j’ai le message suivant lorsque j’essaie d’installer un driver 64 bits avec ndiswrapper :
dmesg | tail
[ 436.693382] usb 3-5: new high speed USB device using ehci_hcd and address 4
[ 436.997385] usb 3-5: configuration #1 chosen from 1 choice
[ 437.129383] usb 3-5: reset high speed USB device using ehci_hcd and address 4
[ 437.366132] ndiswrapper (check_nt_hdr:150): kernel is 64-bit, but Windows driver is not 64-bit;bad magic: 010B
[ 437.366146] ndiswrapper (load_sys_files:206): couldn’t prepare driver ‘dr71wu’
[ 437.369373] ndiswrapper (load_wrap_driver:108): couldn’t load driver dr71wu; check system log for messages from ‘loadndisdriver’
[ 437.369373] usb 3-5: New USB device found, idVendor=07d1, idProduct=3c07
[ 437.369373] usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 437.369373] usb 3-5: Product: 802.11 bg WLAN
[ 437.369373] usb 3-5: Manufacturer: Ralink
j’utilise pourtant les drivers windows situés dans le dossier win64.
Quelqu’un a-t-il une idée ?
