virtual_mailbox_maps.cf
virtual_alias_maps = mysql:/etc/postfix/mysql_virtual_alias_maps.cf
relay_domains = mysql:/etc/postfix/mysql_relay_domains.cf
smtp_use_tls = yes
smtp_tls_note_starttls_offer = yes
smtpd_tls_auth_only = no
smtpd_use_tls = yes
smtpd_tls_key_file = /etc/postfix/ssl/smtpd.key
smtpd_tls_cert_file = /etc/postfix/ssl/smtpd.crt
smtpd_tls_CAfile = /etc/postfix/ssl/cacert.pem
smtp_tls_CAfile = /etc/postfix/ssl/cacert.pem
smtpd_tls_loglevel = 1
smtpd_tls_received_header = yes
smtpd_tls_session_cache_timeout = 3600s
tls_random_source = dev:/dev/urandom
smtpd_recipient_restrictions =
permit_mynetworks,
reject_unauth_pipelining,
reject_non_fqdn_hostname,
reject_non_fqdn_sender,
reject_non_fqdn_recipient,
reject_unauth_destination,
reject_invalid_hostname,
# R�gles pour accepter ou refuser une connexion :
# - on attend une seconde (pour pi�ger les zombies).;
# - on interdit la parall�lisation l� o� il n'est pas sens� y en avoir.
smtpd_client_restrictions =
permit_mynetworks, permit_sasl_authenticated,
sleep 1, reject_unauth_pipelining
smtpd_sasl_auth_enable = yes
smtpd_sasl_security_options = noanonymous
smtpd_sasl_type = dovecot
smtpd_sasl_path = private/auth
# Indiquer � Postfix de livrer � un destinataire � la fois
# la r�ception d'un mail en provenance d'un exp�diteur unique avec plusieurs destinataire ne fonctionnerais pas sans cette option
dovecot_destination_recipient_limit = 1
content_filter = amavis:[127.0.0.1]:10024
receive_override_options = no_address_mappings
Mon master.cf :
[code]# Postfix master process configuration file. For details on the format
of the file, see the master(5) manual page (command: “man 5 master”).
Do not forget to execute “postfix reload” after editing this file.
service type private unpriv chroot wakeup maxproc command + args
(yes) (yes) (yes) (never) (100)
smtp inet n - - - - smtpd
#submission inet n - - - - smtpd
-o smtpd_tls_security_level=encrypt
-o smtpd_sasl_auth_enable=yes
-o smtpd_client_restrictions=permit_sasl_authenticated,reject
-o milter_macro_daemon_name=ORIGINATING
smtps inet n - - - - smtpd
-o smtpd_tls_wrappermode=yes
#628 inet n - - - - qmqpd
pickup fifo n - - 60 1 pickup
cleanup unix n - - - 0 cleanup
qmgr fifo n - n 300 1 qmgr
#qmgr fifo n - - 300 1 oqmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - - - - smtp
When relaying mail as backup MX, disable fallback_relay to avoid MX loops
relay unix - - - - - smtp
-o smtp_fallback_relay=
-o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - - - - showq
error unix - - - - - error
retry unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
Interfaces to non-Postfix software. Be sure to examine the manual
pages of the non-Postfix software to find out what options it wants.
Many of the following services use the Postfix pipe(8) delivery
agent. See the pipe(8) man page for information about ${recipient}
and other message envelope options.
maildrop. See the Postfix MAILDROP_README file for details.
Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/bin/maildrop -d ${recipient}
Recent Cyrus versions can use the existing “lmtp” master.cf entry.
Specify in cyrus.conf:
lmtp cmd=“lmtpd -a” listen=“localhost:lmtp” proto=tcp4
Specify in main.cf one or more of the following:
mailbox_transport = lmtp:inet:localhost
virtual_transport = lmtp:inet:localhost
Cyrus 2.1.5 (Amos Gouaux)
Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
Old example of delivery via Cyrus.
#old-cyrus unix - n n - - pipe
flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
See the Postfix UUCP_README file for configuration details.
uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
Other external delivery methods.
ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman unix - n n - - pipe
flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
${nexthop} ${user}
dovecot unix - n n - - pipe
flags=DRhu user=srv-home:srv-home argv=/usr/lib/dovecot/deliver -f ${sender} -d ${user}@${nexthop}
amavis unix - - - - 2 smtp
-o smtp_data_done_timeout=1200
-o smtp_send_xforward_command=yes
127.0.0.1:10025 inet n - - - - smtpd
-o content_filter=
-o local_recipient_maps=
-o relay_recipient_maps=
-o smtpd_restriction_classes=
-o smtpd_helo_restrictions=
-o smtpd_sender_restrictions=
-o smtpd_recipient_restrictions=permit_mynetworks,reject
-o mynetworks=127.0.0.0/8
-o strict_rfc821_envelopes=yes
-o receive_override_options=no_unknown_recipient_checks,no_header_body_checks
-o smtpd_bind_address=127.0.0.1
Savez-vous comment résoudre ce problème ?
