bonjour j’ai crée un controleur de domaine avec samba et LDAP mais il me reste un petit probléme celui des profils itinérant à chaque fois que je connecte un utilisateur j ai le droit a l’erreurwindows ne peut pas trouver de copie serveur de votre profil itinérant et tente de vous connecter avec un profil temporaire ...
voici le smb.conf
workgroup = pan
netbios name = srvldap
server string = Samba-LDAP PDC Server
domain master = Yes
local master = Yes
domain logons = Yes
os level = 40
#passwd program = /usr/sbin/smbldap-passwd ?u %u
ldap passwd sync = Yes
passdb backend = ldapsam:ldap://127.0.0.1/
### A changer === >
ldap admin dn = cn=admin,dc=pan,dc=loc
### A changer === >
ldap suffix = dc=pan,dc=loc
ldap group suffix = ou=Groups
ldap user suffix = ou=Users
ldap machine suffix = ou=Machines
add user script = /usr/sbin/smbldap-useradd -m "%u"
ldap delete dn = Yes
delete user script = /usr/sbin/smbldap-userdel "%u"
add machine script = /usr/sbin/smbldap-useradd -w "%u"
add group script = /usr/sbin/smbldap-groupadd -p "%g"
#delete group script = /usr/sbin/smbldap-groupdel "%g"
add user to group script = /usr/sbin/smbldap-groupmod -m "%u" "%g"
delete user from group script = /usr/sbin/smbldap-groupmod -x "%u" "%g"
set primary group script = /usr/sbin/smbldap-usermod -g "%g" "%u"
#logon path = \\%L\%U
logon drive = Z:
logon path = \\%L\profiles\%U\%m
logon drive = Z:
logon home = \\%L\%U
socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
case sensitive = No
default case = lower
preserve case = yes
short preserve case = Yes
#character set = iso8859-1
logon script = logon.bat
dns proxy = No
### A changer si vous n'utilisez pas ce réseau === >
hosts allow = 10.0.
nt acl support = Yes
msdfs root = Yes
hide files = /desktop.ini/ntuser.ini/NTUSER.*/
### FIN DE LA PARTIE GLOBALE #####
#### LES PARTAGES #####
[netlogon]
path = /srv/netlogon/
read only = yes
browseable = No
guest ok = yes
#[profile]
comment = Profil de l utilisateur
path = /home
browseable = No
guest ok = yes
writeable = Yes
#profile acls = yes
create mask = 0700
directory mask = 0700
#[homes]
#comment = Repertoire Personnel
#path = /srv/partage/personnel/%u
#browseable = No
#writeable = Yes
[partage]
comment = Repertoire commun
browseable = Yes
write list = Domaine Users
guest ok = no
writeable = Yes
public = No
voici les droits sur les repertoires
rvldap:/home# ls -l
total 28
drwx---rwx 2 fizri Domain Users 4096 2008-12-16 14:48 fizri
drwx------ 2 root root 16384 2008-12-16 10:32 lost+found
drwxrwxrwx 2 operateur Domain Users 4096 2008-12-16 14:23 XXXXX
drwxr-xr-x 20 operateur operateur 4096 2008-12-17 11:44 operateur
et quand je lance la commande pdbedit -up fizri
voici la reponse ke j ai
pdbedit -ps fizri
Unix username: fizri
NT username: fizri
Account Flags: [U ]
User SID: S-1-5-21-73829724-297848066-1435562192-3004
Primary Group SID: S-1-5-21-73829724-297848066-1435562192-513
Full Name: farid Izri
Home Directory: \\srvldap\fizri
HomeDir Drive: Z:
Logon Script: u
Profile Path: s
je ne comprend pas pourquoi j ai Home directory \srvldap\fizri ,sa ne devrait pas etre a la place \srvldap\home\fizri
merci de votre aide à tous et bonne journée
