Probleme post-nvidia
J’ai tenté il y a qques temps une install du driver nvidia selon le tuto des T&A.
J’ai renoncé,toujours un même pb de compil.
J’ai donc fait le ménage toujours selon le tuto des T&A,sans avoir lancé X.
Depuis,j’ai un soucis que je n’arrive pas à résoudre:
[quote]albian@debian:~$ gmplayer
gmplayer: error while loading shared libraries: libnvidia-tls.so.1: cannot open shared object file: No such file or directory
albian@debian:~$ googleearth
./googleearth-bin: error while loading shared libraries: libnvidia-tls.so.1: cannot open shared object file: No such file or directory [/quote]
voici ce qu’il reste de nvidia :
[quote]debian:/home/albian# locate nvidia
/lib/modules/2.6.18-4-486/kernel/drivers/char/agp/nvidia-agp.ko
/lib/modules/2.6.18-4-486/kernel/drivers/video/nvidia
/usr/lib/nvidia
/usr/share/bug/nvidia-glx-legacy-96xx
/usr/share/doc/nvidia-glx-dev
/usr/share/doc/nvidia-glx-legacy-96xx
/usr/share/doc/nvidia-glx-legacy-96xx-dev
/usr/share/doc/nvidia-kernel-common
/usr/share/doc/nvidia-kernel-legacy-96xx-2.6.22-3-k7
/usr/share/doc/nvidia-kernel-legacy-96xx-source
/usr/share/doc/nvidia-kernel-legacy-source
/usr/share/doc/nvidia-kernel-source
/usr/src/nvidia-kernel-legacy-source.tar.gz
/usr/src/linux-headers-2.6.26-1-686/include/config/fb/nvidia
/usr/src/linux-headers-2.6.26-1-686/include/config/fb/nvidia/backlight.h
/usr/src/linux-headers-2.6.26-1-686/include/config/fb/nvidia/i2c.h
/usr/src/linux-headers-2.6.26-1-common/drivers/video/nvidia
/usr/src/linux-headers-2.6.26-1-common/drivers/video/nvidia/Makefile
/usr/src/modules/nvidia-kernel
/usr/src/modules/nvidia-kernel-legacy
/usr/src/modules/nvidia-kernel-legacy-96xx
/var/cache/apt/archives/nvidia-kernel-legacy-2.6.18-4-486_1.0.7184+6_i386.deb
/var/cache/apt/archives/nvidia-kernel-legacy-source_1.0.7184-3_i386.deb
/var/cache/modass/nvidia-kernel-legacy-source.avail_version
/var/cache/modass/nvidia-kernel-legacy-source.buildlog.2.6.26-1-686.1222110911
/var/cache/modass/nvidia-kernel-legacy-source.cur_version
/var/lib/dpkg/info/nvidia-kernel-legacy-2.6.18-4-486.list
/var/lib/dpkg/info/nvidia-kernel-legacy-2.6.18-4-486.postrm
/var/lib/dpkg/info/nvidia-kernel-legacy-source.list
/var/lib/dpkg/info/nvidia-kernel-legacy-source.md5sums
a priori les sources et de la doc.Et quand j’essaie de les virer,pour chaque fichier:
[quote]debian:/home/albian# rm /var/lib/dpkg/info/nvidia-kernel-legacy-2.6.18-4-486.postrm
rm: ne peut enlever `/var/lib/dpkg/info/nvidia-kernel-legacy-2.6.18-4-486.postrm’: Aucun fichier ou répertoire de ce type[/quote]
Je suis un peu paumé,une piste serait bienvenue.
le truc est que ça ne m’interesse pas de réinstaller les pilote nvidia.Je souhaite juste que les softs qui cherchent apres la libnvidia se rende compte qu’il n’y en a plus besoin.
Je ne sais pas s’il reste des traces parasites dans des fichiers de conf du systeme.J’ai effacé à chaque fois ceux des softs en question (mplayer) sans succes.
Edit:
Ma debian est une Lenny à jour avec le source.list et le pref des T&A
merci de ton aide tellmewy.
effectivement ldd confirme la sortie console,à savoir:
La compilation a échouée au make.les drivers nvidia n’ont donc pas été installés.La panne mplayer date pourtant de la compilation.
J’ai désinstallé(purge)-réinstallé mplayer -->sans succes
J’ai essayé de bricoler:
[quote]ln -s /usr/lib/libGLcore.so.1 /usr/lib/libnvidia-tls.so.1
[/quote]pas la solution non plus
J’ai cherché des fichiers de conf dans /etc et dans /usr pour X…bref je nage…
comme tu le dis,je l’ai cherché,je l’ai eu :smiley:
Pourquoi certains softs réclament encore cette libnvidia?Comment en effacer jusqu’au souvenir dans la machine?
comment déclarer à mplayer d’oublier cette librairie?
