J’essaye d’ouvrir Steam après son installation sur Debian Jessie mais il m’affiche un message juste après son démarrage…
Voici le terminal:
liosu@liosu-G551JW:~$ steam
Running Steam on debian 8 64-bit
STEAM_RUNTIME is enabled automatically
[2017-06-22 21:49:18] Startup - updater built Jun 8 2017 04:33:02
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2017-06-22 21:49:18] Checking for update on startup
[2017-06-22 21:49:18] Checking for available updates...
[2017-06-22 21:49:20] Download skipped: /client/steam_client_ubuntu12 version 1496897923, installed version
1496897923
[2017-06-22 21:49:20] Nothing to do
[2017-06-22 21:49:20] Verifying installation...
[2017-06-22 21:49:20] Performing checksum verification of executable files
[2017-06-22 21:49:20] Verification complete
Mais directement après ce message s’affiche:
Que puis-je faire pour résoudre ce problème?
Merci d’avance
