Voici quelques logs de postfix
J’ai envoyé un mail à test.test@gmail.com dans les aliases.
Le mail envoyé à test@truc.com n’arrive pas sur la boite gmail. Pourtant en lisant les logs j’ai l’impression que tout est bien parti…
Jun 4 17:45:01 ns203750 postfix/smtpd[9341]: connect from mail-vb0-f50.google.com[209.85.212.50]
Jun 4 17:45:02 ns203750 postfix/smtpd[9341]: 9BE128060FA: client=mail-vb0-f50.google.com[209.85.212.50]
Jun 4 17:45:02 ns203750 postfix/cleanup[9388]: 9BE128060FA: message-id=CAKJgsitbR=fW=AokdC9ACs2-QUvHYbKQv8DFaC+5NKUVpLnQHA@mail.gmail.com
Jun 4 17:45:02 ns203750 postfix/qmgr[29929]: 9BE128060FA: from=test.test@gmail.com, size=1721, nrcpt=1 (queue active)
Jun 4 17:45:02 ns203750 postfix/cleanup[9388]: CFEC28060FD: message-id=CAKJgsitbR=fW=AokdC9ACs2-QUvHYbKQv8DFaC+5NKUVpLnQHA@mail.gmail.com
Jun 4 17:45:02 ns203750 postfix/local[9389]: 9BE128060FA: to=test@truc.be, relay=local, delay=0.31, delays=0.31/0/0/0, dsn=2.0.0, status=sent (forwarded as CFEC28060FD)
Jun 4 17:45:02 ns203750 postfix/qmgr[29929]: CFEC28060FD: from=test.test@gmail.com, size=1859, nrcpt=1 (queue active)
Jun 4 17:45:02 ns203750 postfix/qmgr[29929]: 9BE128060FA: removed
Jun 4 17:45:02 ns203750 postfix/smtpd[9341]: disconnect from mail-vb0-f50.google.com[209.85.212.50]
Jun 4 17:45:03 ns203750 postfix/smtp[9390]: CFEC28060FD: to=test.test@gmail.com, orig_to=test@truc.be, relay=gmail-smtp-in.l.google.com[74.125.142.26]:25, delay=0.96, delays=0/0/0.34/0.62, dsn=2.0.0, status=sent (250 2.0.0 OK 1370360721 zz4si48202797icb.10 - gsmtp)
Jun 4 17:45:03 ns203750 postfix/qmgr[29929]: CFEC28060FD: removed
Jun 4 17:45:38 ns203750 postfix/smtpd[9341]: connect from mail-vb0-f43.google.com[209.85.212.43]
Jun 4 17:45:39 ns203750 postfix/smtpd[9341]: 5EB078060FA: client=mail-vb0-f43.google.com[209.85.212.43]
Jun 4 17:45:39 ns203750 postfix/cleanup[9388]: 5EB078060FA: message-id=CAKJgsivMTdwfjbsW6LhtRT+rYbdcGV4SFoycDCBCFQg9E_eBRg@mail.gmail.com
Jun 4 17:45:39 ns203750 postfix/qmgr[29929]: 5EB078060FA: from=test.test@gmail.com, size=1715, nrcpt=1 (queue active)
Jun 4 17:45:39 ns203750 postfix/cleanup[9388]: 90BFF8060FD: message-id=CAKJgsivMTdwfjbsW6LhtRT+rYbdcGV4SFoycDCBCFQg9E_eBRg@mail.gmail.com
Jun 4 17:45:39 ns203750 postfix/qmgr[29929]: 90BFF8060FD: from=test.test@gmail.com, size=1854, nrcpt=1 (queue active)
Jun 4 17:45:39 ns203750 postfix/local[9389]: 5EB078060FA: to=test@truc.com, relay=local, delay=0.3, delays=0.3/0/0/0, dsn=2.0.0, status=sent (forwarded as 90BFF8060FD)
Jun 4 17:45:39 ns203750 postfix/qmgr[29929]: 5EB078060FA: removed
Jun 4 17:45:39 ns203750 postfix/smtpd[9341]: disconnect from mail-vb0-f43.google.com[209.85.212.43]
Jun 4 17:45:40 ns203750 postfix/smtp[9390]: 90BFF8060FD: to=test.test@gmail.com, orig_to=test@truc.com, relay=gmail-smtp-in.l.google.com[74.125.142.26]:25, delay=0.98, delays=0/0/0.34/0.64, dsn=2.0.0, status=sent (250 2.0.0 OK 1370360757 fk6si1806136igb.42 - gsmtp)
Jun 4 17:45:40 ns203750 postfix/qmgr[29929]: 90BFF8060FD: removed
