Problème prelude log
Je ne c’est pas si vous pouvez m’aider mais j’ai un problème sous prelude
Dans les logs j’ai sa :
Dans le prelude-manager.conf j’ai rajouter sa et redemarré le serveur :
[code][format=syslog]
time-format = "%b %d %H:%M:%S"
prefix-regex = "^(?P.{15}) (?P\S+) (?:(?P\S+?)(?:blush:
file = /var/log/mylogfile
udp-server = 0.0.0.0:514
[format=apache]
time-format = "%d/%b/%Y:%H:%M:%S"
prefix-regex = "^(?P\S+) - - [(?P.{20}) +.{4}] "
udp-server = 0.0.0.0:514[/code]
mais toujours pareil.
Problème résolu
[code]include = /etc/prelude/default/idmef-client.conf
[format=syslog]
prefix-regex = "^(?P.{15}) (?P\S+) (?:(?P\S+?)(?:[(?P[0-9]+)])?: )?"
file = /var/log/messages
file = /var/log/syslog
file = /var/log/auth.log
file = /var/log/daemon.log
file = /var/log/kern.log
file = /var/log/emerge.log
file = /var/log/user.log
file = /var/log/maillog
[format=apache]
file = /var/log/apache2/access_log
file = /var/log/apache2/error_log
file = /var/log/apache2/ssl_error_log
[Pcre]
ruleset=/etc/prelude-lml/ruleset/pcre.rules
[code]include = /etc/prelude/default/global.conf
listen = 127.0.0.1
[db]
type = mysql
host = localhost
port = 3306
name = prelude
user = prelude
pass = PreludeUserPass
[XmlMod]
disable-buffering
validate
format
logfile = stderr
logfile = /var/log/prelude-xml.log[/code]
La solution peut toujours aider :slightly_smiling:
Merci quand même de votre aide
