problème PEAR
Je dois installer egroupware. Lors du test d’installation, il me donne comme problème :
Warning Checking PEAR::HTTP_WebDAV_Server is installed: False
PEAR::HTTP_WebDAV_Server is needed by: WebDAV. You can install it by running: pear install HTTP_WebDAV_Server
Warning Checking PEAR::Auth_SASL is installed: False
PEAR::Auth_SASL is needed by: EMailAdmin, felamimail. You can install it by running: pear install Auth_SASL
Warning Checking PEAR::Net_IMAP is installed: False
PEAR::Net_IMAP is needed by: EMailAdmin, felamimail. You can install it by running: pear install Net_IMAP
Warning Checking PEAR::Net_Sieve is installed: False
PEAR::Net_Sieve is needed by: felamimail. You can install it by running: pear install Net_Sieve
Warning Checking PEAR::XML_Feed_Parser is installed: False
PEAR::XML_Feed_Parser is needed by: news_admin. You can install it by running: pear install XML_Feed_Parser
Warning Checking PEAR::Log is installed: False
PEAR::Log is needed by: SyncML. You can install it by running: pear install Log
Donc pas de soucis j’installe php-pear. Là, je commence donc par le début de la liste :
16:56 root@ns1 ~# pear install auth_sasl
No releases available for package "pear.php.net/auth_sasl"
Cannot initialize 'channel://pear.php.net/auth_sasl', invalid or missing package file
Package "channel://pear.php.net/auth_sasl" is not valid
install failed
zsh: exit 1     pear install auth_sasl
Lorsque j’essaye de mettre à jour PEAR j’ai ce mesage :
16:11 root@ns1 ~# pear upgrade PEAR
Error getting channel info from pear.php.net: Connection to `pear.php.net:80' failed: php_network_getaddresses: getaddrinfo failed: Temporary failure in name resolution
Nothing to upgrade
Avez vous une idée pour me sortir de là? Merci d’avance
