Bonjour, j’ai un problème avec la mise en place de mon serveur musical. Je voudrais pouvoir écouter ma musique à distance.
Mon /etc/mpd.conf:
[code]# An example configuration file for MPD
See the mpd.conf man page for a more detailed description of each parameter.
Files and directories
music_directory "/home/house/Musique"
playlist_directory "/home/house/Musique/Playlists"
db_file "/home/house/.mpd/tag_cache"
log_file "/home/house/.mpd/mpd.log"
pid_file "/home/house/.mpd/pid"
state_file “/home/house/.mpd/state”
user “house”
For network
bind_to_address “localhost”
And for Unix Socket
bind_to_address “/var/run/mpd/socket”
port “6600”
This setting controls the type of information which is logged. Available
setting arguments are “default”, “secure” or “verbose”. The “verbose” setting
argument is recommended for troubleshooting, though can quickly stretch
available resources on limited hardware storage.
#log_level “default”
If you have a problem with your MP3s ending abruptly it is recommended that
you set this argument to “no” to attempt to fix the problem. If this solves
the problem, it is highly recommended to fix the MP3 files with vbrfix
(available from http://www.willwap.co.uk/Programs/vbrfix.php), at which
point gapless MP3 playback can be enabled.
#gapless_mp3_playback “yes”
This setting enables MPD to create playlists in a format usable by other
music players.
#save_absolute_paths_in_playlists “no”
This setting defines a list of tag types that will be extracted during the
audio file discovery process. Optionally, ‘comment’ can be added to this
list.
#metadata_to_use “artist,album,title,track,name,genre,date,composer,performer,disc”
Symbolic link behavior
If this setting is set to “yes”, MPD will discover audio files by following
symbolic links outside of the configured music_directory.
#follow_outside_symlinks “yes”
symbolic links inside of the configured music_directory.
#follow_inside_symlinks “yes”
Zeroconf / Avahi Service Discovery
If this setting is set to “yes”, service information will be published with
Zeroconf / Avahi.
#zeroconf_enabled “yes”
The argument to this setting will be the Zeroconf / Avahi unique name for
this MPD server on the network.
#zeroconf_name “Music Player”
Permissions
If this setting is set, MPD will require password authorization. The password
can setting can be specified multiple times for different password profiles.
#password “password@read,add,control,admin”
This setting specifies the permissions a user has who has not yet logged in.
#default_permissions “read,add,control,admin”
Input
input {
plugin “curl”
proxy “proxy.isp.com:8080”
proxy_user “user”
proxy_password “password”
Audio Output
MPD supports various audio output types, as well as playing through multiple
audio outputs at the same time, through multiple audio_output settings
blocks. Setting this block is optional, though the server will only attempt
autodetection for one sound card.
See http://mpd.wikia.com/wiki/Configuration#Audio_Outputs for examples of
other audio outputs.
An example of an ALSA output:
audio_output {
type "alsa"
name "Sound Card"
options "dev=dmixer"
device “plug:dmix” # optional
format “44100:16:2” # optional
mixer_device “default” # optional
mixer_control “PCM” # optional
mixer_index “0” # optional
An example of an OSS output:
#audio_output {
type “oss”
name “My OSS Device”
device “/dev/dsp” # optional
mixer_device “/dev/mixer” # optional
An example of a shout output (for streaming to Icecast):
audio_output {
type "shout"
encoding “ogg” # optional
name "My Web Radio"
host "MON ADRESSE DYDNS"
port "8000"
mount "/mnt.ogg"
password "MON_MDP"
quality “5.0”
bitrate “128”
format "44100:16:2"
protocol "icecast2" # optional
user "source" # optional
description "My Stream Radio" # optional
genre "rock/blues" # optional
public "yes" # optional
timeout "2" # optional
An example of a httpd output (built-in HTTP streaming server):
#audio_output {
type “httpd”
name “My HTTP Stream”
encoder “vorbis” # optional, vorbis or lame
port “8000”
quality “5.0” # do not define if bitrate is defined
bitrate “128” # do not define if quality is defined
format “44100:16:1”
An example of a pulseaudio output (streaming to a remote pulseaudio server)
#audio_output {
type “pulse”
name “My Pulse Output”
server “remote_server” # optional
sink “remote_server_sink” # optional
Example “pipe” output:
#audio_output {
type “pipe”
name “my pipe”
command “aplay -f cd 2>/dev/null”
Or if you’re want to use AudioCompress
command “AudioCompress -m | aplay -f cd 2>/dev/null”
Or to send raw PCM stream through PCM:
command “nc example.org 8765”
format “44100:16:2”
An example of a null output (for no audio output):
#audio_output {
type “null”
name “My Null Output”
This setting will change all decoded audio to be converted to the specified
format before being passed to the audio outputs. By default, this setting is
disabled.
