Probléme netgear wg111v2
Bonjour à tous, je posséde une clé wifi USB netgear wg111v2 à base de chipset Realtek 8187L aprés épluchage des informations sur le net j’ai récuperer ce site : http://rtl8180-sa2400.sourceforge.net/. J’ai tenté d’installer leur driver mais lorsque j’essai de compiler le module il me met :
~/rtl8187-newstack$ make make -C /lib/modules/2.6.15-1-686/build SUBDIRS=/home/snake/rtl8187-newstack MODVERDIR=/home/snake/rtl8187-newstack modules make[1]: entrant dans le répertoire « /usr/src/linux-headers-2.6.15-1-686 » Building modules, stage 2. MODPOST *** Warning: "ieee80211_wx_get_freq" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_softmac_start_protocol" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wlan_frequencies" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_is_shortslot" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wx_get_wap" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wx_set_scan" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wx_get_rate" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_stop_queue" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_is_54g" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_softmac_stop_protocol" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wx_set_rawtx" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wpa_supplicant_ioctl" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_get_beacon" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wx_get_essid" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wx_set_mode" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wx_get_mode" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wx_set_freq" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wake_queue" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wx_set_rate" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wx_set_wap" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wx_set_essid" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_reset_queue" [/home/snake/rtl8187-newstack/r8187.ko] undefined! *** Warning: "ieee80211_wx_get_name" [/home/snake/rtl8187-newstack/r8187.ko] undefined! make[1]: quittant le répertoire « /usr/src/linux-headers-2.6.15-1-686 »
Qu’a cela ne tienne je tente d’insére le module :
rtl8187-newstack# insmod r8187.ko
insmod: error inserting 'r8187.ko': -1 Unknown symbol in module
je tente un dmesg pour voir ce qui se passe :
r8187: disagrees about version of symbol ieee80211_wx_set_encode
r8187: Unknown symbol ieee80211_wx_set_encode
r8187: disagrees about version of symbol ieee80211_wx_get_encode
r8187: Unknown symbol ieee80211_wx_get_encode
r8187: disagrees about version of symbol ieee80211_wx_get_scan
r8187: Unknown symbol ieee80211_wx_get_scan
r8187: disagrees about version of symbol ieee80211_rx
r8187: Unknown symbol ieee80211_rx
r8187: disagrees about version of symbol free_ieee80211
r8187: Unknown symbol free_ieee80211
r8187: disagrees about version of symbol alloc_ieee80211
r8187: Unknown symbol alloc_ieee80211
J’ai vraiment tout essayé, je pense que le probléme ce situe au niveau de ieee80211 ( c’est l’évidence meme) serait-il en conflit avec une version déja installé dans le noyau ?
Je précise pour ce qui me dirait : “Install ndiswrapper” je l’ai déja fait mais je n’en suis pas 100% satisfait, j’ai qque bug comme des déconnexions intempestives, pour dire je suis obligé lorsque je suis connecté de lancer un ping permanent vers le poste wifi afin de ne pas perdre la liaison.
Si quelqu’un pouvait m’aider…
Merci d’avance à tous
ton module a l’air de faire appel à un composant de noyau qui n’existe pas, ou qui n’est pas chargé.
j’ai trouvé ça:
ieee80211.sourceforge.net/
regardes si le module ieee80211 n’existe pas déjà dans ton noyau (en le 'modprobe’ant, par ex)
merci pour ta réponse, en effet je déja vu ce site, jai modprobé ieee80211 mais sans résultat.
Je pense effectivement que le probléme vienne de la, mais la je séche …
Bonsoir,
Avec cette clé la j’ai vu qu’il fallait mieux utiliser ndiswrapper mais je ne sais plus où j’ai donc essayé mais malheureusement un petit probleme au niveau de la connection.
Donc ndiswrapper installé apparement correctement avec m-a a-i ndiswrapper et un prepare avant.
J’ai bien installé le paquet wireless-tools ainsi que wpasupplicant
au niveau de mon fichier interfaces j’ai la meme chose que sur mon autre pc (qui pour lui la connection fonctionne) avec bien sur une clé différente.
auto wlan0 iface wlan0 inet dhcp wpa-conf managed wpa-ap-scan 1 wpa-scan-ssid 1 wpa-ssid alex wpa-key-mgmt WPA-PSK wpa-psk XXXXXXXXXXXXXXX
J’ai bien configuré le routeur netgear pour qu’il accepte la connection de la part de la clé usb.
