Probleme proftpd <Ifmodule>
j’ai installé un serveur proftpd avec authentification par certificat SSL
j’avais auparavant installer ce serveur sur une machine ubuntu 8.10 Desktop et cela fonctionnais.
J’ai souhaité migrer vers debian et lors du demarrage du serveur j’ai ce message d’erreur :
"Starting ftp server: proftpd - Fatal: : unclosed context on line 208 of ‘/etc/proftpd/proftpd.conf’"
la ligne 208 est la derniere de mon fichier de conf et ne correspond pas au problème.Au niveau des logs il n’y a tout simplement aucune erreur
comment puis-je corriger ce problème ?
voici mon fichier de configuration
[quote]#
/etc/proftpd/proftpd.conf – This is a basic ProFTPD configuration file.
To really apply changes reload proftpd after modifications.
Includes DSO modules
Include /etc/proftpd/modules.conf
Set off to disable IPv6 support which is annoying on IPv4 only boxes.
UseIPv6 off
ServerName “Mon serveur FTP”
ServerType standalone
ServerIdent on “Bienvenue sur mon ftp. Veuillez-vous identifiez”
DeferWelcome on
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutNoTransfer 600
TimeoutStalled 600
TimeoutIdle 1200
DisplayLogin welcome.msg
#DisplayChdir .message
ListOptions “-l”
DenyFilter *.*/
Use this to jail all users in their homes
DefaultRoot ~
Users require a valid shell listed in /etc/shells to login.
Use this directive to release that constrain.
RequireValidShell off
Port 21 is the standard FTP port.
Port 21
In some cases you have to specify passive ports range to by-pass
firewall limitations. Ephemeral ports can be used for that, but
feel free to use a more narrow range.
PassivePorts 49152 65534
If your host was NATted, this option is useful in order to
allow passive tranfers to work. You have to use your public
address and opening the passive ports used on your firewall as well.
MasqueradeAddress 1.2.3.4
To prevent DoS attacks, set the maximum number of child processes
to 30. If you need to allow more than 30 concurrent connections
at once, simply increase this value. Note that this ONLY works
in standalone mode, in inetd mode you should use an inetd server
that allows you to limit maximum number of processes per service
(such as xinetd)
MaxInstances 30
Set the user and group that the server normally runs at.
User proftpd
Group nogroup
Umask 022 is a good standard umask to prevent new files and dirs
(second parm) from being group and world writable.
#Umask 002 002
Normally, we want files to be overwriteable.
AllowOverwrite on
Uncomment this if you are using NIS or LDAP to retrieve passwords:
PersistentPasswd off
Be warned: use of this directive impacts CPU average load!
Uncomment this if you like to see progress and transfer rate with ftpwho
in downloads. That is not needed for uploads rates.
UseSendFile off
Choose a SQL backend among MySQL or PostgreSQL.
Both modules are loaded in default configuration, so you have to specify the backend
or comment out the unused module in /etc/proftpd/modules.conf.
Use ‘mysql’ or ‘postgres’ as possible values.
SQLBackend mysql
TransferLog /var/log/proftpd/xferlog
SystemLog /var/log/proftpd/proftpd.log
TLSEngine on
TLSLog /var/log/proftpd/tls.log
TLSProtocol SSLv23
TLSOptions NoCertRequest
TLSRSACertificateFile /etc/proftpd/ssl/proftpd.cert.pem
TLSRSACertificateKeyFile /etc/proftpd/ssl/proftpd.key.pem
TLSVerifyClient off
TLSRequired off
#MasqueradeAddress rt74.eu
#PassivePorts 19200 19250
QuotaDirectoryTally on
QuotaDisplayUnits Mb
QuotaShowQuotas on
Definit les requetes SQL pour que ProFTPd recupere les infos sur les quotas
SQLNamedQuery get-quota-limit SELECT “name, quota_type, par_session, limit_type, bytes_up_limit, bytes_down_limit, bytes_transfer_limit, files_up_limit, files_down_limit, files_transfer_limit FROM ftpquotalimits WHERE name = ‘%{0}’ AND quota_type = ‘%{1}’”
SQLNamedQuery get-quota-tally SELECT “name, quota_type, bytes_up_total, bytes_down_total, bytes_transfer_total, files_up_total, files_down_total, files_transfer_total FROM ftpquotatotal WHERE name = ‘%{0}’ AND quota_type = ‘%{1}’”
SQLNamedQuery update-quota-tally UPDATE "bytes_up_total = bytes_up_total + %{0}, bytes_down_total = bytes_down_total + %{1},
bytes_transfer_total = bytes_transfer_total + %{2}, files_up_total = files_up_total + %{3}, files_down_total = files_down_total + %{4}, files_transfer_total = files_transfer_total + %{5} WHERE name = ‘%{6}’ AND quota_type = ‘%{7}’"
ftpquotatotal
SQLNamedQuery insert-quota-tally INSERT “%{0}, %{1}, %{2}, %{3}, %{4}, %{5}, %{6}, %{7}” ftpquotatotal
QuotaLimitTable sql:/get-quota-limit
QuotaTallyTable sql:/get-quota-tally/update-quota-tally/insert-quota-tally
#Ratios on
Delay engine reduces impact of the so-called Timing Attack described in
security.lss.hr/index.php?page=d … 2004-10-02
It is on by default.