#audio_output_format “44100:16:2”
If MPD has been compiled with libsamplerate support, this setting specifies
the sample rate converter to use. Possible values can be found in the
mpd.conf man page or the libsamplerate documentation. By default, this is
setting is disabled.
#samplerate_converter “Fastest Sinc Interpolator”
Volume control mixer
These are the global volume control settings. By default, this setting will
be detected to the available audio output device, with preference going to
hardware mixing. Hardware and software mixers for individual audio_output
sections cannot yet be mixed.
An example for controlling an ALSA, OSS or Pulseaudio mixer; If this
setting is used other sound applications will be affected by the volume
being controlled by MPD.
#mixer_type “hardware”
An example for controlling all mixers through software. This will control
all controls, even if the mixer is not supported by the device and will not
affect any other sound producing applications.
mixer_type “software”
This example will not allow MPD to touch the mixer at all and will disable
all volume controls.
#mixer_type “disabled”
Normalization automatic volume adjustments
This setting specifies the type of ReplayGain to use. This setting can have
the argument “album” or “track”. See http://www.replaygain.org for more
details. This setting is disabled by default.
replaygain “album”
This setting sets the pre-amp used for files that have ReplayGain tags. By
default this setting is disabled.
#replaygain_preamp “0”
This setting enables on-the-fly normalization volume adjustment. This will
result in the volume of all playing audio to be adjusted so the output has
equal “loudness”. This setting is disabled by default.
volume_normalization “yes”
MPD Internal Buffering
This setting adjusts the size of internal decoded audio buffering. Changing
this may have undesired effects. Don’t change this if you don’t know what you
are doing.
#audio_buffer_size “2048”
This setting controls the percentage of the buffer which is filled before
beginning to play. Increasing this reduces the chance of audio file skipping,
at the cost of increased time prior to audio playback.
#buffer_before_play “10%”
Resource Limitations
These settings are various limitations to prevent MPD from using too many
resources. Generally, these settings should be minimized to prevent security
risks, depending on the operating resources.
#connection_timeout “60”
#max_connections “10”
#max_playlist_length “16384”
#max_command_list_size “2048”
#max_output_buffer_size “8192”
Character Encoding
If file or directory names do not display correctly for your locale then you
may need to modify this setting. After modification of this setting mpd
–create-db must be run to change the database.
filesystem_charset “UTF-8”
This setting controls the encoding that ID3v1 tags should be converted from.
id3v1_encoding “UTF-8”
###############################################################################[/code]
Mon /etc/icecast2/icecast.xml
[code]
5
2
5
524288
30
15
10
1
65535
<authentication>
<!-- Sources log in with username 'source' -->
<source-password>MON_MDP</source-password>
<!-- Relays log in username 'relay' -->
<relay-password>MON_MDP</relay-password>
<!-- Admin logs in with the username given below -->
<admin-user>admin</admin-user>
<admin-password>MON_MDP</admin-password>
</authentication>
<!-- set the mountpoint for a shoutcast source to use, the default if not
specified is /stream but you can change it here if an alternative is
wanted or an extension is required
<shoutcast-mount>/live.nsv</shoutcast-mount>
<!-- Uncomment this if you want directory listings -->
<directory>
<yp-url-timeout>15</yp-url-timeout>
<yp-url>http://dir.xiph.org/cgi-bin/yp-cgi</yp-url>
</directory>
<!-- This is the hostname other people will use to connect to your server.
It affects mainly the urls generated by Icecast for playlists and yp
listings. -->
<hostname>MON ADRESSE DYDNS</hostname>
<!-- You may have multiple <listener> elements -->
<listen-socket>
<port>8000</port>
<!-- <bind-address>127.0.0.1</bind-address> -->
<!-- <shoutcast-mount>/stream</shoutcast-mount> -->
</listen-socket>
<listen-socket>
<port>8001</port>
</listen-socket>
<!--<master-server>127.0.0.1</master-server>-->
<!--<master-server-port>8001</master-server-port>-->
<!--<master-update-interval>120</master-update-interval>-->
<!--<master-password>hackme</master-password>-->
<!-- setting this makes all relays on-demand unless overridden, this is
useful for master relays which do not have <relay> definitions here.
