Problème postfix / maildrop
Bonjour/Bonsoir,
J’ai un problème avec postfix + mysql et maildrop:
-> authtest kay@hoarfrost-entertainment.com Authentication FAILED: Input/output error
-> /usr/local/courier/bin/maildrop -V 7 -d kay@hoarfrost-entertainment.com /usr/local/courier/bin/maildrop: Temporary authentication failure.
-> tail /var/log/mail.log Nov 15 18:08:38 vps113197 postfix/anvil[4009]: statistics: max cache size 1 at Nov 15 18:05:18 Nov 15 18:09:01 vps113197 postfix/pickup[3971]: A3E7C22C103A: uid=0 from=<root> Nov 15 18:09:01 vps113197 postfix/cleanup[4027]: A3E7C22C103A: message-id=<20141115170901.A3E7C22C103A@mail.hoarfrost-entertainment.com> Nov 15 18:09:01 vps113197 postfix/qmgr[3972]: A3E7C22C103A: from=<root@hoarfrost-entertainment.com>, size=828, nrcpt=1 (queue active) Nov 15 18:09:01 vps113197 postfix/pipe[4031]: A3E7C22C103A: to=<kay@hoarfrost-entertainment.com>, orig_to=<root>, relay=maildrop, delay=0.21, delays=0.16/0.01/0/0.04, dsn=4.3.0, status=deferred (temporary failure. Command output: /usr/local/courier/bin/maildrop: Temporary authentication failure. ) Nov 15 18:09:49 vps113197 postfix/qmgr[3972]: 94A9622C102F: from=<double-bounce@hoarfrost-entertainment.com>, size=983, nrcpt=1 (queue active) Nov 15 18:09:49 vps113197 postfix/pipe[4031]: 94A9622C102F: to=<postmaster@hoarfrost-entertainment.com>, orig_to=<postmaster>, relay=maildrop, delay=2314, delays=2314/0/0/0.01, dsn=4.3.0, status=deferred (temporary failure. Command output: /usr/local/courier/bin/maildrop: Temporary authentication failure. ) Nov 15 18:10:27 vps113197 postfix/smtpd[4037]: connect from unknown[unknown] Nov 15 18:10:27 vps113197 postfix/smtpd[4037]: lost connection after CONNECT from unknown[unknown] Nov 15 18:10:27 vps113197 postfix/smtpd[4037]: disconnect from unknown[unknown]
/etc/postfix/main.cf:
[quote]mtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
append_dot_mydomain = no
myhostname = mail.hoarfrost-entertainment.com
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
myorigin = hoarfrost-entertainment.com
mydestination = localhost.localdomain, localhost
mynetworks = 127.0.0.1, localhost
mailbox_command = /usr/bin/procmail -a "$EXTENSION"
mailbox_size_limit = 0
recipient_delimiter = +
best_mx_transport = local
local_transport = local
home_mailbox = Maildir/
notify_classes = 2bounce, bounce, delay, policy, protocol, resource, software
masquerade_domains = hoarfrost-entertainment.com
smtpd_helo_required = yes
strict_rfc821_envelopes = yes
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql_virtual_alias_maps.cf
virtual_gid_maps = static:20001
virtual_mailbox_base = /home/virtual
virtual_mailbox_domains = proxy:mysql:/etc/postfix/mysql_virtual_domains_maps.cf
virtual_mailbox_limit = 51200000
virtual_mailbox_maps = proxy:mysql:/etc/postfix/mysql_virtual_mailbox_maps.cf
virtual_minimum_uid = 20001
virtual_uid_maps = static:20001
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonica$
message_size_limit = 50240000
smtpd_recipient_restrictions = permit_mynetworks, reject_unauth_destination, permit
smtpd_data_restrictions = reject_unauth_pipelining, permit
virtual_transport = maildrop
maildrop_destination_recipient_limit = 1[/quote]
/etc/postfix/master.cf:
[quote]#
Postfix master process configuration file. For details on the format
of the file, see the master(5) manual page (command: “man 5 master”).
Do not forget to execute “postfix reload” after editing this file.
service type private unpriv chroot wakeup maxproc command + args
(yes) (yes) (yes) (never) (100)
smtp inet n - - - - smtpd
#smtp inet n - - - 1 postscreen
#smtpd pass - - - - - smtpd
#dnsblog unix - - - - 0 dnsblog
#tlsproxy unix - - - - 0 tlsproxy
#submission inet n - - - - smtpd
-o syslog_name=postfix/submission
-o smtpd_tls_security_level=encrypt
-o smtpd_sasl_auth_enable=yes
-o smtpd_client_restrictions=permit_sasl_authenticated,reject
-o milter_macro_daemon_name=ORIGINATING
#smtps inet n - - - - smtpd
-o syslog_name=postfix/smtps
-o smtpd_tls_wrappermode=yes
#628 inet n - - - - qmqpd
pickup fifo n - - 60 1 pickup -o receive_override_options=no_header_body_checks -o content_filter=
cleanup unix n - - - 0 cleanup
qmgr fifo n - n 300 1 qmgr
#qmgr fifo n - n 300 1 oqmgr
tlsmgr unix - - - 1000? 1 tlsmgr
rewrite unix - - - - - trivial-rewrite
bounce unix - - - - 0 bounce
defer unix - - - - 0 bounce
trace unix - - - - 0 bounce
verify unix - - - - 1 verify
flush unix n - - 1000? 0 flush
proxymap unix - - n - - proxymap
proxywrite unix - - n - 1 proxymap
smtp unix - - - - - smtp
relay unix - - - - - smtp
-o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq unix n - - - - showq
error unix - - - - - error
retry unix - - - - - error
discard unix - - - - - discard
local unix - n n - - local
virtual unix - n n - - virtual
lmtp unix - - - - - lmtp
anvil unix - - - - 1 anvil
scache unix - - - - 1 scache
Interfaces to non-Postfix software. Be sure to examine the manual
pages of the non-Postfix software to find out what options it wants.
Many of the following services use the Postfix pipe(8) delivery
agent. See the pipe(8) man page for information about ${recipient}
and other message envelope options.
maildrop. See the Postfix MAILDROP_README file for details.
Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop unix - n n - - pipe
flags=DRhu user=vmail argv=/usr/local/courier/bin/maildrop -w 90 -d ${user}@${nexthop} ${extension} ${recipient} ${user} ${nexthop} ${sender}
Recent Cyrus versions can use the existing “lmtp” master.cf entry.
Specify in cyrus.conf:
lmtp cmd=“lmtpd -a” listen=“localhost:lmtp” proto=tcp4
Specify in main.cf one or more of the following:
mailbox_transport = lmtp:inet:localhost
virtual_transport = lmtp:inet:localhost
Cyrus 2.1.5 (Amos Gouaux)
Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus unix - n n - - pipe
user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
Old example of delivery via Cyrus.
#old-cyrus unix - n n - - pipe
flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
See the Postfix UUCP_README file for configuration details.
uucp unix - n n - - pipe
flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
Other external delivery methods.
ifmail unix - n n - - pipe
flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp unix - n n - - pipe
flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix - n n - 2 pipe
flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman unix - n n - - pipe
flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
${nexthop} ${user}[/quote]
Je ne comprends pas d’où viens cette erreur, j’ai fait quelque recherche déjà mais je n’est rien trouver de concluant. Postfix a été prit depuis les paquets, j’ai compiler maildrop moi-même avec :
Merci beaucoup d’avance,
Cordialement.
