Le voici : [code]# CMAKE generated file: DO NOT EDIT!
Generated by “Unix Makefiles” Generator, CMake Version 2.8
Default target executed when no arguments are given to make.
default_target: all
.PHONY : default_target
Special targets provided by cmake.
Disable implicit rules so canoncical targets will work.
.SUFFIXES:
Remove some rules from gmake that .SUFFIXES does not remove.
SUFFIXES =
.SUFFIXES: .hpux_make_needs_suffix_list
Suppress display of executed commands.
$(VERBOSE).SILENT:
A target that is always out of date.
cmake_force:
.PHONY : cmake_force
Set environment variables for the build.
The shell in which to execute make rules.
SHELL = /bin/sh
The CMake executable.
CMAKE_COMMAND = /usr/bin/cmake
The command to remove a file.
RM = /usr/bin/cmake -E remove -f
The top-level source directory on which CMake was run.
CMAKE_SOURCE_DIR = /home/xavier/Jeux/hedgewars-src-0.9.12
The top-level build directory on which CMake was run.
CMAKE_BINARY_DIR = /home/xavier/Jeux/hedgewars-src-0.9.12
Targets provided globally by CMake.
Special rule for the target edit_cache
edit_cache:
@$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --cyan “Running interactive CMake command-line interface…”
/usr/bin/cmake -i .
.PHONY : edit_cache
edit_cache/fast: edit_cache
.PHONY : edit_cache/fast
Special rule for the target install
install: preinstall
@$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --cyan “Install the project…”
/usr/bin/cmake -P cmake_install.cmake
.PHONY : install
install/fast: preinstall/fast
.PHONY : install/fast
Special rule for the target install/local
install/local: preinstall
@$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --cyan “Installing only the local directory…”
/usr/bin/cmake -DCMAKE_INSTALL_LOCAL_ONLY=1 -P cmake_install.cmake
.PHONY : install/local
install/local/fast: install/local
.PHONY : install/local/fast
Special rule for the target install/strip
install/strip: preinstall
@$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --cyan “Installing the project stripped…”
/usr/bin/cmake -DCMAKE_INSTALL_DO_STRIP=1 -P cmake_install.cmake
.PHONY : install/strip
install/strip/fast: install/strip
.PHONY : install/strip/fast
Special rule for the target list_install_components
list_install_components:
@$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --cyan “Available install components are: “Unspecified””
.PHONY : list_install_components
list_install_components/fast: list_install_components
.PHONY : list_install_components/fast
Special rule for the target package
package: preinstall
@$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --cyan “Run CPack packaging tool…”
/usr/bin/cpack --config ./CPackConfig.cmake
.PHONY : package
package/fast: package
.PHONY : package/fast
Special rule for the target package_source
package_source:
@$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --cyan “Run CPack packaging tool for source…”
/usr/bin/cpack --config ./CPackSourceConfig.cmake /home/xavier/Jeux/hedgewars-src-0.9.12/CPackSourceConfig.cmake
.PHONY : package_source
package_source/fast: package_source
.PHONY : package_source/fast
Special rule for the target rebuild_cache
rebuild_cache:
@$(CMAKE_COMMAND) -E cmake_echo_color --switch=$(COLOR) --cyan “Running CMake to regenerate build system…”
/usr/bin/cmake -H$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR)
.PHONY : rebuild_cache
rebuild_cache/fast: rebuild_cache
.PHONY : rebuild_cache/fast
The main all target
all: cmake_check_build_system
$(CMAKE_COMMAND) -E cmake_progress_start /home/xavier/Jeux/hedgewars-src-0.9.12/CMakeFiles /home/xavier/Jeux/hedgewars-src-0.9.12/CMakeFiles/progress.marks
$(MAKE) -f CMakeFiles/Makefile2 all
$(CMAKE_COMMAND) -E cmake_progress_start /home/xavier/Jeux/hedgewars-src-0.9.12/CMakeFiles 0
.PHONY : all
The main clean target
clean:
$(MAKE) -f CMakeFiles/Makefile2 clean
.PHONY : clean
clean/fast: clean
.PHONY : clean/fast
Prepare targets for installation.
preinstall: all
$(MAKE) -f CMakeFiles/Makefile2 preinstall
.PHONY : preinstall
preinstall/fast:
.PHONY : preinstall/fast
clear depends
depend:
$(CMAKE_COMMAND) -H$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR) --check-build-system CMakeFiles/Makefile.cmake 1
.PHONY : depend
Target rules for targets named hedgewars
Build rule for target.
hedgewars: cmake_check_build_system
$(MAKE) -f CMakeFiles/Makefile2 hedgewars
.PHONY : hedgewars
fast build rule for target.
hedgewars/fast:
$(MAKE) -f QTfrontend/CMakeFiles/hedgewars.dir/build.make QTfrontend/CMakeFiles/hedgewars.dir/build
.PHONY : hedgewars/fast
Target rules for targets named hwengine
hwengine: cmake_check_build_system
$(MAKE) -f CMakeFiles/Makefile2 hwengine
.PHONY : hwengine
hwengine/fast:
$(MAKE) -f hedgewars/CMakeFiles/hwengine.dir/build.make hedgewars/CMakeFiles/hwengine.dir/build
.PHONY : hwengine/fast
Help Target
help:
@echo “The following are some of the valid targets for this Makefile:”
@echo “… all (the default if no target is provided)”
@echo “… clean”
@echo “… depend”
@echo “… edit_cache”
@echo “… install”
@echo “… install/local”
@echo “… install/strip”
@echo “… list_install_components”
@echo “… package”
@echo “… package_source”
@echo “… rebuild_cache”
@echo “… hedgewars”
@echo “… hwengine”
.PHONY : help
Special targets to cleanup operation of make.
Special rule to run CMake to check the build system integrity.
No rule that depends on this can have commands that come from listfiles
because they might be regenerated.
cmake_check_build_system:
$(CMAKE_COMMAND) -H$(CMAKE_SOURCE_DIR) -B$(CMAKE_BINARY_DIR) --check-build-system CMakeFiles/Makefile.cmake 0
.PHONY : cmake_check_build_system