The default is 0 -->
<!--<relays-on-demand>1</relays-on-demand>-->
<relay>
<server>127.0.0.1</server>
<port>8001</port>
<mount>/example.ogg</mount>
<local-mount>/different.ogg</local-mount>
<on-demand>0</on-demand>
<relay-shoutcast-metadata>0</relay-shoutcast-metadata>
</relay>
<!-- Only define a <mount> section if you want to use advanced options,
like alternative usernames or passwords
<mount>
<mount-name>/example-complex.ogg</mount-name>
<username>othersource</username>
<password>hackmemore</password>
<max-listeners>1</max-listeners>
<dump-file>/tmp/dump-example1.ogg</dump-file>
<burst-size>65536</burst-size>
<fallback-mount>/example2.ogg</fallback-mount>
<fallback-override>1</fallback-override>
<fallback-when-full>1</fallback-when-full>
<intro>/example_intro.ogg</intro>
<hidden>1</hidden>
<no-yp>1</no-yp>
<authentication type="htpasswd">
<option name="filename" value="myauth"/>
<option name="allow_duplicate_users" value="0"/>
</authentication>
<on-connect>/home/icecast/bin/stream-start</on-connect>
<on-disconnect>/home/icecast/bin/stream-stop</on-disconnect>
</mount>
<mount>
<mount-name>/auth_example.ogg</mount-name>
<authentication type="url">
<option name="mount_add" value="http://myauthserver.net/notify_mount.php"/>
<option name="mount_remove" value="http://myauthserver.net/notify_mount.php"/>
<option name="listener_add" value="http://myauthserver.net/notify_listener.php"/>
<option name="listener_remove" value="http://myauthserver.net/notify_listener.php"/>
</authentication>
</mount>
<fileserve>1</fileserve>
<paths>
<!-- basedir is only used if chroot is enabled -->
<basedir>/usr/share/icecast2</basedir>
<!-- Note that if <chroot> is turned on below, these paths must both
be relative to the new root, not the original root -->
<logdir>/var/log/icecast2</logdir>
<webroot>/usr/share/icecast2/web</webroot>
<adminroot>/usr/share/icecast2/admin</adminroot>
<!-- <pidfile>/usr/share/icecast2/icecast.pid</pidfile> -->
<!-- Aliases: treat requests for 'source' path as being for 'dest' path
May be made specific to a port or bound address using the "port"
and "bind-address" attributes.
<alias source="/foo" dest="/bar"/>
<!-- Aliases: can also be used for simple redirections as well,
this example will redirect all requests for http://server:port/ to
the status page
<alias source="/" dest="/status.xsl"/>
</paths>
<logging>
<accesslog>access.log</accesslog>
<errorlog>error.log</errorlog>
<!-- <playlistlog>playlist.log</playlistlog> -->
<loglevel>3</loglevel> <!-- 4 Debug, 3 Info, 2 Warn, 1 Error -->
<logsize>10000</logsize> <!-- Max size of a logfile -->
<!-- If logarchive is enabled (1), then when logsize is reached
the logfile will be moved to [error|access|playlist].log.DATESTAMP,
otherwise it will be moved to [error|access|playlist].log.old.
Default is non-archive mode (i.e. overwrite)
<!-- <logarchive>1</logarchive> -->
</logging>
<security>
<chroot>0</chroot>
<changeowner>
<user>nobody</user>
<group>nogroup</group>
</changeowner>
</security>
Avec cette configuration, mpd ne fonctionne pas, pas de musique (en faite j’ai de la musique 5 secondes toutes les 15,20 minutes).
127.0.0.1:8000/ fonctionne, je peut m’y connecter. Mais je n’arrive pas à me connecter avec mon adresse dydns (MON ADRESSE DYDNS:8000).
Si je change la partie “host” dans mpd.conf et que je met 127.0.0.1 à la place de mon adresse dyndns tous fonctionne très bien.
Un extrait du log:
Nov 12 22:52 : output: Failed to open “My Web Radio” [shout]: problem opening connection to shout server MON ADRESSE DYDNS:8000: Couldn’t connect
Mon adresse dydns marche, si je la tape sous firefox, je tombe sur la page de config de mon routeur.
Voila si vous avez des pistes je suis preneur.
de cette manière sa deviens local
