je viens d eassayer je n arrive cela ne change rien j ai tourjour le probleme
je suis a la lettre ce tuto http://pureedelinux.net/howto/bootsplash.html
mon noyau est le 2.6.18 , jai telecharger les sources du kernel sur ftp://ftp.eu.kernel.org/pub/linux/kernel/v2.6/ et le bootsplash aussi sur un autre site je ne sais plus le quel mais j ai le bootsplash-3.1.6-2.6.20.diff
j arrive bien a patcher le noyau mais quand apres je fais make menuconfig
j ai une erreur
scripts/kconfig/lxdialog/dialog.h:197: error: expected ‘)’ before ‘*’ token
scripts/kconfig/lxdialog/dialog.h:198: error: expected ‘)’ before ‘*’ token
scripts/kconfig/lxdialog/dialog.h:200: error: expected ‘)’ before ‘*’ token
scripts/kconfig/lxdialog/checklist.c:31: error: expected ‘)’ before ‘*’ token
scripts/kconfig/lxdialog/checklist.c:59: error: expected ‘)’ before ‘*’ token
scripts/kconfig/lxdialog/checklist.c:95: error: expected ‘)’ before ‘*’ token
scripts/kconfig/lxdialog/checklist.c: In function ‘dialog_checklist’:
scripts/kconfig/lxdialog/checklist.c:116: error: ‘WINDOW’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:116: error: (Each undeclared identifier is reported only once
scripts/kconfig/lxdialog/checklist.c:116: error: for each function it appears in.)
scripts/kconfig/lxdialog/checklist.c:116: error: ‘dialog’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:116: error: ‘list’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:116: warning: left-hand operand of comma expression has no effect
scripts/kconfig/lxdialog/checklist.c:129: warning: implicit declaration of function ‘getmaxy’
scripts/kconfig/lxdialog/checklist.c:129: error: ‘stdscr’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:130: error: ‘KEY_MAX’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:131: warning: implicit declaration of function ‘getmaxx’
scripts/kconfig/lxdialog/checklist.c:137: error: ‘COLS’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:138: error: ‘LINES’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:140: warning: implicit declaration of function ‘draw_shadow’
scripts/kconfig/lxdialog/checklist.c:142: warning: implicit declaration of function ‘newwin’
scripts/kconfig/lxdialog/checklist.c:143: warning: implicit declaration of function ‘keypad’
scripts/kconfig/lxdialog/checklist.c:143: error: ‘TRUE’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:145: warning: implicit declaration of function ‘draw_box’
scripts/kconfig/lxdialog/checklist.c:146: error: ‘struct dialog_color’ has no member named ‘atr’
scripts/kconfig/lxdialog/checklist.c:147: warning: implicit declaration of function ‘wattrset’
scripts/kconfig/lxdialog/checklist.c:147: error: ‘struct dialog_color’ has no member named ‘atr’
scripts/kconfig/lxdialog/checklist.c:148: warning: implicit declaration of function ‘mvwaddch’
scripts/kconfig/lxdialog/checklist.c:150: warning: implicit declaration of function ‘waddch’
scripts/kconfig/lxdialog/checklist.c:151: error: ‘struct dialog_color’ has no member named ‘atr’
scripts/kconfig/lxdialog/checklist.c:154: warning: implicit declaration of function ‘print_title’
scripts/kconfig/lxdialog/checklist.c:156: error: ‘struct dialog_color’ has no member named ‘atr’
scripts/kconfig/lxdialog/checklist.c:157: warning: implicit declaration of function ‘print_autowrap’
scripts/kconfig/lxdialog/checklist.c:164: warning: implicit declaration of function ‘subwin’
scripts/kconfig/lxdialog/checklist.c:171: error: ‘struct dialog_color’ has no member named ‘atr’
scripts/kconfig/lxdialog/checklist.c:189: warning: implicit declaration of function ‘print_item’
scripts/kconfig/lxdialog/checklist.c:192: warning: implicit declaration of function ‘print_arrows’
scripts/kconfig/lxdialog/checklist.c:195: warning: implicit declaration of function ‘print_buttons’
scripts/kconfig/lxdialog/checklist.c:197: warning: implicit declaration of function ‘wnoutrefresh’
scripts/kconfig/lxdialog/checklist.c:199: warning: implicit declaration of function ‘doupdate’
scripts/kconfig/lxdialog/checklist.c:202: warning: implicit declaration of function ‘wgetch’
scripts/kconfig/lxdialog/checklist.c:210: error: ‘KEY_UP’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:210: error: ‘KEY_DOWN’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:220: error: ‘FALSE’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:221: warning: implicit declaration of function ‘scrollok’
scripts/kconfig/lxdialog/checklist.c:222: warning: implicit declaration of function ‘wscrl’
scripts/kconfig/lxdialog/checklist.c:232: warning: implicit declaration of function ‘wrefresh’
scripts/kconfig/lxdialog/checklist.c:293: warning: implicit declaration of function ‘delwin’
scripts/kconfig/lxdialog/checklist.c:297: error: ‘KEY_LEFT’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:298: error: ‘KEY_RIGHT’ undeclared (first use in this function)
scripts/kconfig/lxdialog/checklist.c:310: warning: implicit declaration of function ‘on_key_esc’
scripts/kconfig/lxdialog/checklist.c:312: error: ‘KEY_RESIZE’ undeclared (first use in this function)
make[1]: *** [scripts/kconfig/lxdialog/checklist.o] Erreur 1
make: *** [menuconfig] Erreur 2
avez vous un site ou il y a de bon tuto!! car je suis 2 site pour essayer de comprendre.
merci avous tous de votre aide