#DelayEngine on
ControlsEngine on
ControlsMaxClients 2
ControlsLog /var/log/proftpd/controls.log
ControlsInterval 5
ControlsSocket /var/run/proftpd/proftpd.sock
AdminControlsEngine on
Mod MySQL
Les mots de passe sont cryptds la base avec la fct ENCRYPT (MySQL)
SQLAuthTypes Crypt
SQLAuthenticate users* groups*
Modifiez cette ligne selon l’utilisateur et le mot de passe dinit plut
SQLConnectInfo proftpd@localhost proftpd password
On donne ProFTPD le nom des colonnes de la table usertable
SQLUserInfo ftpuser userid passwd uid gid homedir shell
SQLUserWhereClause “LoginAllowed = ‘true’”
On donne ProFTPD le nom des colonnes de la table “grouptable”
SQLGroupInfo ftpgroup groupname gid members
Creer le repertoire home de l’utilisateur si il n’existe pas
CreateHome on
Met jour les compteurs chaque connection d’un utilisateur
SQLLog PASS updatecount
SQLNamedQuery updatecount UPDATE “count=count+1, accessed=now() WHERE userid=’%u’” ftpuser
#Met jour les compteurs chaque upload ou download d’un utilisateur
SQLLog STOR,DELE modified
SQLNamedQuery modified UPDATE “modified=now() WHERE userid=’%u’” ftpuser
SQLLog RETR dlbytescount
SQLNamedQuery dlbytescount UPDATE “dl_bytes=dl_bytes+%b WHERE userid=’%u’” ftpuser
SQLLog RETR dlcount
SQLNamedQuery dlcount UPDATE “dl_count=dl_count+1 WHERE userid=’%u’” ftpuser
SQLLog STOR ulbytescount
SQLNamedQuery ulbytescount UPDATE “ul_bytes=ul_bytes+%b WHERE userid=’%u’” ftpuser
SQLLog STOR ulcount
SQLNamedQuery ulcount UPDATE “ul_count=ul_count+1 WHERE userid=’%u’” ftpuser
RootLogin off
Gestion des logs
Enregistre les reques SQL dans /var/log/proftpd/mysql.log
SQLLogFile /var/log/proftpd/mysql.log
Enregistre les authentifications
LogFormat auth “%v [%P] %h %t “%r” %s”
ExtendedLog /var/log/proftpd/auth.log AUTH auth
Enregistre les acc aux fichiers
LogFormat write “%h %l %u %t “%r” %s %b”
ExtendedLog /var/log/proftpd/access.log WRITE,READ write
Recupe le nom partir de l’ip de la machine de l’utilisateur ( resolution DNS )
IdentLookups on[/quote]
Les utilisateurs du serveur ftp sont gerer dans une base de donnée mysql
Sur le net j’ai rencontrer des personnes ayant le même problème et le faite de réinstaller le serveur a corriger le problème, malheureusement pas pour moi
J’ai cherché un peu plus en detail le probleme viendrais de 2 modules a savoir IfModule mod_quota.c et le module IfModule mod_ratio.c (en commentant c’est lignes le serveur demmarre)
Merci de votre aide
En reecrivant EXACTEMENT la meme chose le serveur a reussi a demarrer je ne comprend plus :open_mouth:
en esperant que cela servent a d’autre.
En revanche je cherche a forcer l’authentification tls et refuser les connections par ftp et forcer la connection par ftps
quels sont les paramètres a rajouter pour forcer cela ?
