[quote=“fran.b”] Que donnes dmesg | grep hdc et y a-t-il des messages dans les logs?[/quote]alors ben pas mal de choses :$ dmesg | grep hdc
ide1: BM-DMA at 0x1868-0x186f, BIOS settings: hdc:DMA, hdd:pio
hdc: MATSHITADVD-ROM SR-8177, ATAPI CD/DVD-ROM drive
hdc: host max PIO4 wanted PIO255(auto-tune) selected PIO4
hdc: UDMA/33 mode selected
hdc: ATAPI 61X DVD-ROM drive, 256kB Cache
hdc: media error (bad sector): status=0x51 { DriveReady SeekComplete Error }
hdc: media error (bad sector): error=0x34 { AbortedCommand LastFailedSense=0x03 }
ATAPI device hdc:
end_request: I/O error, dev hdc, sector 64
Buffer I/O error on device hdc, logical block 8
ATAPI device hdc:
ATAPI device hdc:
end_request: I/O error, dev hdc, sector 0
Buffer I/O error on device hdc, logical block 0
Buffer I/O error on device hdc, logical block 1
ATAPI device hdc:
ATAPI device hdc:
ATAPI device hdc:
hdc: drive_cmd: status=0x51 { DriveReady SeekComplete Error }
hdc: drive_cmd: error=0x04 { AbortedCommand }
ATAPI device hdc:
ATAPI device hdc:
ATAPI device hdc:
ATAPI device hdc:
ATAPI device hdc:
ATAPI device hdc:
ATAPI device hdc:
ATAPI device hdc:
ATAPI device hdc:
end_request: I/O error, dev hdc, sector 72
Buffer I/O error on device hdc, logical block 9
Buffer I/O error on device hdc, logical block 10
Buffer I/O error on device hdc, logical block 11
Buffer I/O error on device hdc, logical block 12
Buffer I/O error on device hdc, logical block 13
ATAPI device hdc:
ATAPI device hdc:
end_request: I/O error, dev hdc, sector 112
Buffer I/O error on device hdc, logical block 14
Buffer I/O error on device hdc, logical block 15
Buffer I/O error on device hdc, logical block 16
ATAPI device hdc:
j’ai aussi un message à chaque démarrage de l’ordi qui me dit que le laptop-mode essaye de gérer le parquage des têtes de /dev/hdc mais n’y arrive pas (normal c’est un lecteur dvd). Je n’arrive pas à régler dans /etc/laptop-mode/laptop-mode.conf l’arrêt de ce comportement. On peut en effet y choisir sur quel HDD laptop-mode agit mais même si je met /dev/hda j’ai toujours le message. Voici le réglagle de laptop-mode [code]#
The drives that laptop mode controls.
Separate them by a space, e.g. HD="/dev/hda /dev/hdb". The default is a
wildcard, which will get you all your IDE and SCSI/SATA drives.
HD="/dev/hda"[/code]
