J’ai un petit souci depuis que j’ai mis à jour ma Debian testing, MYSQL ne se lance plus au démarage du PC et quand je regarde le syslog j’ai le message d’insulte suivant:
Oct 21 15:26:08 localhost mysqld_safe[3172]: started
Oct 21 15:26:08 localhost mysqld[3176]: 051021 15:26:08 /usr/sbin/mysqld: unknow
n variable 'old_passwords=1’
Oct 21 15:26:08 localhost mysqld_safe[3178]: ended
Oct 21 15:26:14 localhost /etc/init.d/mysql[3241]: 0 processes alive and ‘/usr/b
in/mysqladmin --defaults-file=/etc/mysql/debian.cnf ping’ resulted in
Oct 21 15:26:14 localhost /etc/init.d/mysql[3241]: ^G/usr/bin/mysqladmin: connec
t to server at ‘localhost’ failed
Oct 21 15:26:14 localhost /etc/init.d/mysql[3241]: error: 'Can’t connect to loca
l MySQL server through socket ‘/var/run/mysqld/mysqld.sock’ (2)'
Oct 21 15:26:14 localhost /etc/init.d/mysql[3241]: Check that mysqld is running
and that the socket: ‘/var/run/mysqld/mysqld.sock’ exists!
Ensuite lorsque j’essaye de lancer MYSQL à la main via /etc/init.d/mysql start j’ai le message d’erreur suivant:
Starting MySQL database server: mysqld…failed.
Please take a look at the syslog.
/usr/bin/mysqladmin: connect to server at ‘localhost’ failed
error: 'Can’t connect to local MySQL server through socket ‘/var/run/mysqld/mysqld.sock’ (2)'
Check that mysqld is running and that the socket: ‘/var/run/mysqld/mysqld.sock’ exists!
Du coup, je suis bien embeté
Merci à tous ceux qui pourront m’aider
