Quand j’insere un disque et que je ferme le lecteur il se passe:
Mar 11 21:51:56 nepenthes kernel: [ 4233.849989] hda: cdrom_decode_status: status=0x51 { DriveReady SeekComplete Error }
Mar 11 21:51:56 nepenthes kernel: [ 4233.849996] hda: cdrom_decode_status: error=0x40 { LastFailedSense=0x04 }
Mar 11 21:51:56 nepenthes kernel: [ 4233.850000] hda: possibly failed opcode: 0xa0
Mar 11 21:51:56 nepenthes kernel: [ 4233.895174] hda: cdrom_decode_status: status=0x51 { DriveReady SeekComplete Error }
Mar 11 21:51:56 nepenthes kernel: [ 4233.895179] hda: cdrom_decode_status: error=0x40 { LastFailedSense=0x04 }
Mar 11 21:51:56 nepenthes kernel: [ 4233.895182] hda: possibly failed opcode: 0xa0
Mar 11 21:51:56 nepenthes kernel: [ 4233.940378] hda: cdrom_decode_status: status=0x51 { DriveReady SeekComplete Error }
Mar 11 21:51:56 nepenthes kernel: [ 4233.940385] hda: cdrom_decode_status: error=0x40 { LastFailedSense=0x04 }
Mar 11 21:51:56 nepenthes kernel: [ 4233.940389] hda: possibly failed opcode: 0xa0
Mar 11 21:51:56 nepenthes kernel: [ 4233.985571] hda: cdrom_decode_status: status=0x51 { DriveReady SeekComplete Error }
Mar 11 21:51:56 nepenthes kernel: [ 4233.985578] hda: cdrom_decode_status: error=0x40 { LastFailedSense=0x04 }
Mar 11 21:51:56 nepenthes kernel: [ 4233.985581] hda: possibly failed opcode: 0xa0
Mar 11 21:51:56 nepenthes kernel: [ 4233.985585] hda: DMA disabled
Mar 11 21:51:56 nepenthes kernel: [ 4234.032027] hda: ATAPI reset complete
Si j’essaye ensuite de le monter a la main:
> sudo mount /dev/hda
mount: block device /dev/hda is write-protected, mounting read-only
La commande ne termine jamais.
“lshw” me donne:
*-cdrom
description: DVD-RAM writer
product: PLEXTOR DVDR PX-870A
physical id: 0
bus info: ide@0.0
logical name: /dev/hda
version: 1.06
capabilities: packet atapi cdrom removable nonmagnetic dma lba iordy audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: status=ready
*-medium
physical id: 0
Le lecteur/graveur est neuf, et semble fonctionner sur windows.
Je suis sur Debian quelque chose comme squeeze+sid.
Toute aide, ou meme piste pour savoir dans quelle direction chercher, est la bienvenue.