Un iwconfig me donne bien les parametres de la clé usb wifi
wlan0 IEEE 802.11g ESSID:off/any Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated Bit Rate:54 Mb/s Tx-Power:20 dBm Sensitivity=0/3 RTS thr:2432 B Fragment thr:2432 B Encryption key:off Power Management:off Link Quality:0 Signal level:0 Noise level:0 Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 Par contre quand je relance le réseaux hé bien la connection refuse de se faire ???
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 1 No DHCPOFFERS received. No working leases in persistent database - sleeping. done.
Le serveur dhcp fonctionne bien car avec mon autre carte wifi ca fonctionne correctement.
Je précise que c’est sur un céléron 700 avec une fraiche netinstall etch.
Kernel 2.6.17-2-686.
lsusb Bus 001 Device 001: ID 0000:0000 Bus 002 Device 006: ID 0846:6a00 NetGear, Inc. WG111 WiFi (v2) Bus 002 Device 001: ID 0000:0000
J’ai déjà essayé de recommencer l’installation complete de ndiswrapper et toujours le meme résultat j’ai meme rebooté le pc et toujours pareil. La je suis un peu à court d’idées
ton serveur dhcp, il est sur l’AP, ou il est sur le réseau qui est derrière ?
Parceque j’ai le même prob avec le même dongle que j’ai récupèré cet été, mais sous windows 2000: il refuse d’accrocher le dhcp qui attribue les adresses sur mon réseau (et je ne sais pas mettre une adresse fixe).
Le wifi, c’est vraiment de la daube.
[quote=“mattotop”]ton serveur dhcp, il est sur l’AP, ou il est sur le réseau qui est derrière ?
Le wifi, c’est vraiment de la daube.[/quote]Oui tu as raison c’est vraiment immonde mais malheureusement pour ma part je ne peux pas m’en passer pour cette install :’(
Ben mon serveur dhcp est directement sur le routeur netgear (la clé était vendu avec). Un petit soucis que j’ai vu sur la clé était qu’elle ne fonctionnait pas forcement au premier branchement même si elle était reconnu. J’ai continué mes recherches après avoir posté et en fait j’ai tenté de changer de port usb et ben maintenant ca fonctionne.
Je ne connais pas sa réaction sous win2000 mais regarde en essayant de la brancher deux fois de suite. C’est fastidieux mais ca pourrait peut etre fonctionner en tant que solution temporaire. Sinon pour ton histoire d’ip fixe tu devrais pouvoir acceder aux propriétés de la connexion wifi via le gestionnaire des connexions réseaux et ensuite au niveau des propriétés du protocole TCP/IP mettre une ip fixe. Comme décrit dslvalley.com/dossiers/w2k/w … e9332db0cd
Après je ne sais pas si tu peux y avoir acces avec la clé usb
Je regarderais ton tuto demain, mais mon problême n’est ni une reconnaissance, ni un “accrochage” de l’AP: le dongle se connecte bien, mais n’obtient juste pas de dhcp (je l’ai vu apparaitre une ou deux fois dans mes leases et je l’ai même pingé, mais quoi qu’il arrive, il reboucle sur “lecture de l’adresse réseau”).
Sinon, sous nux avec ndiswrapper, et l’ap en serveur dhcp, chez moi ça fonctionne nickel. sauf que dans ce cas, l’AP insiste pour attribuer AUSSI les adresses sur le LAN :frowning: .
J’ai aussi essayé le pilote natif cité plus haut et j’ai réussi à le faire marcher en client (me souviens plus si c’etait stable ou pas, mais AMA, ça vaut le coup d’insister et de remonter les erreurs au gars) mais comme mon but était de faire un AP et que le mode server fonctionnait de manière aléatoire, j’ai abandonné.
Peut être qu’avec un BSD, il gèrerait mieux le mode serveur, à voir…
Enfin bon, maintenant, j’essaye de me passer des 15 m de cables pour la connection de la machine de ma femme et ça me gonfle cette histoire.
Bonjour tout le monde,
Je possède aussi une clé wifi netgear WG111v2 et j’ai aussi un problème ^^.
En effet j’ai installé le drivers de la clé comme prescrit ici clubic.com/forum/os-alternat … page1.html
La mode graphique avec Pilote sans fil windows me dit aussi que le drivers est installé et que le périphérique est branché car j’obtient la ligne suivante en tapant ceci:
ndiswrapper -l
J’obtiens:
net111v2 : driver installed, Hardware (0846:6A00) present
Pourtant ma clé wifi refuse de s’allumer de plus en tappant la commande iwconfig j’obtiens ceci:
lo no wireless extensions
eth0 no wireless extensions
Je ne comprends pas ce qui cloche, si quelqu’un pourrait m’aider cela serait vraiment sympa de sa part.
Merci.
