Bonsoir
J’ai installé postfix sur mysql et dovecot et quand je lance une commande pour tester si mon serveur marche en local il me sort cette erreur :
Commande
fatal: /etc/postfix/main.cf, line 52: missing ‘=’ after attribute name: “permit_mynetworks”
Je precise que mon serveur dns local est bien configuré.
Voici mon fichier main.cf
See /usr/share/postfix/main.cf.dist for a commented, more complete version
Debian specific: Specifying a file name will cause the first
line of that file to be used as the name. The Debian default
is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
appending .domain is the MUA’s job.
append_dot_mydomain = no
Uncomment the next line to generate “delayed mail” warnings
#delay_warning_time = 4h
readme_directory = no
TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
information on enabling SSL in the smtp client.
myhostname = ks390281.kimsufi.com
alias_maps = hash:/etc/aliases
alias_database = hash:/etc/aliases
mydestination = test.com, ks390281.kimsufi.com, localhost.kimsufi.com, , localhost
relayhost =
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
virtual_uid_maps = static:3000
virtual_gid_maps = static:3000
virtual_mailbox_base = /home/facteur
virtual_transport = dovecot
virtual_mailbox_domains = mysql:/etc/postfix/mysql_virtual_mailbox_domains.cf
virtual_mailbox_maps = mysql:/etc/postfix/mysql_virtual_mailbox_maps.cf
virtual_alias_maps = mysql:/etc/postfix/mysql_virtual_alias_maps.cf
relay_domains = mysql:/etc/postfix/mysql_relay_domains.cf
smtpd_recipient_restrictions =permit_mynetworks,
#permit_sasl_authenticated,
#reject_non_fqdn_hostname,
#reject_non_fqdn_sender,
#reject_non_fqdn_recipient,
#reject_unauth_destination,
#reject_unauth_pipelining,
#reject_invalid_hostname
smtpd_sasl_auth_enable = yes
smtpd_sasl_security_options = noanonymous
delay_warning_time = 1h
dovecot_destination_recipient_limit = 1
inet_protocols = ipv4
Merci pour votre aide
