Je n’ai que dwm en tant que gestionnaire de fenêtres, pas d’environnements de bureaux.
Voici mes deux conky, si des âmes charitables peuvent essayer sur leur WM/DM…
Un GRAND merci d’avance!!!
.conkyrc
[code]background no
use_xft yes
xftfont Matrix:size=11
xftalpha 0.5
update_interval 1.0
total_run_times 0
own_window no
own_window_type normal
own_window_transparent yes
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
double_buffer yes
minimum_size 200
maximum_width 200
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders yes
default_color 00ff00
color1 356e31
color2 769773
default_shade_color black
default_outline_color black
alignment top_right
gap_x 11
gap_y 30
no_buffers no
uppercase no
cpu_avg_samples 2
override_utf8_locale yes
TEXT
${color2}${font Matrix:size=11}$alignc Debian sid GNU/Linux
${color2}$alignc kernel $kernel / $machine
${color}$alignc ${time %A %d %B %Y}
${color}$alignc ${time %H:%M:%S}
${color2}Uptime : ${color}$alignc $uptime
${color2}Alerte MAJ : $alignc ${color}${execi 1100 aptitude search “~U” | wc -l | tail} paquet(s)
${color2}Mail : ${color}${texeci 30 ~/scripts/check.sh}
${color1}${font Matrix:size=11}FILESYSTEM ${stippled_hr 4}
${color2}$alignc DEBIAN HDD : ${color}${hddtemp /dev/sdb}°C
${color2}${font}ROOT ${color}$alignr${fs_used /} / ${fs_size /}
${fs_used_perc /}% ${color2}${fs_bar /}
${font}HOME ${color}$alignr${fs_used /home} / ${fs_size /home}
${fs_used_perc /home}% ${color2}${fs_bar /home}
${color2}$alignc WIN HDD : ${color}${hddtemp /dev/sda}°C
${color2}${font}XP ${color}$alignr${fs_used /mnt/xp} / ${fs_size /mnt/xp}
${fs_used_perc /mnt/xp}% ${color2}${fs_bar /mnt/xp}
${color2}${font}WD HDD ${color}$alignr${fs_used /mnt/WD} / ${fs_size /mnt/WD}
${fs_used_perc /mnt/WD}% ${color2}${fs_bar /mnt/WD}
${color1}
${font Matrix:size=11}CPU ${stippled_hr 4}
${color2}
Temp :${color} ${exec sensors | grep Core0 | cut -c15-21} $alignr ${color}${freq_g 0} GHz
${color2}Core 1 : ${color}${cpu cpu0}% ${color2}${cpubar cpu0}
${cpugraph 022c00 a9cba7}
RAM $alignr ${color}$mem / $memmax
$memperc% ${color2}${membar}
SWAP $alignr ${color}$swap / $swapmax
$swapperc% ${color2}${swapbar}
${color1}
${font Matrix:size=11}PROCESSES ${stippled_hr 4}
${color2}Highest CPU $alignr %
${color}${top name 1} $alignc${top pid 1} $alignr${top cpu 1}
${top name 2} $alignc${top pid 2} $alignr${top cpu 2}
${top name 3} $alignc${top pid 3} $alignr${top cpu 3}
${top name 4} $alignc${top pid 4} $alignr${top cpu 4}
${top name 5} $alignc${top pid 5} $alignr${top cpu 5}
${color2}
Highest RAM $alignr %
${color}${top_mem name 1} $alignc${top pid 1} $alignr${top_mem mem 1}
${top_mem name 2} $alignc${top pid 2} $alignr${top_mem mem 2}
${top_mem name 3} $alignc${top pid 3} $alignr${top_mem mem 3}
${top_mem name 4} $alignc${top pid 4} $alignr${top_mem mem 4}
${top_mem name 5} $alignc${top pid 5} $alignr${top_mem mem 5}
${color1}
${font Matrix:size=11}NETWORK ${stippled_hr 4}
${color2}Local IP : $alignr ${color}${addr eth1}
${color2}Public IP : $alignr ${color}${execi 3600 wget www.whatismyip.com/automation/n09230945.asp -O - -q}
${color2}Incoming $alignr ${color}${downspeed eth1} kB/s
${color2}Total Incoming : $alignr ${color}${totaldown eth1}
${color2}${downspeedgraph eth1 022c00 a9cba7}
${color2}Outgoing $alignr ${color}${upspeed eth1} kB/s
${color2}Total Outgoing : $alignr ${color}${totalup eth1}
${color2}${upspeedgraph eth1 022c00 a9cba7}[/code]
.conkyrc2
[code]background no
use_xft yes
xftalpha 0.5
update_interval 1.0
total_run_times 0
own_window no
double_buffer yes
minimum_size 200
maximum_width 200
draw_shades no
draw_outline no
draw_borders no
color1 356e31
color2 769773
alignment top_left
gap_x 11
gap_y 30
no_buffers yes
uppercase no
cpu_avg_samples 2
TEXT
${color2}${font Sans:size=11}$alignc TEST[/code]
